LinkBack | Thread Tools |
#1 |
I just picked up a full set of 02 9-5 Areo rear brakes and was wondering a few things; (My car 99 9-3 SE HOT)
1. Are these a dircet bolt on?? Is there any other parts I would need to install these? 2. Will my set of goodridge steel braided brake lines work with these brakes? 3. What kind of brake fluid should I use and where can I get it?? 4. Will there be any issues with the E-brake?? Correct me if I'm wrong, doesnt the 99 9-3 SE have a drum set up for its E-brake?? 5. How much fluid will I need?? Will 1 liter do it? Thanks!!
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” Last edited by Passenger 57; 08-07-2008 at 01:34 PM. Reason: had another question |
Sponsored Links | |||
#2 |
You will need these lines...
http://www.genuinesaab.com/catalog/p...roducts_id=282 |
#3 |
you would be best to get the above lines although ive just used the original steel pipes for now.
you will need to trim the rear backing plate and alter the plate that takes the handbrake release spring. brake fluid is a personal choice for many but my fave is millers racing 300. |
#4 |
I don't know that I would keep the steel lines..
They work fine with the standard fixed caliper design... But the Aero brakes make use of a floating caliper.. Not sure if I'd want to put that stress on those lines. |
#5 | ||
You will need brake pads too.
Stainless lines from Goodrich work with them. You will need the flexi stainless lines Nick sells. You will need to cut the stock dust shields. You will need the larger rotors.
#6 |
Thanks for the help guys!! I'll pick up a set of those GS lines.
Anybody want a pair of rear SS brake lines?
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.” |
#7 | |
Nick Taliaferro
Nicholas Taliaferro To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. | To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts. 2.0 GOOSE 500whp + 8500rpm = 11.06 @125 E85 Viggen 439whp / 447tq 12.43 @114 on Gt2871.64, (Now 511whp Gt3076) Nordic E85 9-3 SS Aero 320hp / 350ftlbs |
#8 |
Those stainless lines go from the "frame rail" to the rear axle. Nick's teflon coated stainless lines go from the rear axle to the caliper.
#9 |
6 lines!!??
Ok let me get this straight, check out the pic ![]() So the goodridge line replaces the line in the yellow circle, correct??? The GS line replaces the line in the red circle??? Is that right?? Thanks to Dip for the great pics.
#10 |
You got it!
#11 |
Word!!
#12 | |
From where again what what!
#13 |
Thank you Aaron for the brakes...
#14 |
115lbs is what they weighed. in the box hahah feel sorry for your ups driver.
#15 |
115 is a typo, right?
Or is that for all four calipers, pads and rotors? |
#16 |
thats everything, fronts & rears
#17 |
I don't know that the front calipers will bolt up, but it's worth trying....
You can always sell them and recoup some of the outlay. ....and the GS brake lines are essential for doing this the right way. I flared my existing brake lines and made them fit, but I was never happy with that. In the end, $60 is cheap money for peace of mind. |
#18 |
#19 |
Bump... had another question
#20 |
Yes it is a drum... But it uses the hat of the rotor for the drum.
No modification neccesary for the e-brake. |
Sponsored Links | |
Thread Tools | |
