My 9000 with the inca's (18x7.5) rub something aweful on my aero with a 235/40. My spacers push them out about another inch so its like running a 18x8.5 wheel. It clears everything fine except the wheel arches on the inside. Instead of rolling the entire fender out I just took a air grinder and cut out all of the excess material from the wheel arch. The rears were the worst but the fronts are rubbing slightly.
Have you drove with that wheel/tire combo yet? Im guessing your going to need some cutting or you are going to shave your rubber over bumps and around corners! I drove my car like it was a boat for a few days so I didn't hurt my tires.
Thanks, but for me i am not into custting and grinding. I just want the wheels to fit right. JTViggen has OZ,s 18x8 38mm 225 40 18 and he has no rubbing with 4 people in the car. he has the stock 1999 viggen springs which seems lowers than the 2002 viggen almost as low as the koni springs.
I am just wondering who with a viggen has gone wide? i was going for 18x8 35mm with 215 40 18 whic closer to the 215 45 17 than the 225 40 18. but aftre seeing a few cars ith 225 40 18 that reported no issues. i am leaning more toward the 225 40 18. i just came accors a good deal on 18x8.5 35mm and i am wonering if i shoud grab them.
Im not trying to be mean but your going to hit something. Whats the offset? You could end up hitting your suspension, and then your in real trouble because you have absolutely no clearence in the fender to use spacers and push it out more. Im not one to say things won't work. Im more the person that says anything goes, but thats only if you have the right attitude, and if your "not into cutting and grinding" I doubt your going to be happy with the results your soon to end up with.
so let me rephrase the question. any one put 18x8.5 on a 9-3 viggen with koni springs? and of so, what tire size did you use? and what wheel offset did you have?. and did you have any rubbing issues?
I don't know but when cutting things as closely as this is i would think that half inch makes a huge difference. i may be wrong but i would only spend the money if there is plenty (at least an extra inch to inch and a half) of clearence on the 18x8s..
not trying to spoil hopes but don't want to spend the money then find out you would have to cut something...
do you have the offset on the wheels. and can you get close up pics?. also can you feel with your fingers and see your clearence around all four on the inside. strut housing. rear shocks and fuel tank house. thanks you so much.
I'm putting 18x8.5 on my viggen, their is a guy with 17x8.5 and had no issues and his car was lowered.
I have yet to buy the tires just waiting on the right time and what size to get. If their is going to be rubbing then i plan on rolling the fenders just a little bit. The process is not that hard and really not that involved just a precaution. With 9k vs the 9-3 i don't think you can really justify saying its not going to work causeit did not work on the 9k.
I plan on putting Nicks coilovers on the vig so i can adjust the front to suite my needs. It will mostly be a track car with everyday driveability. I live in the City but as it is i really don't use my car at all during the week.
To say don't do... Have a open mind rolling the fenders a little bit is not hard at all. I wanted a wider wheel so thats what i went for.
Keep me updated on what you choose for a tire width. The rims i have are a offset of 35 and viggen wheels are ET of 42 my adapters are going to be 19 that will bring my ET back to 42. Might make it 20mm to gain a extra mm but not sure as of yet.
Keep me updated on what you choose for a tire width. The rims i have are a offset of 35 and viggen wheels are ET of 42 my adapters are going to be 19 that will bring my ET back to 42. Might make it 20mm to gain a extra mm but not sure as of yet.[/QUOTE said:
adapters will decrease the offset. so the wheels will stick out more. so if you have 35mm. with 19mm adapters your offset will be 16 . lower offset sticks out and higher offset goes in.
Correct the outer lip of the wheels will stick out by 19mm and the inner lip will go further in by 7mm toward the strut housing. so adding an 19mm adapterwill make your wheel stick out 38mm compared to the viggen and your inner lip will clear an additional 12mm. the wheels will set way out.
I never said its not going to work on a 9-3 because it didn't work on a 9k. :lol: where did I ever say that? I just feel 8.5 is pushing it with my experience with 9-3's.
i have 18x8 compomotive cxt's with 225/40/18 toyo t1r's (actual width 231mm) et 35 offset and they rub on the front arch linears. you could easily get away with et38 and clear the strut still handling would be better too.
26.9K members
