how to hook up a oil catch for a ng900?? - The Saab Link Forums
Old 04-07-2008, 08:17 AM   #1
slober's Avatar
is this a good idea if so how to install one as well a torque damper??
slober is offline
Old 04-07-2008, 08:20 AM   #2
moose's Avatar
just put mine in 2 weeks ago. the tube going to the catch can just replaces the metal pipe going from the valve cover to the intake.
undercover Moderator
Stg. no go
moose is offline
Old 04-07-2008, 08:24 AM   #3
slober's Avatar
pics would really help ty
slober is offline
Old 04-07-2008, 08:59 AM   #4
mcrowley's Avatar
I just ran a 1/2" braided hose from the barb on the valve cover to the catch can.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 04-07-2008, 09:09 AM   #5
The crankcase breather tube connected to a collector works OK with just the pressure built under the valve cover, but using suction from the intake will mimic the stock condition and pull dirty gases out.
I'll look for a pic....
Old 04-07-2008, 09:20 AM   #6
mcrowley's Avatar
Yep, mine still has the smaller hose & check valve (hidden under the engine cover).
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 04-07-2008, 09:34 AM   #7
That's a really good way to handle it.....
I've seen guys comment about how clean their engines are running because they can't see anything in their catch cans...DOH!
In this one, red catch can is attached to the intake heat shield. Dirty hose from engine is at top, running into can half-filled with coarse steel wool, clean hose runs back into intake under the heat shield....
Old 04-07-2008, 09:38 AM   #8
8valvegrowl's Avatar
Torque dampers are good. I think it's a better solution in many ways over the poly trans mount.
It increases NVH, but it improves shifting considerably. I machined my own.
8valvegrowl is offline
Old 04-07-2008, 01:23 PM   #9
jdinneen's Avatar
Send a message via AIM to jdinneen
just to double check, the check valve on the PCV-tb line should be allowing air to flow only FROM the TB, right? (Not sure how I have it set up even come to think of it...)
But after reading about how it sucks the vapors from the valve cover to the inlet pipe I'm glad I hooked mine back up...
jdinneen is offline
Old 04-15-2008, 04:32 PM   #10
slober's Avatar
hey what's going on, i received the catch can today. one question how do i delete the metal line from the intake to the crank cause, meaning plug the intake pipe and also isn't there a vacum line that runs of the top of the crank case shaped like a y where do i re run the vacum part??
slober is offline
Old 04-15-2008, 08:31 PM   #11
Thumbs up
hey, not sure what your asking but i hope this gives you a good idea. this is how i did mine.
99 saab 9-3
stg4
rear anti sway bar
GS stuff
oil leak
squarl is offline
Old 04-16-2008, 06:20 AM   #12
soccerrplyr's Avatar
you have to take the di out. There is a small torc screw that will need to be taken out. The end of the line has a banjo bolt attached to the inlet pipe, that needs to be taken out. That will need to be plugged. ON the y plugs sticking out of the head, you leave the line and check valve alone. It's the line that is the right of te y plug.
1999 9 Stage 18t
2000 9 Stage 19t
2005 CRV
soccerrplyr is offline
Old 07-18-2008, 11:38 PM   #13
TheTalladegaKid's Avatar
where can i buy a decent looking catch can for under $100? im too lazy to make my own... blue, black,polished,chrome...
TheTalladegaKid is offline
