thermal coatings - The Saab Link Forums
Old 05-13-2009, 01:51 PM   #1
thermal coatings
so i was reading more on thermal coatings and came across flow coat coating". its a hydophobic,teflon type coatingto improve airflow and fuel residue and carbon . the coating cover the exhuast and intake ports of the cylender head and also the ends of the valve stems ...the thickness can be between 0.6 and to 0.30 ,0.35 ,0.45mm the gains can be from 1-2 % but it ruduces friction. imporves spool for turbos and lowers water and oil temps it may be somthing i want to gini pig for my head.
however i already have had my head port and polished so would i have to prot my head 0.35mm more for a 0.35 thermal coating ?also i haveto have my valve guids seals.ect replaces so would i have that done first?im goingto give them a call.
calicocoatings.com swaintech.com
itsaviggn is offline
Old 05-13-2009, 02:26 PM   #2
Cost?
Old 05-13-2009, 02:39 PM   #3
nowhereman's Avatar
what he ^ said
is it prohibitively expensive?
2008 9-3 SS: Stg 1
nowhereman is offline
Old 05-13-2009, 02:58 PM   #4
9-3sleeper's Avatar
I've thought about things like this, in fact if I do have my turbo out this summer to covert to 18t I will be having it coated.
9-3sleeper is offline
Old 05-13-2009, 03:34 PM   #5
9-3sleeper's Avatar
well I just wrote swain tech an email asking how much it would cost to have my i/c and intake heat sheild cated with BBE, my manifold DP and turbo coated in white lightning, and my intake maniflod coated in TBC.
Ill let yall know what they say.
Itll probably be horendous.
Old 05-13-2009, 03:48 PM   #6
saabkid37's Avatar
swain tech is dough...but its awesome and way better than jet hot.
has this cool "sweating" property too
saabkid37 is offline
Old 05-13-2009, 03:57 PM   #7
adshaft's Avatar
Looking to send them my pistons for the gold coatings $52.50/each.
http://www.swaintech.com/store.asp?pid=10971
"Prices assume disassembled, clean “standard” parts in good condition. Used
parts can be coated, but a cleaning or stripping charge may apply. Do not send assembled or dirty parts.
Pistons
TBC on Dome and Poly Moly on Skirt ……................ $32.00 each
*TBC on Dome and PC-9 on Skirt* ………................. $38.00 each
Gold Coat on Dome and Poly Moly on Skirt .............. $48.00 each
Gold Coat on Dome and PC-9 on Skirt ……............... $52.50 each
Dome Only with TBC ………………………................. $24.50 each
Dome Only with Gold Coat ……..………................... $42.50 each
Skirt Only with Poly Moly …....…………...…............. $14.00 each
Skirt Only with PC-9 ………………….…................…. $18.00 each
Heavy Skit Build up with PC-9 (.002-.004”)…............. $24.00 each
Diesel (4.5” diameter and above) TBC and PM .......... $60.00 each "
[SIGPIC][/SIGPIC]
adshaft is offline
Old 05-13-2009, 04:29 PM   #8
turbojohnny's Avatar
Guinea Pig
turbojohnny is offline
Old 05-13-2009, 08:28 PM   #9
9-3sleeper's Avatar
wow. looks like Ill have to pick and choose what I want done. It may only be the turbo
I did really want to do the rest of the exhaust parts and the intercooler though.
Old 05-13-2009, 08:42 PM   #10
Drew in Houston's Avatar
You could think about Polydyn as well.
http://www.polydyn.com/index.htm
Their website isn't great, but I had them do the inside & outside of the exhaust housing and rotor faces with a heat resistant coating, and the rotor sides with an oil shedding coating on my RX7. All have held up well (just had the engine apart again). That said, I had them do my header as well, but that part seems to flex too much and coating is flaking off.
Drew in Houston is offline
Old 05-14-2009, 10:47 PM   #11
9-3sleeper's Avatar
they look pretty good but it doesn't look like they offer any heat shedding coatings like the BBE from swain tech. I really want to get my i/c covered in that stuff, it would be neat to see how much faster I could recover from heat soak with it. It also sounds like it would look pretty cool... as you can probably deduce Im a fan of sleepers and having a black intercooler would add to that effect.
