hooked up my alcohol injection on the vigg - The Saab Link Forums
Old 03-26-2008, 03:59 AM   #1
spgeebee88's Avatar
Talking hooked up my alcohol injection on the vigg
last night i finished putting my alcohol injection on my viggen and what a differance. its pulls sooo clean and hard in every gear. now i just got to mess around with my mixtures to get the best one. in my C900 i used a gallon of washer fluid w/ 16oz of de-natured alcohol i'll have to try this out in the vigg
spgeebee88 is offline
Old 03-26-2008, 05:12 AM   #2
liketheword's Avatar
Got pics or info on your setup?
Vitamin SAAB
liketheword is offline
Old 03-26-2008, 05:20 AM   #3
spgeebee88's Avatar
i'll try to get some pics tonight,
http://cgi.ebay.com/ebaymotors/WATER...em330221571443
this is the kit i got ands it works great!
Old 03-26-2008, 05:29 AM   #4
Moonracer's Avatar
More pictures of the install would be great. This looks very interesting and not too bad of price on the kit. Years ago we had water injection on a old Ford pick up to help with pre ignition problems.
Moonracer is offline
Old 03-26-2008, 05:32 AM   #5
spgeebee88's Avatar
the install was very easy. the hardest part was figureing out where to put the pump and resivor
Old 03-26-2008, 05:38 AM   #6
So how exactly does alcohol injection work? What are the advantages/disadvantages of it?
mrzuzzo is offline
Old 03-26-2008, 05:39 AM   #7
lms
As you probably know, comparing water injection to your c900 and your viggen is like apples compared to oranges. How much research did you do in regards to adding this to a T7 motor? Who is going to re-map your ecu or are you doing this? Just like to know as I too have a viggen and I too had water injection on my spg and thought it would be great. But nobody has added it to a viggen except Nick at GS and even he took it off. Well maybe there are others??
Do you have a wide band, egt guage, dyno, etc so you can see just what is really going on. I'm speculating that you installed a switch so you could turn it off and on, so tests with it off and on would be awesome.
Good luck
lms is offline
Old 03-26-2008, 05:55 AM   #8
spgeebee88's Avatar
like u i had the curiousity so i went for it. and it seems to be working out the car is stock execpt for i have an open air element. i am planing to get it dynod soon. i suppose mabey it wouldnt work so well if the car was staged. but its a nice improvment over stock. and it was kinda free to do cause i had the parts laying around. and its not like iam cranking the boost w/ a MBC. just curious how T7 would react. and looking at allthe values w/ Tech 2 they look fine. and ur rite not alot of people have tryied it on a viggen so i thought that i would see for myself and i like it for now
Old 03-26-2008, 06:01 AM   #9
spgeebee88's Avatar
in a nut shell alcohol injection cools the intake air temps, in cylinder temps, and exhaust temps, and also raises the octane of the fuel its mixed with
Old 03-26-2008, 06:12 AM   #10
comtrang's Avatar
Nice, get pics of this asap. That's definitely a good price if it works out fine, esp. compared to snow performance.
comtrang is offline
Old 03-26-2008, 06:19 AM   #11
spgeebee88's Avatar
iam at work rite now but i'll snap some picks when i get home around 5
Old 03-26-2008, 07:24 AM   #12
Mostly because stock is so shitty.
If you ditched the water, and replaced the Viggen IC with one that cools better, your results would likely be similar...
And you'll never run out of air.
If you've pushed the IC to the maximum size for the space allowed, or if you're in a ridiculously hot place (say, Arizona) or if you're at altitude, then water injection is the shiznit...
Old 03-26-2008, 07:45 AM   #13
comtrang's Avatar
Exactly..I expect it'll work well with the 4500' I'm at now, in addition to the fat intercooler I have at home.
I still wanna see pics though!
comtrang is offline
Old 03-26-2008, 08:02 AM   #14
spgeebee88's Avatar
well i had the kit and the time to put it in. it never hurts to experiment
Old 03-26-2008, 08:09 AM   #15
saab4life93t's Avatar
would i see any sort of benefit on my stage 4 9-3??? ive debated on doing this for some time now...
1999 9 sold
1995 9k aero sold
1994 9k aero current
2002 viggen current
saab4life93t is offline
Old 03-26-2008, 08:12 AM   #16
spgeebee88's Avatar
i really dont see why not. theres only one way to find out.
Old 03-26-2008, 08:16 AM   #17
What IC are you using?
Old 03-26-2008, 08:27 AM   #18
User
zingZACH's Avatar
he has a huge custom fmic. and i mean huge haha
1988 900 Springtime in Sweden
zingZACH is offline
Old 03-26-2008, 08:32 AM   #19
Then he's the perfect test mule...
Do some repeated WOT runs and data logging, then install the kit, and then do similar tests on a day with similar temperatures....
Old 03-26-2008, 08:47 AM   #20
^^^ looks like im gonna have to lol...
1999 9 sold
1995 9k aero sold
2002 viggen current
