Let the games begin :) - The Saab Link Forums
Old 10-26-2008, 08:57 AM   #1
Phase 1 complete of the planned winter upgrades to my car, out with the old and in with the new
http://www.stcf.net/viggen/Holset/asennus/
So basically everying else from air filter to catalyst where exchaged besides the engine it self. Dp from 3.5" stuff and compressor intake from 4" stuff.
Did not have much time to test it yet but here is a few graphs. Spool comapred to previous
http://www.stcf.net/viggen/holset_vs_getari21.gif
remained the same. Have my Holset with #16 turbine housing and aim is more in the high rpm power than low spool, and the aim was not to have it worse than what is was with 3071.
Performance with base mapping 100-200 8.7s with 1.3bar boost.
100-200 l8.3s with 1.5bar and 100-150 3.1s.
Power output
http://www.stcf.net/viggen/holv1.gif
The super40 likes to be run with higher boost (compressor efficiency is better at PR 3+) and will incrase boost from here on, but until the fuel side is upgraded (phase II) I dont have much play room to go with.
Anyways I very please with the preliminary results and if the car did not sound "mean" in the past, it surely now does (will make a film later.)
Vigge is offline
Old 10-26-2008, 09:01 AM   #2
tophusmaximus's Avatar
nice pushin 500 bhp, cant wait to hear what it sounds like!
none of you can talk/function with dicks in your mouths.
Amateurs.
2000 9tree
tophusmaximus is offline
Old 10-26-2008, 09:07 AM   #3
Jokke A's Avatar
Looking good, as usually with this car.
+ few bicycles
Jokke A is offline
Old 10-26-2008, 09:42 AM   #4
Deez Nutz
Palmer's Avatar
Wow.
Awesome.
This is a good motivator!
S55/LC100/KL
Palmer is offline
Old 10-26-2008, 10:06 AM   #5
Legit's Avatar
That turbo could swallow that DI cassette
2002 Viggen Convertible
Legit is offline
Old 10-26-2008, 11:48 AM   #6
JZW
Power output
Wow, you already have it running So, it looks like the Holset meets up a little higher in the rpm, but might be a hair slower on spool below 3500rpm or so in the one data group and then about 5500rpm in the 3rd gear torque pulls and then it shows where the .86ar was starting to fall off, the Holset was actually starting to go up in pressure
Get some video eh...
John
JZW is offline
Old 10-26-2008, 12:24 PM   #7
User
zingZACH's Avatar
I want I can't wait to see videos!
1988 900 Springtime in Sweden
zingZACH is offline
Old 10-26-2008, 12:53 PM   #8
Deez Nutz
Palmer's Avatar
How does the section from the compressor side to the intercooler look?
Those stupid AC lines are in JUST the wrong spot. I can only imagine how the fit of that is under there. It's really tight with my GT30.
S55/LC100/KL
Palmer is offline
Old 10-26-2008, 12:59 PM   #9
its straight and simple, 90deg silicone bend from compresso, then a section of almost straight pipe and then a 90 deg silicone bend which outlet you see in the pics, which connect to the IC inlet pipe. In other words the outlet of the compressor is not too far a way from std position from which the routing to IC takes the same path.
Vigge is offline
Old 10-26-2008, 01:02 PM   #10
Deez Nutz
Palmer's Avatar
Ah, gotcha.
That 90 off the compressor is part of the reason I'm going top-mount. I'm pretty sure mine is a restriction.
Also, I like the welded pipe off the intercooler.
S55/LC100/KL
Palmer is offline
Old 10-26-2008, 01:11 PM   #11
drewz airflow se's Avatar
That down pipe is huge.
^CLICK ME^
drewz airflow se is offline
Old 10-26-2008, 06:57 PM   #12
comtrang's Avatar
You could fit a 2 year old inside of that intake.
Looks nice.
Glad someone finally has put up a walkthrough of their own Holset setup. I'm sure many people will come back to this in the future - myself included.
Daily Driven '00 Saab 9-3
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Old 10-27-2008, 12:27 AM   #13
well planned is half done Drove the car in the garage saturday morning with previous set-up and out with the new the same night. It surely was a long day, but well worth every needed sweat drop.
Vigge is offline
Old 10-27-2008, 12:55 AM   #14
Ah, gotcha.
If I look at my previous top mount set-up, the bottom half of compressor to IC pipe takes the same path as now. The top half was just a vertical pipe down from compressor.
Filter to compressor was almost a straight pipe (~3") with that set-up , now a 4" pipe with a smooth 90deg bend in the bottom just before the compressor, which in terms of flow should be just perfrect.
http://www.stcf.net/viggen/Holset/as...s/image15.html
Did the IC pipes welded style in order to suppor higher boost for future needs. All other seems with silicone have been equipped with larger collars to prevent pipes from comming loose.
Vigge is offline
Old 10-27-2008, 01:31 PM   #15
Here is a video of a few test runs in 3rd gear, in 1st wot from ~100km/h and in 2nd from 110km/h
http://www.stcf.net/viggen/testing.wmv
seems though that the "acustics" of the car was too much for the mobile phone mic to handle
Vigge is offline
Old 10-27-2008, 01:37 PM   #16
Deez Nutz
Palmer's Avatar
Damn, that's impressive.
S55/LC100/KL
Palmer is offline
Old 10-27-2008, 02:29 PM   #17
JZW
That sounds very mean, be careful running that thang with the coolant temp so low and the tack running 0 and the boost gage reading 0, the car does not like that
So, screw all the data, how does it feel???
Is that you're garage/shop? Is that you tig welding or you're buddy?
John
JZW is offline
Old 10-27-2008, 02:45 PM   #18
John
Feels great to be honest, very agressive when you give it wot. Best part is that there is plenty of pontential to play with and with the current 1.5bar its more or less pushing like the 3071 set-up on average when taken "beyond" its capasity. Ofcourse only time will tell what the set-up has to offer but I'm optimistic that there is "plenty" left in it. Depends on how long the fuel side will support me if I will throw it on the dyno or not, but as usual road before the "show", i.e. if fueling is not enough to bring more "go" on the road the dyno will need to wait until that is taken care of.
The guy who is welding has a small company which produces custom hw for cars to and have used his services for the past years (last set-up was built there also), like many other saab enthusiast in this country. Pricing is resonable, guy is pro in welding and has all the needed tools for this kind of jobs. Just look at the pic, DP being welded with backing gas, dont see that often and seems more than perfect.
Vigge is offline
Old 10-29-2008, 07:59 AM   #19
JZW
Want to see if he wants to make me a manifold just like you'res That and how much and how much to ship to the good ol USA
thanks,
John
JZW is offline
Old 10-29-2008, 11:21 AM   #20
comtrang's Avatar
thanks,
John
I almost asked him the same question yesterday, but I thought it seemed out of the question.
I'd definitely be 100% interested, though, if yours is working out well, Vigge.
Bone stock
SOLD '97 Saab 900SE
Stock 2.0
Holset HX35
-Branden
comtrang is offline
Tags
bigger boat, holset
