viggen trans/engine rebuild - The Saab Link Forums
Old 03-04-2008, 04:01 AM   #1
gm
gm's Avatar
My car doesn't like to get into reverse & I figure when that get's fixed I might as well have my LSD thrown in. Anyone have any ideas on who I should have build the trans & also how much $$$ is it to have it done?
I am also debating on having pistons thrown in the car due to the weak viggen piston issues. What have people paid to have this done?
thanks
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 03-04-2008, 04:50 AM   #2
moose's Avatar
https://saablink.net/forum/showthread...viggen+rebuild
undercover Moderator
Stg. no go
moose is offline
Old 03-04-2008, 05:54 AM   #3
gm
gm's Avatar
thanks.... never been good at that search stuff
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 03-04-2008, 07:16 AM   #4
Nick Taliaferro
GenuineSaab's Avatar
It is hard to quote since you never know what will be messed up inside and the parts from saab are so expensive.
We are working on an affordable bearing package. This will help some. I found arp bolts for the Diff less than half of factory.
I love my new gearbox with the update kit, some little fixes and the LSD..
Nicholas Taliaferro
GenuineSaab is offline
Old 03-04-2008, 07:19 AM   #5
Still waiting on what these little fixes are. The tranny is apart now just waiting to get the update kit and LSD installed. What other little fixes are their before its thrown back together?
Feel free to update in other thread.
snow4_1man is offline
Old 03-04-2008, 06:51 PM   #6
gm
gm's Avatar
A friend/mechanic told me 30hrs to do the trans + parts, that remove it from my car-rebuild-install. He guessed $3500 by the time the trans was rebuilt, new clutch & whatever else was involved.
I asked him how much if he threw new pistons in the car & he stated about $1500 ish.. so around $5,000 total.
Definantly more then I want to spend on it, trying to see if there are other options....
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 03-04-2008, 06:56 PM   #7
NahumCC's Avatar
Pull trans out yourself, send off for R&R, remove head and oil pan, unbolt rods and push out through top of block, put in new pistons and HG, put head and pan back on, put trans back in when it comes in.
You'd at least this way be only paying for the labor on the trans as well as all the parts.
2013 FR-S
NahumCC is offline
Old 03-04-2008, 07:19 PM   #8
The pistons at $1500 sounds a lot more reasonable than $3500 for the trans.
Jameson is offline
Old 04-01-2008, 12:14 PM   #9
LostAbbott's Avatar
Do you actually have to take the Trans. apart to put an LSD in? Or do you only have to take the Final drive apart? I am planning on redoing my clutch this summer with my uncle who has a full shop. We are going to put in a new clutch, alum. flywheel, and the LSD. We are thinking that all we have to do is take the final drive apart and put the LSD in there. IF that is the case I won't get into the rest of the trans.
LostAbbott is offline
Old 04-01-2008, 12:18 PM   #10
saabkid37's Avatar
the final drive coming out requires removing everything else as its pretty much the heart of the trans....so yes a full teardown is necessary.
saabkid37 is offline
Old 04-01-2008, 12:37 PM   #11
LostAbbott's Avatar
Really? Because looking at it from underneath the Final drive looks to be a separate piece from the rest of the transmission. Or is that bump out towards the back of the car on the transmission not the final drive?
Old 04-01-2008, 12:45 PM   #12
saabkid37's Avatar
the final drive is most definetly in the transmission, along with the differential, as it is on 99% of fwd cars (im not saying 100% becuase i dont want someone to say some obscure car) and cant be accesses without a full teardown
Old 04-01-2008, 12:54 PM   #13
Nick Taliaferro
Full tear-down is necessary. Takes special tools. The biggest factory to durability is proper bearing preload on reassembly and setup.
Nicholas Taliaferro
Old 04-01-2008, 09:37 PM   #14
LostAbbott's Avatar
Are there Saab trans specific tools? Or just trans specific tools? I know that if I get in there I need to do the update kit, new crush sleeve, new seals all around.. What else should I replace? Of course if I find any worn gears or other problems those should be replaced as well...
Old 04-02-2008, 03:36 AM   #15
saabkid37's Avatar
yes, thats why you dont see many, if any people doing there own trans work.
Old 04-02-2008, 05:35 AM   #16
Nick Taliaferro
Even some of the factory tools are not the best. We have made a few custom tools too. I will get a picture of some of the main ones one day.
Nicholas Taliaferro
