Turbo heat shield - The Saab Link Forums
Old 09-26-2008, 05:50 AM   #1
MONSTAMUNCH's Avatar
Turbo heat shield
Is it worth just removing the turbo heat shield? Thought it would be better cause then the fan can blow a bi t more air onto the turbo and head. Then i thought that maybe it will cause more heat on the piping? The temps here get up to 32 degrees celsius.
Ex 2000 VIGGEN [email protected]
2006 93 2.8T AERO auto [email protected]
MONSTAMUNCH is offline
Old 09-26-2008, 06:27 AM   #2
Nick Taliaferro
GenuineSaab's Avatar
Very bad idea to remove it.. Important part.. You want to keep the radiant heat down or you will start burning stuff.
Nicholas Taliaferro
GenuineSaab is offline
Old 09-26-2008, 06:28 AM   #3
Elmo's Avatar
Send a message via AIM to Elmo
correct me if i'm wrong, but i believe the heat sheild helps keep cold air off the turbo, as well as keeping the heat contained from the rest of the engine. if cool enough air were to reach the spooling hot turbo, it could crack do to the rapid temperature change on the metal. same reasoning behind why you should sit and let turbo'd cars idle for a minute before shutting the engine off.
correct?
Elmo is offline
Old 09-26-2008, 06:38 AM   #4
liketheword's Avatar
Heat retention and heat flow control are both very critical in a turbo car. Keep the part. If anything paint it w/ high heat paint.
Vitamin SAAB
liketheword is offline
Old 09-26-2008, 06:51 AM   #5
srp
srp's Avatar
Send a message via AIM to srp
My NG doesn't have a heat sheild
srp is offline
Old 09-26-2008, 07:11 AM   #6
mcrowley's Avatar
x2
Neither does my 900 (or 9000 for that matter).
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 09-26-2008, 07:14 AM   #7
my heat shield has been gone for over a year I think...
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 09-26-2008, 07:24 AM   #8
Marks9-3's Avatar
This is mostly due to the fact that the turbos lifeline is oil. You turn the car off and its source is cut off. You want to idle for a minute to let the trubo spool down to as slow as it can while at idle.
The air hitting the turbo isnt drastic enough to crack it. If the air hitting the turbo was able to hit it all at once from nothing and be very cold, maybe. The heat shield is more to contain the heat from all the other vital parts in the engine bay. ie rubber hoses and vacuum hose.
Marks9-3 is offline
Old 09-26-2008, 08:06 AM   #9
Elmo's Avatar
ah... i see, thanks for clearing things up
Elmo is offline
