Piston Options - The Saab Link Forums
Old 03-24-2005, 06:16 AM   #1
Piston Options
Does anyone have any +/- to either of these or am I going to be happy either way. Also are there any other options out there for the 2.3 t7. The time is nearing where I dump some large amounts of $ into my baby. The JE and Maptun forged pistons are the only ones I have found.
lemonscu is offline
Old 03-24-2005, 01:15 PM   #2
I would go with the dished pistons as the stock pistons have a dish.
Also, maybe you can call up Mahle and see if they have any "box-in-box" pistons for Saabs like they do for WRX's. They won't sell them directly to you, but maybe they know the name of a distributor?
SaabTuner is offline
Old 03-24-2005, 01:37 PM   #3
Administrator
Boxerchip's Avatar
I would go with maptun simply because they seem to know what they are doing and have been at it for years... JE im sure has less expireance with saabs.
1998 BMW M3-ECU, intake, tein coils w/ pillow ball uppers, sway bars, W7 w/ 1000 watt JL, short shift, DSSR, uuc exhaust, BBS CH 18s.
2001 Audi S4-Sold
1999 STAGE III VIGGEN-Sold
2000 9-3-Sold
1992 900S- Sold
Boxerchip is offline
Old 03-24-2005, 02:34 PM   #4
When it come does to it, a engine is a enginel, Saab or not. If you go though maptun your going to be chared a ton of money. The JE psitons are good. You can go to any performance shop here in the US and ask what type of pistons are good for a 2.0 turbo engine and they will give you a anwser. Also different pistons heads are going to offer a advantage over others, and some or better for different applactions. Call up JE.
snow4_1man is offline
Old 03-24-2005, 02:39 PM   #5
DeLorean's Avatar
well what is the need for upgrading the pistons?
DeLorean is offline
Old 03-24-2005, 02:47 PM   #6
Ive heard the pistons are good for 300hp max. After a long discussion with a my mechanic we decided that forged pistons had 0 negatives and would be worth the $. Im going to get the nordic stg 3 package soon but do not want to stay there forever so pistons would be a good thing to get out of the way. From there its a turbo, tranni, injectors and a reflash I think. Im just trying to play it safe.
lemonscu is offline
Old 03-24-2005, 03:01 PM   #7
DeLorean's Avatar
did the person selling the pistons tell you this? Saab uses Mahle pistons, people actually use these as upgrades for non turbo cars that are being converted to turbo. The ONLY conditions where I have ever seen one of these fail is under constant massive lean out (bad injector, running WAY too much boost all the time with not enough fuel) As Paul H and I can tell you, the stock pistons can take massive lean out shots where the fuel shuts down, you hear a bang and may get a backfire, and you are still at 20+ PSI while this happens. The ECU then turns your fuel back on, your boost is now at a more normal level and away you go!
A piston upgrade for me is on the list WAY behind a erricson 4 speed dog box, and quite honestly, neither one is ever going to make the top of the list while I own the car...
DeLorean is offline
Old 03-24-2005, 03:03 PM   #8
PaulH's Avatar
dude you have no idea what kind of car he has do you?
hes got one of those self destructing dainty pistoned viggens .
Paul
PaulH is offline
Old 03-24-2005, 03:04 PM   #9
DeLorean's Avatar
oh, a viggen? that's another matter.... yeah upgrade those
DeLorean is offline
Old 03-24-2005, 03:11 PM   #10
Hes just an indy mechanic. He races sprint cars which makes him which makes him a firm believer that forged pistons are the only way to go(850hp, you know). But he has worked on Saabs/ Volvos for a long time. I have heard a number of horror stories about Viggens cracking pistons. The 99s were different than 00-02(im sure you know) but I dont want to blow up the motor. The t7 2.3 has Mahle pistons? If you really think this is a waste of $ let me know. From my research(forums) I thought this was needed past stg 3.
lemonscu is offline
Old 03-24-2005, 03:17 PM   #11
DeLorean's Avatar
I would do some research on those pistons before you upgrade. the 99-00 viggens should be upgraded because it's just a well known fact that they have weak light weight pistons. I don't know about the later ones, but I might question their integrity as well. with C-900's a piston upgrade is just not something that ever has to be discussed because they just don't fail almost no matter what you do to them.
DeLorean is offline
Old 03-24-2005, 03:17 PM   #12
ya take his advice, The T5 pistons are good for about 450, and the valves in the head are good for about 600hp. The viggen are are week, not a bed idea to get them out of the way. If you going to do a new stage past the stage 3, on your viggen, then do a worth while upgrade. like 350hp to the wheels.
Old 03-24-2005, 03:20 PM   #13
See, I didnt think I was off base. Last think I want to do is dump a bunch of cash into my car only to blow it up. Thanks for the replies.
lemonscu is offline
Old 03-24-2005, 03:23 PM   #14
JE seems to have an excelent reputation i would go with them. i assume that you are going to bore out the engine.
turbokick is offline
Old 03-24-2005, 04:01 PM   #15
He would not need to rebore out the engine as long as there is no damage to his block. Assumng the pistions that he gets are going to be the same size. If anything just rehone, but there is no need if there is no scoring on the side of the walls. If you compression right now is ok, and you don't have a lot of miles on the car, don't worre about it.
Old 03-24-2005, 08:58 PM   #16
The MapTun pistons are JE pistons ... just custom made to MapTun's specs IIRC.
Old 03-25-2005, 05:56 AM   #17
Trollerator
abdukted1456's Avatar
no, I think maptun used to sell JE now it looks like they are Wössner
"Maptun are now able to deliver forged pistons of the absolute highest quality! As exclusive Swedish agent for German Wössner High Performance Pistons, we offer the perfect alternative for ultra high power output in Trionic 7 cars (both 2.0 and 2.3 litre models) Wössner Pistons supplies BMW Challenge Factory Team as well as special manufacturing for Porsche GmbH. Needless to say, this is the ultimate in forged pistons. These pistons have been tested in 450+ hp Saab 9-5 applications with excellent results. "
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 03-25-2005, 06:04 AM   #18
Nick Taliaferro
GenuineSaab's Avatar
To get JE pistons you have to pull one and send it to them, along with some other info too. Basically they are functionally a copy except in this case we have modified the ring package. Same compression etc... Nordic uses JE pistons. These are the pistons we wil be using in my Viggen and also in Ed Smiths 2.5l monster motor. Maptun uses Wössner pistons.
Nicholas Taliaferro
GenuineSaab is offline
Old 03-25-2005, 06:11 AM   #19
When are these going in? Not that I think there will be a problem but you have taken it upon yourself to try out everything first(thanks by the way) that it would be nice to hear first hand reports and problems if any.
lemonscu is offline
Old 03-25-2005, 09:11 AM   #20
Nick Taliaferro
I believe ed has his engine together, It was a bit tricky since it is 2.5L with big bore, we had to use a 2.1 c900 head gasket. I have test fit my pistons in a spare block, Have been to busy to tear the Vig apart yet.
Nicholas Taliaferro
