New trans mount bracket for the 2.0 - The Saab Link Forums
Old 05-06-2009, 02:45 PM   #1
Nick Taliaferro
GenuineSaab's Avatar
Since we have had issies with the stock stamped steel part we fabricated one of tubing with more mounting points. It ties into 5 10mm bolts instead of the factory 3. Should eliminate any problems. Probably overkill but hey its actually about the same weight. Should have a production engine side bracket kit for ac delete soon. It will use 2 bolts instead of the factory single.
Ties into the top two bolts.
You can see we run off the shelf mounts even!
Nicholas Taliaferro
GenuineSaab is offline
Old 05-06-2009, 02:57 PM   #2
Harvey's Autohaus's Avatar
Nice Fancy Looken Piece Nick! And I Like that Easy Access Bell Cut out even Better!!
HakbarSAABzzz
Harvey's Autohaus is offline
Old 05-06-2009, 03:00 PM   #3
Nick Taliaferro
They were powder coating that black anyway. Sure beats spray paint. In a few minutes it is ready to run. Only has to cool off.
Yep that was the weekend before lasts gearbox Tried a little too hard on stock diff.
Nicholas Taliaferro
Old 05-06-2009, 03:21 PM   #4
So thats a pic of the box that "Ventalated" All that torque and Hp to Atmosphere? The DIFFpurgeBLoW off Valve? Just Kidding NICE Piece Again.
HakbarSAABzzz
Old 05-06-2009, 05:26 PM   #5
Sleepy7666's Avatar
Looks nice. Is it autotragic compatible? Christian may need it.
I lurk.
99 and 01 Saab 9-3
96 Escort LX
83 Yamaha XJ650 Maxim
Sleepy7666 is offline
Old 05-06-2009, 10:01 PM   #6
NahumCC's Avatar
Nick, what is in the work for the engine side mount for cars that don't have the A/C delete to avoid breaking that single bolt again?
2013 FR-S
NahumCC is offline
Old 05-07-2009, 02:40 AM   #7
mvadenais's Avatar
nice fabrication
88 900 SPG Black
95 9000 Aero Green
00 9-3 Viggen Silver
mvadenais is offline
Old 05-07-2009, 03:09 AM   #8
mcrowley's Avatar
Excellent.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 05-07-2009, 05:59 AM   #9
Nick Taliaferro
We are still on the single bolt engine mount. It is not a problem unless it comes loose (Cure: loctite) or is over tightened (Torque to factory spec) Until you get into this sort of level but you cant get close to the grip necessary on the road with street tires. If you let it wheel hop then all bets are off.
Nicholas Taliaferro
Old 05-07-2009, 10:03 AM   #10
Makeyousaab's Avatar
i really like this.
~Dave
Makeyousaab is offline
Old 05-07-2009, 10:05 AM   #11
srp
srp's Avatar
Send a message via AIM to srp
This would go perfect with a short shifter... *hint*hint*
srp is offline
Old 05-07-2009, 11:30 AM   #12
Nick Taliaferro
It is the next part. Got some new poly to go in the catalog too. The prototypes seem to be working great now.
Nicholas Taliaferro
Old 05-07-2009, 03:24 PM   #13
srp
srp's Avatar
Are you going to be offering this trans mount bracket in the catalog? Or simply as an as needed basis for those super high output cars?
In other words, is there a need for it in say a stage 3/4 car?
srp is offline
Old 05-07-2009, 03:55 PM   #14
christian900se's Avatar
hehe, it wont be the same as the manual transmission. Plus, it may be good to have a bit more flex and movement to lessen sudden jerks movements.
christian900se is offline
Old 03-31-2010, 08:39 AM   #15
Sleepy7666's Avatar
Wait a second... Couldn't Palmer's old car benefit from one of these? These available?
I lurk.
99 and 01 Saab 9-3
96 Escort LX
Old 03-31-2010, 08:54 AM   #16
Castor Troy's Avatar
no. the engine mount bracket was the mount that automotion modified/ruined, not the trans mount bracket
Castor Troy is offline
Old 03-31-2010, 09:20 AM   #17
Sleepy7666's Avatar
O duh. *Self Facepalm*
I lurk.
99 and 01 Saab 9-3
96 Escort LX
Old 04-02-2010, 02:24 PM   #18
Nick, why didn't you ever put these or the beefier passenger brackets into production?
~Dave
Old 04-02-2010, 02:45 PM   #19
dave del's Avatar
I've been wondering why too
01' 9-3 jzw stage 4 track car
slammed 87' c900
24v 87' e30
dave del is offline
Old 04-02-2010, 03:45 PM   #20
Probably demand and time of production, I mean unless you are running killer power there's no point to upgrading. Good question though... hopefully we'll get the answer.
tucksayre is offline
