Forge BOV & GS Intake questions - The Saab Link Forums
Old 03-11-2008, 06:01 PM   #1
Passenger 57's Avatar
What up,
I have a 99 9-3 SE HOT and I just installed a forge bov & GS intake and was wondering what experiences others have had with them. The bov has the yellow spring in it, I took it apart and lubed it up with some mobil 1 synthetic grease before I installed it. The install was a peice of cake but it was a bit anti-climactic. When I fired the car up, I was expecting lots of lift throttle “pshhhhh” and “whoosh” noise but I could only hear it when the car was pulling rather hard and it sounded more like a “cough” Is that normal??? The car seemed to boost faster than before and the intake sounds great, no problems there but I want more “pshhhhhh”. Any ideas??? I guess its not that big of a deal. I cant wait to get the GS rack brace, SS lines and bushings in. I see a 3” downpipe in the future as well.
Thanks
PSNGR 57
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
Passenger 57 is offline
Old 03-11-2008, 06:19 PM   #2
The Forge isn't loud at all.
One of the main reasons is because it allows boost to exit so smoothly, instead of having restrictive holes or horns.
Old 03-11-2008, 06:23 PM   #3
Adrenaline406's Avatar
mine is freakin loud as hell and it takes very little boost to make it open. Try a different spring? Im not sure which one mine has in it.
Adrenaline406 is offline
Old 03-11-2008, 06:32 PM   #4
JK
JK's Avatar
I have a FMDV001 forge BOV
My is VERY "talkative," very audible (in fact this is exactly why mcrowley sold it ), but other forge valves I have heard are less so. What model to you have Passenger 57?
always a SAAB guy at heart
JK is offline
Old 03-11-2008, 06:40 PM   #5
Deez Nutz
Palmer's Avatar
JK's=not quiet at all.
I would maybe call Forge and see what spring they suggest. If you are stock, you will see around 14psi of boost, peak.
S55/LC100/KL
Palmer is offline
Old 03-11-2008, 06:41 PM   #6
I have the FMDV004A
Old 03-11-2008, 06:42 PM   #7
This is my experience with it on my Viggen, i would say its just right and not annoying.
snow4_1man is offline
Old 03-11-2008, 06:57 PM   #8
JK
JK's Avatar
I think the dual piston valves are less vocal than the single piston.
I have to only lightly back off the throttle (not even all the way off) with the 001, and its going to hiss. The dual piston has a second spring that is meant to keep things closed unless it needs to blow off. That's probably much of the reason.
Show up for a get together sometime this summer and I'd let you give the 001 a listen in my car, or if you were really up for it, try it on your car (although its pretty much going to sound the same ).
JK is offline
Old 03-11-2008, 07:10 PM   #9
mcrowley's Avatar
JK is definitely right about the dual piston vs single. I've had both...single was WAY louder....by a mile.
I run single piston recirculating valves (006 and 007P) vented to atmosphere on both of my cars, both with the blue spring & 2 shims. They're both loud enough. Also consider the amount of boost passing through them and the size of the intercooler piping will have an effect on how it'll sound.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 03-12-2008, 10:06 AM   #10
I talked to Forge and they recommend the yellow spring for stock levels of boost.
Old 03-12-2008, 12:07 PM   #11
I have both of those mods and mine is pretty loud its not so much of a woosh noise but more of a chirp or whistle
Bummer is offline
Old 03-12-2008, 02:26 PM   #12
Thats exactly what mine sounds like. I have yet to pop the thing open since i got it though, not sure what spring is in there.
Old 03-12-2008, 02:50 PM   #13
Try forcing a lot of air through a small opening by pursing your lips tightly. You'll probably hear a whistle as the air encounters resistance
Open your mouth wider to let air out more quickly, and with less resistance, and you'll hear a slight whuush....
Old 03-12-2008, 04:35 PM   #14
so Mike, youre saying that i might need to put a lighter spring in? I can tell you that I still get "blow-off" at 1-2lbs. of boost (its a very light whistle, but still obviously there)
Old 03-12-2008, 04:44 PM   #15
I opend mine the other day and cleaned up some gunk that had built up in there..i had a yellow spring which i think comes standard when you order it
Bummer is offline
Old 03-15-2008, 08:46 AM   #16
I dont want to beat a dead horse but, I am getting a weird "coughing" sound comming out of the intake when the BOV dumps boost. Does anyone else get this??? Any idaes what this could be??? Also the bov doesnt open when the car isnt under load, ie reving the engine with the clutch engaged. Maybe I am worring to much, but I dont want to do any damage to the turbo.
Old 03-15-2008, 08:54 AM   #17
Deez Nutz
Palmer's Avatar
Well, if the car is not under load, the turbo will not be making enough boost to open the BOV.
I can't help you with the other part though.
S55/LC100/KL
Palmer is offline
Old 03-15-2008, 08:55 AM   #18
Are you referring to turbo flutter?
From Tubrosmart.com:
The "flutter" noise reported by many excited enthusiasts may sound good but is actually very unhealthy for the turbo. The "flutter" occurs when upon shutting the throttle, air caught between the free-spinning turbo and the shut throttle. The consequent back pressure forces the air back through the turbine blades. This process, more commonly called "cavitation" places enormous loads on the turbo and can lead to premature wear of the turbo bearings and other load-bearing components. The cavitation or "flutter" can be fixed by either fitting a blow-off valve onto a system that hasn't got one, or making sure the blow-off valve is matched to the output of the turbo and is not working outside its flow capacity and ensuring the blow-off valve is set up correctly.
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 03-15-2008, 09:52 AM   #19
Uh oh....
Old 03-15-2008, 11:23 AM   #20
lol i bought an ebay bov to see if i could make it function... that cavitation flutter was all that i could get. I also didnt realize how bad it was and what exactly it was doing either
