Short-Belt time? - The Saab Link Forums
Old 02-03-2005, 08:31 AM   #1
Short-Belt time?
I happened to be running my engine with the hood open noticed a humming noise coming from the area of my serpentine belt - My assumption is that I've got a noisy idler pulley (at least that's my hope, since everything else on that belt is expensive to replace).
Should I just replace both idlers and be done with it, or should I replace only one, and remove the lower pulley entirely?
I'd plan to replace the belt in any event.
Does the short-belt mod have any benefit at all?
Open to ideas, suggestions and recommendations.
Q-SAAB is offline
Old 02-03-2005, 09:06 AM   #2
stevehayes01's Avatar
I would do the short belt mod if you are looking to save money. I am not sure of what benefit it has other than possibly less drag on the pulleys and maybe less of a drain on the car. Try replacing the belt first as it may not be a bad pulley at all but possibly just a bad belt that makes noise.
stevehayes01 is offline
Old 02-03-2005, 09:33 AM   #3
i dont think the newer t7 can do the short belt
ricot83 is offline
Old 02-03-2005, 10:27 AM   #4
Sorry, forgot to mention - '97 900 SE Turbo
Q-SAAB is offline
Old 02-03-2005, 11:01 AM   #5
rcmdesign's Avatar
Yeah I saw that short belt mod on this site http://pages.infinit.net/mlbriand/sa...elt/page1.html
I wondered if there was any benefit engine wise for this mod...Probably too little to register on a dyno...
Rob
Swedish Performance
rcmdesign is offline
Old 02-03-2005, 12:20 PM   #6
SaabScott's Avatar
Send a message via MSN to SaabScott
Just one question ... where do you get the belts from?
Is there a Saab parts place that sells them?
I would hate to have the belt off the car only to find the short belt is the wrong one.
SaabScott is offline
Old 02-03-2005, 12:26 PM   #7
I was under the impression that later models did not even use the lower pulley, in which case we should be able to use a standard SAAB belt, right?
Q-SAAB is offline
Old 02-03-2005, 12:28 PM   #8
Forgetting the pulleys for a second. I just want to mention my car used to make a horrible grinding noise. Many people thought it was the steering pump, but it turned out to be the AC motor.
I got an AC delete belt from the U.K. and the problem has been cheaply resolved.
Old 02-03-2005, 12:44 PM   #9
TWEEK!
A/C issues? GACK!
Q-SAAB is offline
Old 02-12-2005, 10:41 AM   #10
Took another closer look today - the lower pulley seems to be the problem - I can see it wobbling as the engine idles. I'd think that this needs to be pretty firm, shouldn't it?
Q-SAAB is offline
Old 02-15-2005, 08:42 AM   #11
which pulley?
the crank pulley? (harmonic damper?)
*THAT* should be replaced ASAP.
Craig R.
2008 9-5 Aero-1995 900T 'vert
g96nt is offline
Old 02-15-2005, 02:38 PM   #12
no, not the crank - the lower (center) idler pulley.
I sent an e-mail to eeuroparts.com looking for the short belt, but they don't have it for my car.
Q-SAAB is offline
Old 02-15-2005, 03:03 PM   #13
spgdude's Avatar
Send a message via AIM to spgdude
Hey Id either do the short belt mod, or get both new pulleys. And do it asap, I had the idler pulley fall off on one of our saabs. And on another it caused the belt to slip off, dont wan that to happen to far from home.
77' Datsun 280z
02' 9-5 Aero B234/19t
07' 9-7x
09' 9-5 SportCombi 5mt Stg1
spgdude is offline
Old 02-17-2005, 05:56 AM   #14
Check out the website listed above that shows how to do the short belt mod and get the belt numbers that are displayed and take it to your local autoparts shop. They should be able to cross reference the number and get you the belt you need. I got mine at an Advance Autoparts shop here in Northern Virginia.
deleonl1 is offline
Old 02-17-2005, 05:59 AM   #15
The 99-02 9-3 doesn't have a lower pulley and have read the belt used on these cars cannot be used for the short belt mod on the 94-98 900.
deleonl1 is offline
Old 02-17-2005, 06:56 AM   #16
Interesting - I wonder what's different - if you look at the two pics below - both from the EPC - it looks like it "SHOULD" work - but then, in my business we konw what I call "famous last words" - "Sure, that should work just fine". CRASH.
From what I can see in the EPC, the difference between the two is in the tensioner pulley assembly - different part #'s there - don't know why that would impact the belt, though.
Q-SAAB is offline
Old 02-17-2005, 06:59 AM   #17
DC_SAAB's Avatar
I still wonder what that pulley is for....was it to keep the belt proprietary..and wrap you into SAAB only parts...? Anyway, I heard about two concepts for doing this mod...
1> The short belt was a method to get around the proprietary SAAB belts that used to be hard to match for its length.
2> That odd-ball pulley is made out of plastic, and to replace it would mean a lot of unecessary work..., so when it goes just shorten the belt.
but considering less drag on the motor...maybe it does release a small percentage of power too.
I guess that could be another topic too... the proprietary parts on SAABs in the mid-90's.
Things like the wheel lug spacing for example, forced you to buy SAAB only for a time, although eventually manufacturer's found ways to get around it.
What about those star head bolt heads? I never saw one until I bought my SAAB...couldn't even find a wrench for it in the beginning, cause they weren't sold for a while. Just like the pulley.
DC
DC_SAAB is offline
Old 02-17-2005, 10:13 AM   #18
SaabScott's Avatar
You would think that if the '99 9-3 doesn't use the long belt, that the short belt on that engine would in fact work.
It is the T5 engine afterall!
I replaced my idler pulley last week ... and the difference was noticable right away (it was also much easier than I thought it would be).
Now, the car is making a similar noise again!
All of the pulley wheels that the belt routes around are stable when the car idles ... but that may mean nothing.
I know that the pulley that is eliminated with the short belt has never been replaced for as long as I have had the car (70K kms - 45K miles). It could be that one is going too ...
So, the question I have is ... can anyone verify whether the belt from a '99 9-3 will work for the short belt mod?
Old 02-17-2005, 11:27 AM   #19
Try to search Saabnet, I believe someone already checked if a belt from a 9-3 would work on the 900 and it doesn't.
deleonl1 is offline
