Recommendation on Upgraded Brakes - The Saab Link Forums
Old 04-03-2008, 10:53 AM   #1
So i was driving home from work the other day and i was boostin pretty hard and my brakes seem not to work so well cause there stock obviously and i was going to upgrade them real soon cause i cant stand bad brakes and so i was wondering what kinda aftermarket brake setups you guys have and i was wondering if you recommend me on what kind of brake setup i should do, i was looking at gs's big brake kit for the rear? if i get that would that help out alot since its 400+ dollers lol. but uhh what would guys think i should get for my rear/front. i was looking at GS and i see the brembo rotors are those any good? i know brembo is a good brand for brakes but i dont seem any reviews on it so i bet no one really bought those.. so yeah let me know guys thank you.
http://www.genuinesaab.com/catalog/p...products_id=71
http://www.genuinesaab.com/catalog/p...products_id=70
Are the rotors from GS Any good
http://www.genuinesaab.com/catalog/p...roducts_id=409
ViggenStory is offline
Old 04-03-2008, 10:56 AM   #2
Champ's Avatar
What kind of car do you drive?
Pads make a lot of difference.
Champ is offline
Old 04-03-2008, 10:59 AM   #3
JK
JK's Avatar
To me it sounds like he needs to flush the fluid and replace the pads.
You aren't going to get any additional braking power from upgrading rotors unless you get a big brake kit (which is probably not needed here).
always a SAAB guy at heart
JK is offline
Old 04-03-2008, 11:26 AM   #4
Rudedog's Avatar
Agreed. I installed better pads in conjunction with a complete brake flush. Very helpful in reducing the fade.
RG Rude
WASSAAB member
1997 900SE Talladega (SQR stage 4)
2006 9-3SS Aero
Rudedog is offline
Old 04-03-2008, 11:35 AM   #5
alright i understand so what kind of pads would you recommend?
http://www.genuinesaab.com/catalog/p...roducts_id=253
are these any good?
Old 04-03-2008, 11:42 AM   #6
nowhereman's Avatar
if you drive a 900 you would need Aftermarket Rims to get the big break kit. they stock wheels don't fit around the big brakes. Plus i will agree that unless your rotors are shot (like mine are) no need to replace them. Better pads, lines, and a flush should take care of you for a lot less than the cost of all new rotors.
Also on the Brembos, i am going to be getting new rotors and doing the full brake job and Nick told me that they are great and for the price worth it. the drilled rotors really don't do that much more unless y ou really want the look.
Nick............... feelings?
2008 9-3 SS: Stg 1
nowhereman is offline
Old 04-03-2008, 12:13 PM   #7
i acutally have a 1999 93
what kind of rotors u getting?
link?
Old 04-03-2008, 12:24 PM   #8
saabkid37's Avatar
if its not a viggen, get brembo blanks, and i love hawk hps pads, some of the best pad ive ever run.
saabkid37 is offline
Old 04-03-2008, 12:33 PM   #9
where can i get those saabkid?
Old 04-03-2008, 12:38 PM   #10
nowhereman's Avatar
link?
Rear Rotors Brembo
Front Brembo Rotor
Rear Pads
Front Pads
Total is $324 and with the flush would defintely help you out. Again unless your rotors are shot no need to replace them. Nick said that those Brembos are great and that really the slotted ones aren't needed if you are trying to stay on a budget.
2008 9-3 SS: Stg 1
Old 04-03-2008, 12:39 PM   #11
Good Look
Thank You!
whats the difference between slotted and unslotted?
Old 04-03-2008, 12:39 PM   #12
JK
JK's Avatar
http://www.genuinesaab.com/catalog/p...roducts_id=406
JK is offline
Old 04-03-2008, 12:42 PM   #13
nowhereman's Avatar
is that a set of 4? if so it might be worth it to get those instead. either way plenty of inexpensive ways to go brought to you by GS..
2008 9-3 SS: Stg 1
Old 04-03-2008, 12:43 PM   #14
JK
JK's Avatar
That is a set for the front - as noted on the page. It would include 4 pads, 2 for each caliper. But no, not a set for all 4 wheels.
JK is offline
Old 04-03-2008, 01:01 PM   #15
dang man i think ima pick those up. lol....
Old 04-03-2008, 01:36 PM   #16
Slots.
SRSLY.....
They're mainly for looks, but can help keep a "new" pad surface if you do repeated hard stops...but will wear slightly faster.
Old 04-03-2008, 01:39 PM   #17
Castor Troy's Avatar
slotted rotors can wear pads faster, but in theory help keep the pads from glazing.
they also look [email protected]#
Castor Troy is offline
Old 04-03-2008, 02:01 PM   #18
ill probably get slotted to look cool lol..
Old 04-03-2008, 08:32 PM   #19
Send a message via AIM to mlemorie Send a message via MSN to mlemorie
The slots are there to vent the gasses that the pads release when heated. Those gasses form a cushion and "lubricate" the pad surface. Same thing as the air cushion setups on some engine machining equipment. Cross drilling has the same effect, but that reduces the ability of the rotor to spread absorb and spread heat. It also makes them more prone to crack.
mlemorie is offline
Old 04-03-2008, 08:59 PM   #20
Slots/holes were effective with older organic brake compounds, which did actually create a gas layer...but brake pad gassing hasn't happened since the 70s.
