Viggen nordic stg 3 misfireing - The Saab Link Forums
Old 03-14-2008, 10:58 AM   #1
Send a message via AIM to szucman
so i just put in a stg 3 nordic ecu and at WOT im feeling a misfire and poping from my exhaust. no check engine lights and it runs smoothly otherwise. my spark plugs are gapped at 1.0mm about which is what is recomended.
any idea please?
szucman is offline
Old 03-14-2008, 11:04 AM   #2
JK
JK's Avatar
If I were to just put a new ECU in and had any issues I think my first reaction would be to talk to the person who writes or distributes the software. They would probably have the most accurate info for you.
(call and talk to Nick Taliaferro)
always a SAAB guy at heart
JK is offline
Old 03-14-2008, 11:05 AM   #3
amish_geek's Avatar
How old are the plugs?
Condition of the DI?
amish_geek is offline
Old 03-14-2008, 11:16 AM   #4
i tried calling nick but hes not in
the plugs r a few months old
and the di seems fine i never had any issues with it
szucman is offline
Old 03-14-2008, 11:17 AM   #5
JK
JK's Avatar
A tune will bring out issues in parts.
I have 2 DIs that work fine on stock cars with stock boost, but misfire on my stage 4.
JK is offline
Old 03-14-2008, 11:23 AM   #6
really? then that could be a possibility...since im pretty sure this is the original di
szucman is offline
Old 03-14-2008, 01:36 PM   #7
lms
What plugs are you running and no matter what I would change them with a new tune (cheap insurance)-drop the gap some.
Have you had the DIC replaced under the recall?
How old is the maf, if over 50k I would replace.
What about vacuum lines and such? Any leaks will rear their ugly heads when you raise the boost.
From what I was told, it will take at least 200 miles before the car fully adapts to the new ecu-this is what Nick told me, but if it's miss-firing then something else is wrong.
lms is offline
Old 03-14-2008, 01:42 PM   #8
What about vacuum lines and such? Any leaks will rear their ufly heads when you raise the boost.
From what I was told, it will take at least 200 miles before the car fully adapts to the new dic-this is what Nick told me, but if it's miss-firing then something else is wrong.
99's were not covered on the DI recall. I fought with Saab USA about it to no avail. It was retarded. No one could give me a good reason to justify it....it came down to money since there were so few 99's, it was easy to screw us over and not be heard.
Jameson is offline
Old 03-14-2008, 03:01 PM   #9
Nick Taliaferro
GenuineSaab's Avatar
It is hard to support something I did not sell. You might contact me by email with the original purchasers Vin and name.
Nicholas Taliaferro
GenuineSaab is offline
Old 03-14-2008, 03:02 PM   #10
JK
JK's Avatar
Hahaha...yeah, that would be an issue too!
JK is offline
Old 03-14-2008, 03:16 PM   #11
yea 99 di's were not covered.
i replaced the maf just last month.
im running NGKBCPR7EXI-11 gapped at about 0.9mm
and i replaced all my vacuum lines
szucman is offline
Old 03-14-2008, 03:59 PM   #12
Nick Taliaferro
Where did the ecu come from?
Nicholas Taliaferro
Old 03-14-2008, 04:00 PM   #13
Nick Taliaferro
Oh also throw those plugs away get NGK BCPR7ES-11 gap 1.0mm
Nicholas Taliaferro
Old 03-14-2008, 07:02 PM   #14
Thanks nick i will try those plugs tomorrow morning.
Also the ecu came from Wigwam Saab of RI...they no longer support nordic though.
szucman is offline
Old 03-14-2008, 08:37 PM   #15
MONSTAMUNCH's Avatar
On my stock Vig the agents here in South Africa fit NGK BCPR7ES-10. If i di an ecu tune do i need to change plugs? NGK BCPR7ES-11? Whats the difference?
MONSTAMUNCH is offline
Old 03-14-2008, 09:41 PM   #16
User
zingZACH's Avatar
The 11 and 10 is the gap. The 7 is the temperature... If the 7 were a 6 it would be a hotter plug.
1988 900 Springtime in Sweden
zingZACH is offline
Old 03-15-2008, 08:41 AM   #17
ok so i put in the NGK BCPR7ES-11 gaped at 1.0mm and its still misfiring.
i dont have my other boost gauge installed so im going off the factory one...it seems to misfire once the boost hits the end of the yellow and red...so it seems it is misfiring once the boost is raised above stock boost.
szucman is offline
Old 03-15-2008, 09:29 AM   #18
lms
Your stock viggen should boost to the red line give or take. Do you have the original ecu. If so put it back in and see what happens. Worth a shot to see if it's the ecu or not??? Does the nordic stage 3 still require a 3.5 fpr, or was that just the stage 3+. If it does, did you install that?
What did the plugs look like when you pulled them?
Can't believe saab did not recall the 99 viggen DIC, what sense does that make? Were the 2000-2002 DIC's that much different compared to the 99's?
lms is offline
Old 03-15-2008, 10:14 AM   #19
so it turns out it was the di. i replaced it and it runs great.
thanks everyone for your help
szucman is offline
Old 03-16-2008, 08:50 PM   #20
So can i run BCPR7ES-11 on the stock car?
Ex 2000 VIGGEN [email protected]
2006 93 2.8T AERO auto [email protected]
