Brake Lines - The Saab Link Forums
Old 03-06-2008, 01:21 PM   #1
Exclamation Brake Lines
I'm changing my brake lines to performance ones, and was wondering what brake fluid would you guys recommend? Also, While changing the brake lines do i need to drain all the fluid from the car?
Thanks
Viggen Crazed is offline
Old 03-06-2008, 01:24 PM   #2
saabkid37's Avatar
you dont need to drain all the fluid, it will all come out on its own when you change the first line.
i would get ATE superblue.
saabkid37 is offline
Old 03-06-2008, 01:43 PM   #3
Champ's Avatar
Anything 5.1 or better should be fine for street.
If you are tracking your car, look into the higher temp stuff, which is all 5.1 but there is a wide variety.
Champ is offline
Old 03-06-2008, 02:14 PM   #4
Bullseye's Avatar
Ditto on the Super blue.
Bullseye is offline
Old 03-06-2008, 02:29 PM   #5
srp
srp's Avatar
Send a message via AIM to srp
x3 with full flush
srp is offline
Old 03-06-2008, 02:33 PM   #6
...but bleed it out every year or two
the only problem with super blue is the wet boiling point....
I love it otherwise, and run it in two cars...
Old 03-06-2008, 02:40 PM   #7
Champ's Avatar
DRY: 401F -- WET: 284F --- DOT3
DRY: 446F -- WET: 311F --- DOT4
DRY: 502F -- WET: 343F --- VALVOLINE SYNPOWER
DRY: 509F -- WET: 365F --- MOTUL 5.1
DRY: 527F -- WET: 302F --- AP RACING 551
DRY: 536F -- WET: 392F --- ATE SUPERBLUE/TYP200
DRY: 550F -- WET: 290F --- FORD HD
DRY: 590F -- WET: 410F --- AP RACING 600
DRY: 590F -- WET: 518F --- CASTROL SRF
DRY: 593F -- WET: 420F --- MOTUL RBF600
DRY: 610F -- WET: 421F --- NEO-SYNTHETIC SUPER DOT 610
Champ is offline
Old 03-06-2008, 02:42 PM   #8
Deez Nutz
Palmer's Avatar
Um, ok.
New brake fluid for me then. As far as I know, mine is 2 years old or so.
S55/LC100/KL
Palmer is offline
Old 03-06-2008, 02:48 PM   #9
Champ's Avatar
The valvoline synpower is pretty good and easy to find. If you are just driving streets it really won't matter.
Champ is offline
Old 03-06-2008, 03:10 PM   #10
not only street but tracking too, superblue it is then...
Old 03-06-2008, 03:14 PM   #11
Champ's Avatar
What I would do is take a look at that chart, and whatever is the easiest to find of those with higher temps than the synpower I'd buy.
Some of that stuff may be more difficult to find than others. It also may cost much more.
If you are tracking, remember to bleed your brakes after each event.
Champ is offline
Old 03-06-2008, 03:37 PM   #12
moose's Avatar
i just bought ate last weekend. going put it in this weekend. when you bleed it out you do left front, right rear, right front, left rear?
undercover Moderator
Stg. no go
moose is offline
Old 03-06-2008, 07:36 PM   #13
Heath's Avatar
Motul 600 for this guy
Heath is offline
Old 03-07-2008, 08:16 AM   #14
Start soaking your connections with power lube or something now. And if you round off the hard lines, the parts are all pretty cheap to replace.
Old 03-07-2008, 07:12 PM   #15
Saab9-3se's Avatar
Why do you need to Bleed after a tracking event ?
Saab9-3se is offline
Old 03-07-2008, 07:48 PM   #16
I'm guessing any moisture that may be in the system would boil causing overpressure in the system. Possibly bubbles.
Old 03-07-2008, 11:41 PM   #17
Champ's Avatar
You typically boil the fluid at a good track event unless you have some pretty beefy brakes, and I don't like the feel of a super mushy pedal.
I guess I should say most important would be to make sure you have fresh fluid before the events.
Champ is offline
Old 03-08-2008, 04:20 AM   #18
Saab9-3se's Avatar
Thanks
I have EBC slotted/dimpled rotors with EBC greenstuff pads (might change these to reds) and stainless steel brake lines. I am very happy with the setup. Should be good for the track
Old 03-08-2008, 08:08 AM   #19
Champ's Avatar
Thanks
If you are driving hard I'd say you will likely boil the fluid. If you haven't done track before, it becomes apparently obvious (pretty fast) how poor the stock brakes are.
Champ is offline
Old 03-08-2008, 08:30 AM   #20
99saabnut just added ate rotors, redstuff pads, super blue, and goodrich lines to his car. He may have an opinion on the set up.
