I had to buy a new delivery pipe (intake air pipe) for my viggen as it was leaking out of one of the small pipes next to the TB. I have an aquamist water injection system setup to spray the ic which could easily be converted to water injection. So since I have two pipes now I would like to drill a hole in old pipe and install a jet and give it a go-test wise. My question is where would be the best place for the jet? The delivery pipe has an air temp sensor located next the Diverter valve, should I place it before or after that sensor? I'm thinking after??
Thanks
Thanks
