Running Lean? - The Saab Link Forums
Old 05-24-2009, 12:25 PM   #1
Running Lean?
Ok so my friend has an identical ng900 to mine. Its a 1998 Saab 900se and it has a GS Intake and 2.5 inch Catback exhaust and a Viggen intercooler. He wanted to try my Nordic stage 4 tune in his car so i let him, but when we started driving around it boosted fine 22psi and ran good but it sputtered a lit bit at low rpms in like 3rd gear at 55mph like struggling to build boost and making a popping noise??? Then eventually after 65mph it would seem like its pulling like a bat out of hell. I looked at his A/f Gauge and it goes to lean at WOT??? Can someone tell me why?
Then to compare we tried my automotion ECU and it ran good. 20 PSI at WOT it went to rich on the Gauge. No sputtering or nothing. So I know nothing is wrong with his car. No check engine lights or anything some input please?
1998TurboSaab is offline
Old 05-24-2009, 12:34 PM   #2
wide band or narrow band?
'94 9000 Aero
GirlGoneBoosted is offline
Old 05-24-2009, 12:37 PM   #3
Narrow Band. I know they're not accurate but why would a Automotion Stage 2 say Rich and then Nordic Stage 4 Say Lean?
Old 05-24-2009, 12:39 PM   #4
doesn't a stage 4 require a 3.0bar fpr?
'94 9000 Aero
Old 05-24-2009, 12:52 PM   #5
Not that I know of. I checked the specs on GS.
Stg4 Hp 290 and 295 Tq
GS Sportcat/DP, Airfilter + Td0415t 5cm, Forge IC)
Old 05-24-2009, 02:46 PM   #6
nowhereman's Avatar
while it isn't required might that be the reason it is lean though...? stage 2 to stage 4 is a huge jump. Plus as they are done by different tuners they may be programmed to run differently. in your car do they do the same thing? or have you tried them in something different..
2008 9-3 SS: Stg 1
nowhereman is offline
Old 05-24-2009, 03:44 PM   #7
I have all the same mods except I have a 3" downpipe tdo4 viggen turbo. And mine even says lean under wot. ???
Old 05-24-2009, 04:32 PM   #8
VWSAABVT's Avatar
3.0bar fpr is stock
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 05-24-2009, 04:47 PM   #9
sorry couldn't remember.
'94 9000 Aero
Old 05-24-2009, 04:54 PM   #10
Well anyways damnnn it. Any ideas saab linkers?!
Old 05-24-2009, 05:18 PM   #11
saabkid37's Avatar
so...your putting a tune for a td04 in a car with no td04 and no 3 inch dp and your wondering why the A/F may or may not be off, since you really have no idea since your using what is basically a toy and has no bearing on what the mixture actually is?
this thread is full of fail...we need a facepalm smiley on here these days.
saabkid37 is offline
Old 05-24-2009, 05:53 PM   #12
Originally Posted by saabkid37 View Post
so...your putting a tune for a td04 in a car with no td04 and no 3 inch dp and your wondering why the a/f may or may not be off, since you really have no idea since your using what is basically a toy and has no bearing on what the mixture actually is?
This thread is full of fail...we need a facepalm smiley on here these days.
idioso! It also reads lean on my setup to. Get your fucking eyes checked cause i think you need a huge fail sticker on your forhead between your eyes.
Old 05-24-2009, 06:26 PM   #13
saabkid37's Avatar
good one
your still gauging this off a toy gauge that has pretty lights. its just showing you the voltage output of the o2, which is converted downstream by the ecu.
you have no idea if its actually lean or rich.
you also keep running ecu's on inappropriately/inadequately equipped setups...what did you expect to happen?
Old 05-24-2009, 07:04 PM   #14
Green9kAERO's Avatar
maybe nordic tunes their ECUs to a different AFR?
cant a bad map sensor cause you to run lean?
widebands are cheapish, only 200$ adn they look sweet!
Green9kAERO is offline
Old 05-24-2009, 07:35 PM   #15
I have a Wideband. Its going in tommorow with new o2 sensor so we will see the outcome.
Old 05-24-2009, 11:24 PM   #16
JZW
Yea, find out what it actually is reading before you make any assumptions.
The narrow band really is useless, I have seen them go inverted under extreme conditions and read rich when lean and visa-versa, I would not trust them in any way what-so-ever, its just a light show.
Check it with wide-band and see what ya got!
John
JZW is offline
Old 05-24-2009, 11:40 PM   #17
How much hp is that stage 4 putting out?
drivebyrachko is offline
Old 05-25-2009, 09:10 AM   #18
VWSAABVT's Avatar
155 crank *
stg 5 99 9-3 coupe
96 900se sold
VWSAABVT is offline
Old 05-25-2009, 09:34 AM   #19
Drew in Houston's Avatar
John
Holy crap. Inverted? :facepalm:
Here's what the response from a functioning narrow band looks like:
Drew in Houston is offline
Old 05-25-2009, 09:59 AM   #20
Originally Posted by drivebyrachko View Post
how much hp is that stage 4 putting out?
290hp 295ft lbs. Torque
