could you guys give me some advice.the machine shop is boreing my cylnders to 90.5 to fit the gsab je pistons.my questions.
the rods in the 234 are the same as the 235 only stronger,so i CAN use the 234 rods in the 235 without a problem correct?
since im using the 234 rods i must order the 234 pistons.
as for ordering the rod bearings.all i must do is order the 234 bearings? or how would i go about doing that?
as far as i am concerned the crank is the same and the only difference is the head of the rod?...bearings are the same.
last but no least i have a book called the 1998 to aug 02 (R to 02)petrol and diesel saab 9-3 owners workshop manual by haynes
is this the right book or closest to use when dong the oil pump and timing gears for the viggen.thanks for your time
