Brake Upgrade - The Saab Link Forums
Old 02-22-2008, 06:25 AM   #1
sethrman's Avatar
Send a message via AIM to sethrman
Brake Upgrade
Hey guys, I've been debating what to spend my tax return on and I think I have finally decided. I have needed new brakes since I got the car. Its a 1999 9-3. Is this setup a good choice for my daily driver with minor track use? All from GenuineSaab mind you.
-Goodridge Steel-Braided Brake Lines
-Hawk HPS Pad in Front
-Satisfied Pads in Rear
-Brembo Slotted Rotors in Front/Rear
Is that a good combo and is there anything else I should do while I'm there?
Thanks.
sethrman is offline
Old 02-22-2008, 06:55 AM   #2
how did much you get from taxes
ViggenStory is offline
Old 02-22-2008, 07:07 AM   #3
sethrman's Avatar
$300ish. I'll pay the rest with my money.
sethrman is offline
Old 02-22-2008, 07:18 AM   #4
mcrowley's Avatar
The SS brake lines are worth every penny, def a good choice.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 02-22-2008, 07:19 AM   #5
Chill i got 300 too. im getting turbo back in 2 weeks and my taxes come a weke after i get my turboback. im debating on
-Hks bov
-ETS Intercooler
-Hids
Old 02-22-2008, 07:26 AM   #6
What should i get? i am think im gonna get the Intercooler
Old 02-22-2008, 07:43 AM   #7
srp
srp's Avatar
Send a message via AIM to srp
I also recommend a full fluid flush. Made a big difference on the pedal feel in my car. The fluid was very dark
I used ATE Super Blue but any correct brake fluid will work.
srp is offline
Old 02-22-2008, 08:35 AM   #8
Think you can sneak in some viggen style calipers from a junkyard in there?
Old 02-22-2008, 08:41 AM   #9
srp
srp's Avatar
x2.. Good idea. I've been meaning to pick up a pair of these plus those damn expensive rotors.
srp is offline
Old 02-22-2008, 09:02 AM   #10
Unslotted undrilled 9-5 aero rotors are $60 at Eeuro.
And maybe you can find a junkyard willing to just sell the slides.
Old 02-22-2008, 10:14 AM   #11
srp
srp's Avatar
What was the range on the front calipers/carriers again?
All Viggens
02-05 9-5 Aero's?
And the rear 9-5 Aero brakes were also 02-05 right?
srp is offline
Old 02-22-2008, 10:33 AM   #12
stromer's Avatar
I believe eliteforeignauto has a 9-5 aero they are parting right now that might have the calipers you need.
All Viggens, all 9-5 Aeros have the 308mm front rotor size.
For the rear, you'll need a 02+ 9-5 Aero for the 300mm rear rotors.
I would definitely consider upsizing now, which you are replacing everything else.
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 02-22-2008, 10:50 AM   #13
StX221's Avatar
make sure you get front carriers from a pre-hub update aero. otherwise the carrier bolts are in the wrong spot for you.
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 02-22-2008, 10:53 AM   #14
srp
srp's Avatar
Not familiar with Aero's... When were the hub's updated?
srp is offline
Old 02-22-2008, 11:22 AM   #15
StX221's Avatar
I believe 02 was the first year with the updated hubs?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 02-22-2008, 12:12 PM   #16
sethrman's Avatar
What is better about the viggen Calipers, how much do they cost, and where can i get them?
sethrman is offline
Old 02-22-2008, 12:22 PM   #17
srp
srp's Avatar
The viggen calipers are powder coated. What you really only need is the caliper carrier which spaces out the caliper farther and allows you to use the larger aero/viggen rotors.
srp is offline
Old 02-22-2008, 03:26 PM   #18
StX221's Avatar
Calipers are the same specs between both. You just want the carriers that hold the caliper. They push the caliper out from the hub further so that you can bolt the 308mm rotor on there.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
