boring out a b204 - The Saab Link Forums
Old 03-30-2008, 10:12 AM   #1
cruzer51's Avatar
boring out a b204
im planing on geting my block line bored the head decked and the cylinders bored before i start puting my 2.0l back together does anyone know how far they can be bored out before i get into the coolant pasages?
cruzer51 is offline
Old 03-30-2008, 10:16 AM   #2
No more than a mm over (.040 in) for safety, according to Saab, but some have pushed it more...
Why are you boring it out? Is the cylinder bore gouged?
Old 03-30-2008, 01:24 PM   #3
saabsbreakdown's Avatar
Send a message via AIM to saabsbreakdown
i think you want it honed, not bored..
Car 178 - 1975 Saab 99 EMS
saabsbreakdown is offline
Old 03-30-2008, 06:03 PM   #4
cruzer51's Avatar
the reason i want to get it bored is because it is gong to be a strictly racing engine and the larger the bore the more power (torque it will produce)
cruzer51 is offline
Old 03-30-2008, 06:32 PM   #5
StX221's Avatar
You would be better off refreshing a B234 and getting a tune for it. There is your displacement.
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 03-30-2008, 08:32 PM   #6
Lots of high power Saabs in Europe use the higher revving 2.0 engine and concentrate on the top of the engine, improving the breathing and strengthening the valve springs....
Old 03-30-2008, 08:41 PM   #7
cruzer51's Avatar
i was told that the b204 and the b234 are the same block the only difference was the crank on the b234 had a longer stroke i plan on using a b234 crank in it and bore it out and i do pla on going with a better top end with cams valves valve springs port and polish and all the good stuff
cruzer51 is offline
Old 03-30-2008, 09:36 PM   #8
StX221's Avatar
B234 + GT30xx seems to have some very good response from the majority of the people on here. Spools relatively low, and makes some great power.
I would say you should be fine with that
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 03-31-2008, 04:39 AM   #9
jssaab's Avatar
IIRC, daveship bored his engine a bit over not sure why but it cost him plenty to get the template done ( again IIRC)
I think the limit ( besides what you read hear) is the aftermarket pistons you can use. I have only seen 90.5 and 91 in Woesner pistons larger than the OEM. I am not sure about the JTs that Nick has access to.
But of course you can go custom rods and all and make anything work
jssaab is offline
Old 03-31-2008, 10:00 AM   #10
I agree with mike that you can more comfortably rev the 2.0L higher, but the b234 is an excellent engine as demonstrated in kaylans car. I think its silly to bore an engine out for 'racing' and just get rings made for an oversize bore. Seems like a bad way to do things to me. .040 isn't going to give you more power, either.
Old 03-31-2008, 11:32 AM   #11
Nick Taliaferro
GenuineSaab's Avatar
You can go up to 93mm but anything over 91mm requires a different head gasket.
Nicholas Taliaferro
GenuineSaab is offline
Old 04-03-2008, 09:28 PM   #12
cruzer51's Avatar
thanks im going to go talk to the machine shop tomarow and see what they say and se if i can get a price on it. i will try to ceep you all posted on the build but im buissy as hell at work and have to many projects going on right now so i dont have allot of time to get on the computer anymore. (the story of my life)
cruzer51 is offline
Old 04-03-2008, 10:18 PM   #13
drewz airflow se's Avatar
There was a few years back on ebay a c900 motor with small block chevy pistons in it. Keep us updated.
^CLICK ME^
drewz airflow se is offline
Old 04-04-2008, 06:18 AM   #14
amish_geek's Avatar
I'd like to get a spare 204 block and build it up. Bore it out to 2.3 rather than go with a stroked 2.3. This way you can keep the short stroke and gain the displacement. (Like Ed did with his 2.5 Viggen, only he went with the long stroke for the 2.5).
High revving 2.3L oh yeah.
But then again, I have to find a 204 block first, and then get the pistons etc. So we'll see what really happens by the time I get around to it.
amish_geek is offline
Old 04-04-2008, 06:23 AM   #15
Nick Taliaferro
IF you gobig bore on a 2.0 it ends up 2.1L You are not going to gain much at all. Eds it larger not for displacement but to unshroud the valves and make it flow better. Not necessarily for the extra motor size. The 2.0 / 2.3 difference is from the stroke difference basically makes more torque with the extra leverage.
Nicholas Taliaferro
Old 04-04-2008, 06:30 AM   #16
amish_geek's Avatar
Hmm.. I must have been misinformed then.
I thought the 2.0 could be bored out to 2.3... At least I remember a conversation (I thought with you) about that at SOC.
Old 04-04-2008, 06:39 AM   #17
Nick Taliaferro
Bore Stroke Displacement
93x90 = 2.445
90x90 = 2.290
90x78 = 1.984
93x78 = 2.119
Nicholas Taliaferro
Old 04-04-2008, 07:12 AM   #18
JZW
You can make a 2.3 into a 2.5 by boring over
John
JZW is offline
Old 04-04-2008, 03:07 PM   #19
Max displacement
How about this.........
A. use the shorter rods from a b234 with the newer pistons with higher pin placement from a b235.
B. Have the crank reground to increase the stroke to bring the pistons back to the top of the deck. overbore if you like.
someone do the math, what would the max displacement be?????????
MTAERO is offline
Old 04-04-2008, 03:58 PM   #20
get the crank re ground to increase the stroke? yeah, okay. your talking a whole different crank buddy, which cant even spin in the crankcase of the 2.0 block.
