t25/28 vs gt2871 - The Saab Link Forums
Old 01-31-2008, 11:41 AM   #1
t25/28 vs gt2871
hey guys im just sitting here wondering and thinking of doing a turbo slight upgrade from my t25/28 to a gt2871r. im sure i would have to get ecu re mapped but how bad would it be on the ecu i have now, would it really throw it off that much? i most likely wont do it im just sitting here dreaming and what not. i was lookin at my dyno sheets and thats what sparked this. id really like to see 300whp, im at 279whp now. and my top end starts to really fall off around 5200rpm.
sleet is offline
Old 01-31-2008, 02:28 PM   #2
well the gt will give you alot move top end than the t25.
it will run cooler which will in turn give you more power. bigger turbo means it will not have ti spin as much to make as much boost.
jonny72888 is offline
Old 01-31-2008, 02:43 PM   #3
yeha i know all that, just wondering would it throw off the maps in the ecu that much to have to get a new one or would this ecu maybe be ok for it. i know it would probably be best to get a remapped ecu but im just curious
sleet is offline
Old 01-31-2008, 02:46 PM   #4
i went from the t25 to the td04 on stage3 sw and it was all good but once i got my stage4 sw it was even better. im sure it would be fine, i would talk to your tunner and see what they think. just know they will push you to get a new tune.
Old 01-31-2008, 03:12 PM   #5
JK
JK's Avatar
GT2871r, yes, it will perform much differently than the t25/28 hybrid.
Much different.
always a SAAB guy at heart
JK is offline
Old 01-31-2008, 05:47 PM   #6
Castor Troy's Avatar
the only thing they really have in common is they're both turbos.....they're for completely different power ranges and uses
Castor Troy is offline
Old 02-01-2008, 06:57 AM   #7
JZW
I went from the t28 to my gt3071 and it was not too bad, it was a little lean on the top end, maybe 13.1/1 and that was about what I was running with the Big T28. I had a stage 5 with 50# injectors on the car before I swapped turbos.
To me, the gt3071 .64ar spools just as fast or maybe faster than the gt2871 and it has a little more grunt to it. They are about the same price and I would just buy the gt3071 .64ar if I were you... Good Luck,
John
JZW is offline
Old 02-01-2008, 10:57 PM   #8
hey guys a guy on a local site here is selling a gt28rs for very good price due to him in financial problems. basically i could get this and sell my t25/28 for same price and only have to deal with labor (myself) unless i take it somewhere and the fittings and such. although im just considering my options here and dreaming. how much different would this be and would it be worth it to you guys? i know the rs is rated to about 350-360 hp and right now im making 279whp = 320 hp with the t25/28. would the rs get me to 300whp and would my ecu tune i have in now work with it or would it lean out to much you think?
sleet is offline
Old 02-02-2008, 09:23 AM   #9
talk to your tunner, jak told me that going from a t25 to a td04 would be fine aslong as i do not beat the hell out of the car alot. im sure it would be fine for awhile, you could put it all on and then dyno it and send the sheet to your tunner and see what he thinks. but if the turbo is cheap, i would do it.
and just wondering, how much would you sell your old one for?
Old 02-02-2008, 09:31 AM   #10
well the gt28rs is for sale for 500 and if i were to do it i would maybe sell mine for the same, maybe. the turbo is less than a year old with maybe 10k miles or around there? 99 percent sure i wont do this as i dont have the funds right now since im saving every penny i can to get a loan paid off. but im just considering my options. i figured the rs wouldnt be to big of a difference but im thinking it could possibly get me closer if not meet that 300whp mark and have a little better top end
sleet is offline
Old 02-02-2008, 12:42 PM   #11
JZW
It would take about all the gt28rs has to get 300whp. You would be pretty close to the edge, where as a gt2871 or gt3071 would give you 300whp at 20psi and not push things hard at all and then you can run 23-25psi and make 330-350whp on a dynojet.
The tdo4-18t is rated at 350-360bhp, about the same as the gt28rs or the JSP Big T28/gt28r turbo I had. It was around 294whp with the cf in half in Denver or 318whp sae on a dynojet. I had to push the car pretty hard to get that close to 300whp out of it, 25-29psi of boost and the 50# injectors and my large ets ic.
The gt28rs would give you better low end grunt and around town drivability, but would still run out of emph in the rpms above around 5k-5500rpm. If you want good drivability and decent power, this a great turbo. If you want 300whp, you should consider a larger turbo that won't have to work so hard to give you those bigger whp numbers you want.
If you want to make 300whp without pushing things too much, you need at least a gt2871 or gt3071 .64ar in my opinion...
John
JZW is offline
Old 02-02-2008, 11:12 PM   #12
comtrang's Avatar
Those Holsets sure are nice, too..
But definitely NOT bolt on.
comtrang is offline
Old 02-27-2008, 12:47 PM   #13
Hey John how much does the big T28 turbo gives you to the whp and tq? since u know from experience man. i wanan get it for my car. by summer. im saving up for it.
ViggenStory is offline
Old 02-27-2008, 12:53 PM   #14
Legit's Avatar
It is an upgrade from the TD04-18t. Jaks stage 5 with the Aero turbo is ~281/302 at wheels so Id guess between 290-300whp and 310-320ft lbs
2002 Viggen Convertible
Legit is offline
Old 02-27-2008, 01:04 PM   #15
mcrowley's Avatar
18t isn't just a regular old Aero turbo.
The 281/302 is pretty close to what my 900 made with the 15t-6cm on it, so I'd bet with an 18t/t28/gt28rs you could certainly do better.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 02-27-2008, 01:10 PM   #16
Legit's Avatar
I know that was just for a size comparison
Legit is offline
Old 02-27-2008, 02:03 PM   #17
290 wheel man. i wanan get the BIG T28 FROM JSP. is the BIG T28 a ball bearning turbo?
Old 02-27-2008, 02:21 PM   #18
moose's Avatar
no its just the T25 machined out and with new internals to make it a BIG T28.
undercover Moderator
Stg. no go
moose is offline
Old 02-27-2008, 02:23 PM   #19
nice thats still good.
