83# injectors working with Street Heat 57 turbo? - The Saab Link Forums
Old 04-08-2008, 04:26 PM   #1
moose's Avatar
hey,
i just got a presicion turbo Street Heat 57 , about the same as a GT3071, from a friend of mine and i was wondering what are people running for injectors. i bought 83# last summer for a bigger size turbo but i decided that i would rather have a track/streetable car then a dyno king.
thanks,
chris
undercover Moderator
Stg. no go
moose is offline
Old 04-08-2008, 07:58 PM   #2
moose's Avatar
maybe JZW can chime in? i guess he is the only one running a GT3071?
Stg. no go
moose is offline
Old 04-08-2008, 07:59 PM   #3
Deez Nutz
Palmer's Avatar
Sorry, missed this.
I am running a gt3071. I have 60# siemens injectors.
I don't know where they are at as far as the duty cycle goes though.
The A/F looks ok on the dyno.
S55/LC100/KL
Palmer is offline
Old 04-08-2008, 08:01 PM   #4
moose's Avatar
Originally Posted by Palmer View Post
Sorry, missed this.
what kind of duty cycle are you running?
Stg. no go
moose is offline
Old 04-08-2008, 08:04 PM   #5
Deez Nutz
Palmer's Avatar
Sorry, missed this.
S55/LC100/KL
Palmer is offline
Old 04-08-2008, 08:22 PM   #6
PaulH's Avatar
http://www.rceng.com/technical.aspx
should be able to figure it out with the calculator on that page. #83 is a lot of fuel, looks like around 450 crank hp @ 80% duty cycle.
Paul
PaulH is offline
Old 04-09-2008, 05:23 AM   #7
moose's Avatar
ya, i was a little drunk last night so i didn't see the rest of that. haha
Paul
i'm aiming for 350-380 whp so i would say i would be running around 70ish duty cycle.
Stg. no go
moose is offline
Old 04-09-2008, 05:37 AM   #8
Nick Taliaferro
GenuineSaab's Avatar
83s sound good with e85..
On my vig the 750cc ~71lb are maxed with 500hp and e85. The pump is not quite up to the task though.
Nicholas Taliaferro
GenuineSaab is offline
Old 04-09-2008, 01:03 PM   #9
JZW
The siemans 60# would be ok up to around 512-550bhp, both Vigge and Kyanton and myself are running the 60# and have made upwards of 450whp.
Jak made 431whp on a mustang or 481whp on a dynojet...
I was turning them down on my gt3071wg with w/m injection, but with new gt3076, I need to turn them back up. I will see where I end up.
If you plan to run 400whp, you are fine with the 60# with gasoline. If you plan to run 500bhp, you are getting near the end of the 60# injectors.
If you plan to run 600bhp, you need larger fuel line, larger fuel rail possibly and maybe a high flow fuel filter and fuel pressure regulator and the fuel pump of course too...
JZW is offline
Old 04-09-2008, 01:31 PM   #10
moose's Avatar
but would it be a big deal if i just run the 83#.
Stg. no go
moose is offline
Old 04-09-2008, 01:43 PM   #11
spgeebee88's Avatar
you could run the 83# at a lower duty cycle and all ways have room to play with
spgeebee88 is offline
Old 04-09-2008, 02:11 PM   #12
here we go again....
Were your numbers corrected or uncorrected?
With nitrous or without?
Old 04-09-2008, 03:41 PM   #13
moose's Avatar
i read a huge thing on injectors in T5suite bible. the probably is that it takes a long time to have them open since they are so big so running them at lower duty cycle might be a problem. i was wondering would 350-380whp be to low?
Stg. no go
moose is offline
Old 04-09-2008, 03:47 PM   #14
Maintaining good boost and fueling control might be a bit easier with smaller injectors. And you can get to your HP goal with 60# injectors...and have decent mileage and keep cylinder washing from overfueling at a minimum....
Old 04-09-2008, 03:57 PM   #15
moose's Avatar
i think i might have to exchange them.
Stg. no go
moose is offline
Old 04-09-2008, 04:55 PM   #16
JZW
Everyones numbers are sae, Nicks, Jak's, Kevin and everyone else in the world...
Its the hp the injectors can serve, not exactly how much hp they actually made down the number, which can't be done in bhp anyway without a engine dyno. My numbers are probably over 600bhp in sae... silly rabbit, tricks are for kids...
John
JZW is offline
Old 04-09-2008, 05:00 PM   #17
JZW
From what I understand, the larger they are, the harder it is to make the car do things like idle good, warm up and enrichment maps are harder to tweak and the maps get farther and farther away from what they look like stock.
That is why you want to match the exact fuel injectors to the tuner as if they have a lot of time tuning and getting all the bugs out at idle, part throttle and all that, the better they run. It would be very difficult for a tuner that has never used those injectors to get it all right, almost impossible.
IF you plan to tune yourself, it will take the time to figure all that out and change the Konstant and just keep driving and tweaking and driving and tweaking.
The siemans 60# are supposed to be pretty good, being high impedence and many of the tuners have them fairly well dialed in...
This could cost you more time and frustration than its worth, but anything is possible and if there is a will, there is a way
John
JZW is offline
Old 04-09-2008, 05:18 PM   #18
JZW
You act like making power with nitrous takes less fuel than cams or a big turbo, that is a little silly Mike.
Asking these questions is just trying to muddy the waters, its the same as the na guys that like all throttle and no bottle, that is fine, but it has no bearing on the fuel injector question and is no different than asking well did you make 500bhp with cams or without? Did you make 500bhp with stock fuel injectors or without?
Did you make 500bhp with stock exhaust or without? Did you make 500bhp with a t25 or gt30? Did you make 500bhp with w/m injection or without? Did you make 500bhp with forged pistons or without? Did you make 500bhp with the balance chain removed or not? Did you make 500bhp with stock exhaust manifold or without...
Get what I am saying? Its all bhp and it all takes a certain amount of fuel to make it no matter how a guy chooses to play with his toy and if he wants to make 500bhp, he needs a certain amount of fuel and besides w/m that may displace that amount, its all the same to me whether its super charged, turbo-charged, ethonal, gasoline, nitromethane, tolulene or nitrous... It all makes power and thats what we do with performance cars
I don't try to knock a guy that does it different than some or most of the others, I give that guy credit for going outside the box, you should try it sometime! Its easy to be the sheep, try playing the wolf sometime...
John
JZW is offline
Old 04-09-2008, 05:41 PM   #19
PaulH's Avatar
well actually if its a wet nitrous kit (presumably it is) then it does require smaller injectors, since the nitrous system injects additional fuel...
Paul
PaulH is offline
Old 04-09-2008, 07:05 PM   #20
JZW
You are right, I got off on a little tangent there. To me a power adder is a power adder is a power adder.
I have to fight the guys at my engine builders shop all the time because they say the same kind of thing about how my turbo is cheating
John
JZW is offline
