ive fitted some to a my96 900. if you find that you have the earlier small brakes then you will need the stub axles off a later 900. its unlikely though as if the 308mm front brakes fit then you must have the matching later rear brakes also.
Like other said, you will need to find the hubs which thankfully are assemblies. So you wont need to press fit them on and off.
Find any 97+900 or 9-3. remove the brake Bull ish to make them lighter, and just undo the 4 bolts where they meet the axle. Unplug, and tap them out.
Just remember you will need to cut your dust shield too. Dip, has a great write up, so does PhilipHS. And both Bullseye and myself have a small thread on the subject. http://www.viggenfactfile.de/brakes4.html
To find out if you have the smaller hubs, find a used 9-5 or later 900/9-3 used brake rotor and see if it fits on.
Actually the early cars have a different bolt center for the rear calipers. You just need the new E-brake / caliper bracket / backing plate assembly.
26.9K members
