Clocking it is easy. Just find a T7 TD04 and swap the 9000 6cm exhaust housing on. Its as simple as removing the band clamp around the center section and undoing the actuator.
It'll essentially look the same as a 9-3 HOT/Viggen setup. Visually the only thing that differentiates swapped exhaust housings from outside is the tab for the engine brace on the 6cm.
...and to the o/p. Stick with the stock injectors. The ecu is tuned to work with those already.
26.9K members
