Different exhaust - The Saab Link Forums
Old 02-03-2005, 08:42 AM   #1
Coops93's Avatar
Different exhaust
I am trying to decide between MP performance's Downpipe with the 3" jt system on genuine saab, or just go with the whole jt 3" system from genuine saab? i like the sound of my friends 3" JT exhaust on his 9000, its kinda quite not too loud. anyone have sudgestions on either of those set ups?
Coop
99 9-3 Dark Green 2.0t
Coops93 is offline
Old 02-03-2005, 09:07 AM   #2
You may also want to look at the Saab Savior system - I have the cat-back and am very happy with the sound and performance, although I can't give you a hard number.
Q-SAAB is offline
Old 02-03-2005, 10:23 AM   #3
stevehayes01's Avatar
Why not go for a custom 3" system with the MP downpipe? I have always used 3" custom tube with a Magnaflow 3 chamber on all my other cars that were turbcharged and the sound is some what like a V-6 Camaro (burble wise) and only gets noticeable under full acceleration. I have seen the MP downpipe and they are very nice quality so I don't think you can go wrong there.
stevehayes01 is offline
Old 02-03-2005, 10:54 AM   #4
VAGGEN's Avatar
Jak Stoll makes a nice 3" DP too.
VAGGEN is offline
Old 02-03-2005, 11:34 AM   #5
What kind of car is it going on??? If you are pre OBDII I wuold go with a catless DP as well and have a flanged cat made to put in for smog inspections.
Old 02-03-2005, 05:04 PM   #6
Coops93's Avatar
It would be going on a 1999 9-3. Wasn't looking for a american kinda noise. Think i may just go with the JT 3" system and have a cat weilded into it, it cost almost 400 bucks for the JT to come with a cat.
Coop
Coops93 is offline
Old 02-03-2005, 05:27 PM   #7
iwantaviggen's Avatar
i have the JT on mine and its good the one thing it has that MPs doesnt is the flex piece...but i dont think its needed if its made for an exact fit.... its your choice...i got my JT before MP even came out i think...but if i was getting one now i'd up for MP less expensive one... MPs also looks to have more subtle curves....were as JT has more to restrict....but i'm sure they both did their home work and know what they are doing.....
the choice is yours!
haha
iwantaviggen is offline
Old 02-03-2005, 05:50 PM   #8
I have a JT Full Exhaust. I also bought mine before MP came out with thereís. MP DP has better bends as the JT has 2 smooth bends with MP only has one smooth curve. There is going to be flexing in any pipe on your on your car, I like MP DP better then the JT but I donít know if I would sacrifice the flex pipe. Cedric's flex pipe was cracked because of to much movement, and he is getting it replaced for free. But that just goes to show that you need some leeway.
Also i have seen Jak Stoll makes a nice 3" DP, looks exactly the same as MP, no Flex pipe.
Both are very good products, just what is your preference. Flex or no Flex.
Dan
snow4_1man is offline
Old 02-03-2005, 08:12 PM   #9
Coops93's Avatar
what company does Jak Stoll make the DP's for? this is the second time his name has poped up on this thread.
Coop
Coops93 is offline
Old 02-03-2005, 08:39 PM   #10
he makes them for his own company.. out of his backyard http://www.jakstollperformance.com/
ricot83 is offline
Old 02-04-2005, 05:30 AM   #11
VAGGEN's Avatar
Jak's is aluminized steel, while MP's is stainless. They use different brands of cats too, I think.
Mine is on order from Jak, I will let you know what I think of it when I get it. Hope to take some pics of the install as well.
VAGGEN is offline
Old 02-04-2005, 05:52 AM   #12
Trollerator
abdukted1456's Avatar
can someone tell the dumbass what the flex pipe is for/what is does? (me)
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 02-04-2005, 06:22 AM   #13
flex pipe is hte pipe after the dp and before the catback section,.... it has a flex section in it which is why it is called flex pipe..... otherwise known as an intermediate pipe.. or center exhaust section
ricot83 is offline
Old 02-04-2005, 06:29 AM   #14
Trollerator
that much I assumed. But why does it need to flex is my silly question?
obviously it needs to, or it would not be there, but why is what i am asking?
and why would some systems leave it out of the equation?
1990 900 turbo vert
2004 9-5 aero sedan
Old 02-04-2005, 07:07 AM   #15
with the movement of the engine, it will eliminate any chance of breaking exhaust connections
ricot83 is offline
Old 02-04-2005, 07:13 AM   #16
Trollerator
thank you. so it is best practice to get a system with flex pipe then. if not there is a heightened risk of breakage...
1990 900 turbo vert
2004 9-5 aero sedan
Old 02-04-2005, 08:56 AM   #17
I would defiantly say yes. Think of how much your engine moves just at idle when you step on the gas. Then your exhaust pipes are connecting to your turbo and all these pipes and so forth are moving as well. Itís very wise to get a flex pipe, in-between the cat and DP, this would allow for a more leak free exhaust also, because youíre not having the straight pipes bend.
If you have an Engine mount on your car, this would prevent the engine from moving too much then not letting the pipes bend. But there is still going to be some movement, my dad has a flex pipe on him 9k JT full exhaust and that car come built with an engine mount. I would say itís a healthy idea.
Old 02-04-2005, 09:09 AM   #18
Trollerator
thanks. i will probably end up with a full 3" JT plus DP anyways if I stay with Maptun for my stage 3. that way I can get their discount for upgrading stages. now you have to buy the hardware from them in order to get the stage remap discount. makes sense, I guess... I think they want to be sure you are using the same HW they use for staged packages, so if there is a problem because you used a custom part, you can't blame them if the SW does not match up exactly.
1990 900 turbo vert
2004 9-5 aero sedan
