Upgrading Cams - The Saab Link Forums
Old 02-05-2008, 09:00 AM   #1
moose's Avatar
Upgrading Cams
Does anyone know about the necessary degreeing that is required when you upgrade to bigger cams. i was looking at maptuns site and they say that degreeing is necessary to run right.
Which cam would be best for different applications. if i were to get the 276 cams would that be to big and would be awaste of time?
undercover Moderator
Stg. no go
moose is offline
Old 02-05-2008, 09:09 AM   #2
x2 on the degreeing, But the 276 cames are rated for 400-550hp and the 264 are rated from 350-425hp. Thats taken from nicks site, I believe the cames are from the same company that maptun gets them from.
Take a look at Yakgton he was running a GT30r Turbine Housing A/R: 0.82, Wheel: 60mm w/ 84 trim Compressor Housing A/R: 0.60, Wheel: 76.2mm w/ 56 trim. His dyno was 450whp with cams Lift/Duration: 268/9.6.not that should give you a better understanding of what cam to use. He had a longer manifold more top end. His dyno curve is amazing though def what i'm shooting for once i get the other engine installed.
snow4_1man is offline
Old 02-05-2008, 09:11 AM   #3
Castor Troy's Avatar
GS's site doesnt say anything about degreeing the 264 cam, but it does on the 276 cam
Castor Troy is offline
Old 02-05-2008, 09:12 AM   #4
moose's Avatar
maptun.com
Stg. no go
moose is offline
Old 02-05-2008, 09:17 AM   #5
i dont think the maptun cams are enem, judging by the fact that the pictures of the cams on maptun are polished in between the lobes, and are not polished on the GS/Enem cams
regardless, GS does not say you need to degree the 264 cams, but does say you need to degree the 276 cams.
also, the GS cams are $786, and the maptun cams are (at today's conversion rate) $828 plus probably $100 in shipping.
besides that, when you're getting up to the amount of power that these cams are designed to make, not taking the extra care to degree the cams sounds like a bad idea
Old 02-05-2008, 09:28 AM   #6
Originally Posted by Guteman View Post
Hey,
Question for you all. Who makes the camshafts that Genuine Saab sells? Does Nick make them? I'm curious to know what company makes them.
Cheerio,
Paul
Originally Posted by GenuineSaab View Post
Enem is the manufacturer in Sweden. They also sell to Maptun.
The pictures could always be different.
Old 02-05-2008, 09:28 AM   #7
PAviggen's Avatar
From what I have been told, unless you are running a gt2871 or larger, upgraded cams are not effective since the smaller turbos (i.e. td04) are not able to breath enough at higher rpms. Below a 2871 T5 cams are ideal.
PAviggen is offline
Old 02-05-2008, 03:13 PM   #8
moose's Avatar
i'm looking at eventually upgrading the turbo next fall. but since i have to change my valve springs out and i'm already going to be in there what would the car run like with bigger cams?
Stg. no go
moose is offline
Old 02-05-2008, 03:38 PM   #9
Red DIC's Avatar
I hear also, to get the most effect out of the cams you need head work done and a set of tubular headers.
Red DIC is offline
Old 02-05-2008, 03:39 PM   #10
moose's Avatar
when i pull the head i'm going to have it p/p.
Stg. no go
moose is offline
Old 02-05-2008, 03:42 PM   #11
NahumCC's Avatar
Ok well I'm having a blank momment. What is "degreeing"?
2013 FR-S
NahumCC is offline
Old 02-05-2008, 03:48 PM   #12
moose's Avatar
retard timing.
Stg. no go
moose is offline
Old 02-05-2008, 03:54 PM   #13
saabkid37's Avatar
retard timing.
wrong
http://www.webcamshafts.com/
http://www.ridgenet.net/~biesiade/camdegree.htm
you needa tool similar to this
http://www.newenglandhondarebuilders.com/
thats degreeing cams.
your just setting timing, which needs cam gears.
saabkid37 is offline
Old 02-06-2008, 05:23 AM   #14
Nick Taliaferro
GenuineSaab's Avatar
The 276 are too big for most street cars. Plus you have to clearance the head just so the they will turn.
You cannot clock them with the same timing as original. It is not a big job just takes a little bit. Maybe 20 min.
The 264 are my second favorite power mod on the vig.. Second to the Top mount Gt2871 (Maybe I will get it swapped to the 3071 after this weekends drag race. ) For now I want to see what the cams and springs did for the times.
Nicholas Taliaferro
GenuineSaab is offline
Old 02-06-2008, 05:31 AM   #15
Nick Taliaferro
Here is the link.. Clearancing for the 276
http://genuinesaab.com/gallery/BigCams
Modified gear
You can time them with one indicator. Don't have any other photos of this though. Usually get excited to see the results.
Nicholas Taliaferro
Old 02-06-2008, 05:38 AM   #16
laxian55's Avatar
Nick have you tried running a combo of the cams? A couple of my DSM/Evo buddies have had some luck running a 264 intake and 272 exhaust cam setup.
laxian55 is offline
Old 02-06-2008, 05:46 AM   #17
Nick Taliaferro
Our heads don't flow that well.. Basically it is not " the problem"
Nicholas Taliaferro
Old 02-06-2008, 05:48 AM   #18
laxian55's Avatar
Ok my thinking was about the same. Have you been doing any work to fix "that problem"?
laxian55 is offline
Old 02-06-2008, 08:24 AM   #19
comtrang's Avatar
Wait a second, drag racing at this time of year? Where do you do that at!?
comtrang is offline
Old 02-06-2008, 08:33 AM   #20
Nick Taliaferro
http://www.ozarkdragstrip.com/
Nicholas Taliaferro
