While we are on the topic of the downpipe. I had one custom made, the only issue i have is that the nuts onto the turbo keep coming loose i assume because of the heat and the shaking. Anyone else experience this? Think i might need to use some locktite, or any other suggestions?
As far as the hangers go, can u not cut them off and re weld them further down or up? I suppose it is a bit of a mission though.
While we are on the topic of the downpipe. I had one custom made, the only issue I have is that the nuts onto the turbo keep coming loose i assume because of the heat and the shaking. Anyone else experience this? Think i might need to use some locktite, or any other suggestions?
my jt system doesnt fit all that well tbh but perfors great and is much better value than all the other options available in the uk.
as for the nuts coming loose, use a washer and then 2 nuts on each stud, holds the dp better and 2 nuts wont come loose.
My JT 3" dp, when bolted to the turbo, DOES NOT fit and reach the hangers. I do not use the hangers.
26.9K members
