i had some spare time today so i i put a switch in to turn the fan on the help with heat soak when the car is not moving (sitting a a red light next to a little ricer reving his engine)
ill try to walk you through it step by step the best i can...
first off find the wires from the back of the fan
undo the plugs
cut the white wire (i have a 1999 9-3 it may be another color for you. but it was the one with only one wire in it)
then strip the ends of the wires
run 3 wires from where you want your switch to the engine bay
put one the the + side of the battery
one to each end of the the wire you just cut and stripped
take your switch (it needs to be one that has a common and 2 other points so that when the switch is up the fan is on and when it is down it will work off the tstat.)
mount the switch and test it out.
PICTURES....
Questions? Comments?
undo the plugs
PICTURES....
