My '99 9-3 SE:
B204L w/ T25 and shitty Intercooler.
185 hp stock.
Before I go any Farther, I owe a huge thanks to Rob (SPG-GASM) and the wonderful people, Marty & Annette, for allowing me to use their shop.
So it began when I needed to replace the timing chain.. it was making far too much noise for our comfort. Rob and I got to talking and a couple weeks later, this is where we are: engine is out of the car and we are working on the rebuild.
The List:
This is everything I had done previous to this summer.
MP Short Throw Shifter
MBC
GS rear sway bar
GS Engine Mount
GS Trans Mount
2.5" custom cat back (magnaflow muffler/cat) Viggen look-a-like tip.
Blitz Blow Off Valve
2.5" Custom Cold Air Intake
2 Months ago she got all this:
GS Poly Bushes (all)
Quaife LSD (Thanks Dad!)
Spec Clutch (stg 2)
Spec Lightweight Flywheel
Now In Progress: "-" designates its completion
-Replaced all Timing
-Balance Shaft Delete
-New Water Pump
-New Crank Position Sensor
-Upgraded Valve Springs
-All seals replaced except the oil pump seals and the dipstick tube seal.
-Painted Block Red
-Painted coolant/oil lines 'Aluminum'
-Painted all Brackets 'Aluminum'
-Cleaned everything
New Headgasket
3" JT Exhaust painted with POR-20 (1 Muffler, 0 Cat)
GS slotted Rotors front and rear
Hawk HPS pads- front
Ceramic pads- rear
New Intercooler & 2.5" Delivery Pipe from I/C to Throttle Body
coming soon:
Koni Sport Kit-- as soon as I get it from GS
Suspension Bearings f/r
T5 Suite-- I can has on-the-fly tuning?!!
Coming later- spring time most likely:
bigger turbo:
TD04 #6/Big T28
Holset?-- i think not.
The non performance list:
Previous to this summer.
Little Griffin Stickers (best mod evar!!)
Infinity Kappa 6.5" Front Doors
Infinity Reference 6x9" Rear 'Deck'
^powered by Sony Amp 125x2 rms
XM radio- Custom Install
2 Gauge A-Pillar Pod
^AutoMeter Ultra Lite Boost/Vac Gauge
^AutoMeter Ultra Lite Air/Fuel Gauge
Smoked Side Markers
Smoked Headlights
Fogs replaced with non-saab ones, I broke the tabs off somehow
In Progress:
12" Sub in the hatch (still deciding which one to get)
^powered by sony Amp- 2 ch. running at 360x1
New Sony Head Unit
ProSport Gauges
-Water Temp
-Boost/Vac
-EGT
-Oil Pressure
JAW Wideband A/F
Coming sometime (I hope):
Viggen Seats mmmmmmhmm
Wheels/Tires:
Summer:
Borbet 17" wheels Type CA (gumby look-a-like wheels)
BFGoodrich G-Force Sport (215/45/17)
Winter:
Saab 16" Viking Wheels
Dunlop SP Winter Sport 3D (205/55/16)
p.s. this is a teaser--- pics tonight- lots of pics.
185 hp stock.
The List:
MBC
GS rear sway bar
GS Engine Mount
GS Trans Mount
Spec Clutch (stg 2)
-New Water Pump
-Painted Block Red
-Cleaned everything
New Headgasket
Ceramic pads- rear
coming soon:
bigger turbo:
TD04 #6/Big T28
Smoked Side Markers
Smoked Headlights
In Progress:
New Sony Head Unit
ProSport Gauges
-Water Temp
-Boost/Vac
-EGT
-Oil Pressure
JAW Wideband A/F
Wheels/Tires:
Summer:
Winter:
