Project thread 97 NG900 - The Saab Link Forums
Old 01-31-2008, 01:58 PM   #1
SAAB9-3USA's Avatar
List of what the car has
-KONI KIT
-steering rack&clamp
-full poly bushings
-ARB
What i have to add to it
-SS brake lines
-yellow stuff break pads front and rear
-brembo rotors
What else i plan on getting for it
-6 point subframe brace
That is really are there is for suspension needs if i get around to i may order some rear bushings from elkparts
I will try to keep this thread up to date as much as possible
SAAB9-3USA is offline
Old 01-31-2008, 02:08 PM   #2
Champ's Avatar
Wow you have a nice base already!
Does the 6-point work for NG or was it 9-3 only? (I don't know, seriously asking)
Champ is offline
Old 01-31-2008, 02:32 PM   #3
SAAB9-3USA's Avatar
yea it does work for a NG
Old 01-31-2008, 02:32 PM   #4
i think the 6pt would work just as well in both, i have it on my 93 and its great.
let us know how those brake lines work out, i want to get some but i do not know if it would be work it.
jonny72888 is offline
Old 01-31-2008, 03:05 PM   #5
JK
JK's Avatar
This car is, or is not getting that big nurbo?
always a SAAB guy at heart
JK is offline
Old 01-31-2008, 03:14 PM   #6
mcrowley's Avatar
Going from a 94 900 w/oem brake lines to a 96 w/ss lines I can say that its WELL worth it, especially for the price.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 01-31-2008, 09:20 PM   #7
Curlymurt's Avatar
Thanks
I'm quite excited to follow the process. These are all things I had hoped to do at some point, but it was unrealistic right now. I'm so excited.
Updated 04/02/2010:
'04 9-3 Aero
Curlymurt is offline
Old 01-31-2008, 09:22 PM   #8
by Brembos, do you just mean the stock Brembo solid replacements? I have those on my 900 too. They aren't an "upgrade" over the existing stock brakes.
Topher is offline
Old 02-01-2008, 12:10 AM   #9
Send a message via AIM to brewtide
But do you have the sticker?
brewtide is offline
Old 02-01-2008, 05:32 AM   #10
JK
JK's Avatar
Brembo is a major OEM for various car manufacturers, and I believe they were probably an OEM for for Saab. OEM parts are not upgrades, but if they rotors are worn, its good to get them back sqaure one.
JK is offline
Old 02-01-2008, 07:10 AM   #11
Marks9-3's Avatar
If this is going to be a daily driver, I would stray from the Yellow Stuff pads and go with the Red Stuff. They need less heat to make them bite and are a lot easier on the rotor then the Yellows.
For the rotors look into the CNC machines fronts from GenuineSaab.
Marks9-3 is offline
Old 02-01-2008, 07:59 AM   #12
JK
JK's Avatar
The yellow stuff has been reformulated, and apparently has better cold stop than red now.
JK is offline
Old 02-01-2008, 12:55 PM   #13
SAAB9-3USA's Avatar
This is the holset car
Old 02-01-2008, 01:09 PM   #14
JK
JK's Avatar
Originally Posted by SAAB9-3USA View Post
This will be the holset car
Fixed for you
JK is offline
Old 02-01-2008, 01:30 PM   #15
SAAB9-3USA's Avatar
So how hard is it to replace the pistons with forged .is it worth it ?
Old 02-01-2008, 02:32 PM   #16
Deez Nutz
Palmer's Avatar
Well, you have the t5 pistons, and they are widley regarded as stronger. The safe limit is 400 hp or so?
I would be more worried about the main and rod bearings than the pistons right now.
I hope you plan to re-build the motor before you put that much boost in it.
S55/LC100/KL
Palmer is offline
Old 02-01-2008, 04:19 PM   #17
drewz airflow se's Avatar
Hey I cracked a piston boosting stock.
^CLICK ME^
drewz airflow se is offline
Old 02-01-2008, 04:24 PM   #18
Deez Nutz
Palmer's Avatar
Is that based on the results of a leakdown test?
S55/LC100/KL
Palmer is offline
Old 02-01-2008, 04:43 PM   #19
JK
JK's Avatar
Stock internals are good for around 500bhp, on a good tune. Not 400bhp.
However, there's the obvious "fuck-up" factor. If something gets fucked up you can kiss the pistons and or rods goodbye.
You're not going to need forged internals right away, and I know that this car probably won't have more than 500bhp right off the bat, so I wouldn't worry about it until you blow the motor.
JK is offline
Old 02-02-2008, 12:26 PM   #20
SAAB9-3USA's Avatar
i am rebuilding one of them. just wondering cause if i don't sell the 9-3 i will be trading engines
Tags
pipe dream
