Marathon suspension overhall. - The Saab Link Forums
Old 03-09-2008, 07:16 PM   #1
Since I'm leaving nissan shortly, I needed to get all my suspension and brake components on the car. It was also cool that Ced was selling the final peices.
We started out at about 4 yesterday. It took 12 hours pretty nonstop. My front brakes and whole suspension went onto his car. While his shocks and springs got added to my sub assemblys.
I have crumy pics of the upgrades, the fronts got viggen brakes, ebc greenstuff pads, centric rotors, and clean spindles from a 97 for the smaller hubs. The rear got a clean axle and hubs from a 97 as well, rear brakes are from an 03 9-5 aero also with ebc green pads, and poly bushings. The shocks and springs from Blaque, are Koni adjustable with Vogtland springs.
Changing over the fronts was pretty straight forward, but the rear axle fought me a bit. The LH bolt slides out into the same spot the exhaust is in. Going back together it slid back in fine. But with the poly and the new springs, I commented how it was "sprung tighter than a swiss watch"
Bad pic of the rears.
Out of focus pic of the rears.
Pic of the fronts.
Blaque has some better ones.
Important to note the abs sensors on a 95 and I'm guessing 94 plug in at the wheel well, where as the 96 and up seem to plug in under hood. And the plugs are completely diff.
Also, seems all bleeder valves go on the top.
My ball joints are also pretty well gone. And I should replace my abs sensors.
Old 03-09-2008, 07:28 PM   #2
Deez Nutz
Palmer's Avatar
Wow, that's going to feel great!
S55/LC100/KL
Palmer is offline
Old 03-09-2008, 07:39 PM   #3
Send a message via AIM to mlemorie Send a message via MSN to mlemorie
Very nice. What are these centric adaptors/rotors/hubs that I keep hearing about? Is it a brand or something?
mlemorie is offline
Old 03-09-2008, 08:07 PM   #4
Yeah an inexpensive brand. Seems to stop really well, but I had too much stuff in the car that I didn't want to spill or bang around. I'll test it later tomorow.
Old 03-09-2008, 09:05 PM   #5
PaulH's Avatar
Your bedroom isnt gonna handle nearly as well as it did before.
Paul
PaulH is offline
Old 03-10-2008, 01:07 PM   #6
I like the TP stand.
CiaoR32 is offline
Old 03-10-2008, 03:25 PM   #7
BluAero's Avatar
Send a message via AIM to BluAero
Not bad. I believe some pictures of the car as a whole are in order very soon? Can't wait to see it/ride in it. Maybe i'll come down to VA for a weekend.
BluAero is offline
Old 03-10-2008, 03:26 PM   #8
srp
srp's Avatar
Send a message via AIM to srp
You paint or POR15 those front assemblies/knuckles?
srp is offline
Old 03-11-2008, 09:47 AM   #9
Just some rattle can krylon. Gonna align it a bit tonight, and I'm looking for some solid lower controll arms right now, that I can offord.
Markles, I washed it last night, but it rained and its dirty again.
Old 03-11-2008, 01:57 PM   #10
DeLorean's Avatar
We did see a few today, I did not have my large sockets so there was no way to get them or I would have grabbed you a set. If you still need a set I might be able to go back later this week, but you probably want to get this finished before then.
DeLorean is offline
Old 03-11-2008, 02:47 PM   #11
I cut a deal with the same junkyard that got me a $40 alternator for my mom. I probably wont get them in the car till next month. They aren't horible, I just need a break. I've been going nonstop for the last few weeks.
Alignment should be any minute now here at work.
Old 03-11-2008, 04:00 PM   #12
DeLorean's Avatar
well on a side note I did get that 90 9000-T ignition ECU saabnazi needed.
DeLorean is offline
Old 03-12-2008, 09:22 AM   #13
Cool, I forgot my phone, but will call him up, and probably pick it up. I run home at the end of this month.
Old 06-03-2010, 12:05 PM   #14
So,
These parts are going to be going on the newerish 9-3.
The front rotors went to the machine shop on Tuesday, and were done before I was even awake on Wed. $37 for the pair. I highly recomend these guys, they did the SPG's head for $167. Fairfax Auto Parts Machine Shop, in Beautiful downtown Merrifield.
The calipers themselves were pretty well rusted, but the original powder coat on the carriers was holding up really well. One of the 7mm hex headed slide piston dealies was completely un done. So that got re installed into the carrier. The EBC greenstuff pads are still like new. I am going to scuff them a bit with some sandpaper and hopefully get these back on the 9-3, re-using the 9-3s calipers.
For the first go around, I wont disconnect the flexi lines, to save from having to bleed things out, but once the rear axle comes out, I will need to bleed all around, and will install the goodrich lines back up front.
The next step also is to remove the poly and front sway bar from the old 900, even tho I have a good feeling the sway bar is the same from the 9-3SE. When I drop the 9-3's subframe, and install the JT and Rear motor mount, will then add the bigger bar if needed. I have some fresh end links, and tie rod ends coming as well.
To make the end links easier, I plan on removing the whole tie rod, gutting the bushings, and adding the poly ones I got from genuine, but didn't have a chance to put in the 900. Then off for a fresh alignment.
Old 06-03-2010, 07:25 PM   #15
Send a message via AIM to nomadtw
wait... so the brake assemblies from the 9 5 can bolt up to our cars? that's awesome i was under the impression that very few parts, none of which are of any worth could be swapped in
1997 900 SE Convertible - now with 100% more drop top
nomadtw is offline
Old 06-03-2010, 07:37 PM   #16
Sleepy7666's Avatar
Is this worth the time?
I lurk.
99 and 01 Saab 9-3
96 Escort LX
83 Yamaha XJ650 Maxim
Sleepy7666 is offline
Old 06-04-2010, 02:32 AM   #17
Harvey's Autohaus's Avatar
How did you bleed the rear calipers with both of them ON upside down? You have a right side caliper on the left side of the axle in the first pic.
HakbarSAABzzz
Harvey's Autohaus is offline
Old 06-04-2010, 01:32 PM   #18
Yeah, the 00 and 01 9-5 Aero front brakes are also the Viggen front brakes. And the 02-04 Aero/V6 rear brakes are the 300mm diameter which swap right up.
Yeah, I also have it suspended with toilet paper on not on the car, I assure you, it was installed correctly.
In the very fist post almost to the bottom I say this;
Old 06-05-2010, 12:06 PM   #19
Well whatever front sway bar is on my 9-3 is nowhere near as beefy as the 900's upgraded unit. So the whole subframe is gonna come down and get swapped over.
Also the RH rotor set screw needs to be drilled out.
Old 06-05-2010, 12:23 PM   #20
Sleepy7666's Avatar
I know the S model and SE models have different size front sway bars.
I'll get a link soon.
I lurk.
99 and 01 Saab 9-3
96 Escort LX
