FPR replacement - The Saab Link Forums
Old 03-22-2008, 10:23 AM   #1
Bullseye's Avatar
FPR replacement
I thought I saw a post with step by step instructions on swapping out your FPR. I can't find it. Can anyone point me to it?
The weather is finally breaking so it's time for me to finally put all that stuff I have accumulated in the garage on the Viggen.
Bullseye is offline
Old 03-22-2008, 11:58 AM   #2
HIDSPG's Avatar
It should be pretty easy. Just make sure you have no pressure in the system. I think its a snap ring you have to remove. Pull it out. Install new one.
88 SPG, 08 TX Combi
HIDSPG is offline
Old 03-22-2008, 12:18 PM   #3
Bullseye's Avatar
Pull the fuel pump fuse and let it run until it stalls. Correct?
Bullseye is offline
Old 03-22-2008, 03:56 PM   #4
Trollerator
abdukted1456's Avatar
yes. and then when you get the fpr off it will still gush a little gas, so have a rag ready.
you will have to remove the delivery pipe to throttle body, and move it aside. there is a torx screw that holds a ring which holds the fpr on there. it's very hard to reach. the right size allen wrench also worked in a pinch one time.
It's way harder on a 2.3 than a 2.0
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
Old 03-22-2008, 04:23 PM   #5
lms
I did it with out removing the delivery pipe on my viggen, but its a bitch!
lms is offline
Old 03-22-2008, 05:01 PM   #6
Bullseye's Avatar
Thanks for the hints!
Bullseye is offline
Old 03-22-2008, 05:23 PM   #7
Drew in Houston's Avatar
What they said, as an fyi what you're un-screwing is just a band clamp. The 'o' rings do the sealing, so you can just take that clamp off, then twist and pull on the FPR, working it up & out until gas starts pouring everywhere. Pretty easy, I did one alonside the road once.
I just talked to a lady whose husband didn't depreassurize his fuel system before working on the filter. He didn't burn, but did go to the hospital for gas in his eyes, face, chest...
Drew in Houston is offline
Old 03-22-2008, 08:03 PM   #8
Use a candle for extra light, its easier than trying to point a flashlight.
Old 03-22-2008, 11:19 PM   #9
Adrenaline406's Avatar
Really? is this seriously the best way to get rid of fuel pressure? When i put in injectors and an fpr to my c900, i just had rags ready.
Why does that seem pretty freakin bad for the engine, i mean yes you'll be lean, but i guess its not a big deal with no pressure on the engine?
Adrenaline406 is offline
Old 03-23-2008, 03:57 AM   #10
Trollerator
also, put some vaseline on the new fpr o rings so it will go in the hole. yeah, i said to lube it and put it in.
1990 900 turbo vert
2004 9-5 aero sedan
Old 03-23-2008, 07:09 AM   #11
Nick Taliaferro
GenuineSaab's Avatar
I never bleed them down. Just wrap it with a shop rag and twist/pull it out. Wear safety glasses.. But you wear those anytime you work on the car right? A tad of engine oil will make it pop in easier.. Always present too.
Oh and make sure not to drop anything over 20lbs on your foot..
Nicholas Taliaferro
GenuineSaab is offline
Old 03-23-2008, 10:30 AM   #12
Bullseye's Avatar
Who needs extra light? I'm going to burn it out with my acetylene torch.
(Don't think so)
I actually do wear safety glasses. Mostly because I can no longer see up close.
Huh??
Bullseye is offline
Old 03-23-2008, 10:59 AM   #13
^^^ Nick dropped something on his foot and fractured it(brake rotor IIRC)
Bummer is offline
Old 03-23-2008, 11:02 AM   #14
Bullseye's Avatar
Ah. Now I remember.
Bullseye is offline
Old 03-23-2008, 07:32 PM   #15
90SPG's Avatar
Send a message via AIM to 90SPG
Stage 4?
'90 900 SPG (RIP rust)
'86 900 SPG (DD)
'86 900S
"A car with an image so immaculate it can hold confession and communion."
90SPG is offline
Old 03-23-2008, 08:35 PM   #16
Originally Posted by 90SPG View Post
Stage 4?
No i think stage four would have flattened the foot... its pretty damn heavy.
