Nordic Stage 4 Problems - The Saab Link Forums
Old 05-22-2009, 10:53 AM   #1
Ok So I just picked up this stage 4 ecu from Spanky and was wondering Im only pushing 22psi. My old automotion is pushing 22psi and that was a stage 2. So im confused here do I need to adjust my base boost on my wastegate? Im under the impression a Stage 4 Nordic should be pushing somewhere between 25+ PSI?
1998TurboSaab is offline
Old 05-22-2009, 10:55 AM   #2
Castor Troy's Avatar
fuel cut is ~25psi, and afaik that cant be changed without going to a 3 or 5 bar map sensor.
are you running the proper td04? 22psi from a td04 will be more air than 22psi from a t25....
does the car seem faster?
Castor Troy is offline
Old 05-22-2009, 11:06 AM   #3
Trollerator
abdukted1456's Avatar
22 psi seems like a lot for a stage 2
a set amount of boost isn't what makes a tune a certain stage anyways. It's combo of boost, timing, igntion and other things to be honest.
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 05-22-2009, 11:58 AM   #4
Yes it def seems faster. The stage 2 would need 3/4 throttle just to get the tires to lose traction. Stage 4 I give it 1/4 throttle and it spins. Its really nice. But still my automotion on the td04 was still 22psi. Oh well it pulls way smoother but up in higher rpm's in deff drops down to 15 psi?
Old 05-22-2009, 12:18 PM   #5
JK
JK's Avatar
TD04 15t or t25 on the car?
Seems to me like the automotion ECU was running too much, 22psi or so seems more realistic for stage 4.
Could be that your BPC is fried and stuck open and your wategate blows open at 22psi no matter what. That's the case for my 9-3, the T25 wastegate actuator really can't hold more than 20psi even if the vac line running to it is taken off
always a SAAB guy at heart
JK is offline
Old 05-22-2009, 12:33 PM   #6
Trollerator
you may want to check to see what hardware you are supposed to run on the nordic tune. Sometimes stage 4 requires things like a turbo inlet upgrade or larger, more effiecient IC. In which case, you'd probably be losing boost without one as the ECU cuts back once it sees the intake air is WAY hotter than it was programmed for.
1990 900 turbo vert
2004 9-5 aero sedan
Old 05-22-2009, 12:51 PM   #7
Nick Taliaferro
GenuineSaab's Avatar
I always love when people quantify boost as a single peak number.. It needs to be boost at various rpms 22psi peak for a split second at 2500rpm on the t25 is not anywhere near the same 22psi at 5k rpm with the tdo4
Is that ecu setup for a 3bar map sensor? We did a few of those.
Nicholas Taliaferro
GenuineSaab is offline
Old 05-22-2009, 01:46 PM   #8
No not setup for 3bar. And yes it is a td04 turbo. Also I have a Viggen Intercooler and 3inch exhaust. GS Open Air Intake. And a HKS SSQV Bov. So Am I missing anything?
Old 05-22-2009, 01:56 PM   #9
JZW
In reality, going over 22psi is not going to do much good, the extra hw and whatever timing and fuel that is programmed into the ecu should make it a good bit faster. It should hold more boost longer and timing and the end result should be more power.
Once you get up to the 18t or something, then 23-25psi might be more in order and spikes to 27-28psi are not unheard of. With some of the automotion style tuning, a spike to 25psi and then holding 22psi might be just about right, but from what I have seen, the nordic tunes seem to build boost more gradual and avoid those spikes.
Some people love the torque/boost spikes, some people do not, its all in personal preference.
The best way to really know what its doing is to do some acceleration runs and or put it on a dyno and see how it compares to other stg 4 tunes out there.
John
JZW is offline
Old 05-22-2009, 02:14 PM   #10
lms
Yes you are missing something and it's called the IC as most stage 4 IC's call for something bigger then a viggen one. But, this will not get you any more PSI, just better sustainable fun.
lms is offline
Old 05-22-2009, 03:34 PM   #11
Haha alright then guys. I will have to be ordering a bigger intercooler soon then and possibly a IC sprayer kit or make my own. Is it safe to spray water onto the intercooler meaning from the outside?
Old 05-22-2009, 04:30 PM   #12
lms
Sure is as I use a modified aquamist system that has 3 jets.
lms is offline
Old 05-22-2009, 06:33 PM   #13
Gobes's Avatar
Send a message via AIM to Gobes
Do you have an upgraded Downpipe?
2002 9-5- R.I.P.
1999 9-3- SOLD
Gobes is offline
Old 05-22-2009, 07:38 PM   #14
viggenkid's Avatar
are you serious?
have you ever driven in the rain? any ill effects?
viggenkid is offline
Old 05-22-2009, 07:46 PM   #15
christian900se's Avatar
I get ill effects, every time my intercooler gets wet, I seem to lose at least 20whp*
christian900se is offline
Old 05-22-2009, 07:47 PM   #16
Originally Posted by viggenkid View Post
are you serious?
Haha Yeah no traction lol. But yeah it seems to run alot cooler.
Yes Sir!
Old 05-22-2009, 07:47 PM   #17
Seriously?
Old 05-22-2009, 11:28 PM   #18
that plus you don't want to learn the hard way what increasing the boost, plus a rock on plastic endtanks will do ya.
wasaaabi is offline
Old 05-23-2009, 08:31 AM   #19
Alright well dont worry I have got me a IC on order.
Old 05-23-2009, 08:59 AM   #20
Gobes's Avatar
What IC did you order?
2002 9-5- R.I.P.
1999 9-3- SOLD
Gobes is offline
