do they make front anti roll bars? - The Saab Link Forums
Old 01-04-2004, 10:42 AM   #1
Administrator
Boxerchip's Avatar
if so where can i get one?
Boxerchip is offline
Old 01-04-2004, 06:33 PM   #2
WS
WS's Avatar
Send a message via AIM to WS
i dont think so....i think they only make front strut tower bars. I know the viggen comes with one...a lot of cars do
2000 Saab 9-3 Viggen Sedan
-Silver
-20% Tint
-BSR Cat-Back and Intake
WS is offline
Old 01-04-2004, 08:11 PM   #3
Administrator
Boxerchip's Avatar
Old 01-05-2004, 12:59 PM   #4
Maarten's Avatar
Why do you want to change your front anti-rollbar?
Are you going to replace it with a stiffer or weaker item?
Maarten is offline
Old 01-05-2004, 01:29 PM   #5
Administrator
Boxerchip's Avatar
stiffer... i did the rear one and it made SUCH a huge difference so if they made somthing like that for the front... i figured why not?
Old 01-05-2004, 02:14 PM   #6
Maarten's Avatar
I would not recommend stiffer front anti-rollbars to improve handling. It will probably get worse instead.
For the Viggen SAAB used a softer front anti-rollbar to reduce oversteer. Hirsch Performance does the same on their tuned SAAB's. The idea behind this is that a very stiff rear anti-rollbar can cause oversteer when cornering at very high speeds.
This thread on Saabscene might be interesting if you want to know more about front/rear anti-rollbars.
Maarten is offline
Old 01-05-2004, 03:34 PM   #7
Administrator
Boxerchip's Avatar
oh hot ok thanks!
we need more people as helpful as you here
Old 01-05-2004, 03:54 PM   #8
Administrator
Boxerchip's Avatar
so what i want is a viggen front brace... but where can i get one?
Old 01-05-2004, 04:20 PM   #9
Maarten's Avatar
What problem are you trying to solve by fitting Viggen spec anti-rollbars?
You've already fitted the uprated rear anti-rollbar. If there's still too much bodyroll, try stiffer springs and shocks first. Eibach progressive springs in conjunction with Koni adjustable shocks will improve handling a lot.
If oversteer is the problem, get some sticky tires. Bridgestone S03's are very good.
Please post a list of mods done to your car. It will be easier to find a solution if we know the exact specs of your SAAB.
Maarten is offline
Old 01-05-2004, 04:25 PM   #10
Administrator
Boxerchip's Avatar
as of now i have eibach springs, konis, stage 2 anti roll, forge BOV, intake/heat sheld. The problem is one the tires... first of all the SUCK... anytime i floor it in 1st even if its towards the end it spinns im sure this is a commen problem but i would still like to atleast make it better. as far as the front anti roll bar i just saw/felt the difference the rear one made and figued if i could do the same with the front it would kick ass. im always looking for ways to make my car handel tighter.
Old 01-05-2004, 04:37 PM   #11
Maarten's Avatar
Originally Posted by Boxerchip
I'm always looking for ways to make my car handle tighter.
For tighter handling, you might try the MP Performance clamp and brace. It's the same idea as the VRK by Abbott or the KIC unit, but not as expensive.
BTW the mods you've already done are very nice
Maarten is offline
Old 01-05-2004, 04:40 PM   #12
Administrator
Boxerchip's Avatar
yeah i have seen abbots and the one from ginuinsaab.... where is this one? and are there any benfits to the more expensive ones?
I like to do things right... note the konis and eibachs i would rather wait till i get the money than get a cheeper solution.
Old 01-05-2004, 04:40 PM   #13
Maarten's Avatar
oh, and before you're going to ask: "Where can I get one?", here's the link toMP Performance
Maarten is offline
Old 01-05-2004, 04:42 PM   #14
Maarten's Avatar
Duh.........you already beat me to it
Maarten is offline
Old 01-05-2004, 04:43 PM   #15
Administrator
Boxerchip's Avatar
ahhhahahaha victory is mine!!!!! I beet ya to it!!!
Old 01-05-2004, 08:40 PM   #16
Dont forget about the little guys! The bushings. upgrading those will also increase your handeling without changing the anti roll or sway bars
TK900SE is offline
Old 01-06-2004, 06:00 PM   #17
Chip, you have a 9-3 SE right? if so, you should have a 24mm sway bar up front, the Viggen's is only 22mm.
3 cheers for poly bushings, stay tuned for some pics.
