leaded fuel - The Saab Link Forums
Old 01-29-2008, 07:17 PM   #1
Makeyousaab's Avatar
leaded fuel
To my knowledge running leaded fuel is only detrimental to you're catalytic converter. If you do not have a cat, then would it be safe to run leaded fuel?
~Dave
Makeyousaab is offline
Old 01-29-2008, 07:27 PM   #2
MONSTAMUNCH's Avatar
I ran 102 octane leaded race gas on my stock 93 SE. The cats had been removed and i wanted to see if the higher octane would make a difference. The car seemed to boost a bit faster. Then i spoke to a guy who said that the lead would eventually damage my motor. I always thought that it could only damage the cats which had been removed? I had no problems never the less in the month or so that i ran the leaded fuel.
MONSTAMUNCH is offline
Old 01-29-2008, 08:12 PM   #3
Chadwick's Avatar
It's bad on your 02 sensors and will wear them out after awhile.
-Chad
Chadwick is offline
Old 01-30-2008, 02:23 PM   #4
well I thougth the lead was in fact beneficial to the engines, giving prolonged lifespans. I thought it was something like what chadwick is meantioning with the O2 sensors or another new electrical sensor that wasn't around when they were using leaded fuel.
~Dave
Old 01-30-2008, 02:47 PM   #5
mr_saab79's Avatar
Send a message via Yahoo to mr_saab79
Where does one go about finding leaded fuel these days? I thought it was totally phased out in the mid 80's. I know you can get lead substitute at most parts stores but as far as genuine leaded fuel... Where is it obtained?
79' 900T
91' 900 SPG Beryl Green
96' 9k CSE
95' 9k CSE
3 99s RIP
11 900s RIP
5 9000 RIP
mr_saab79 is offline
Old 01-30-2008, 02:48 PM   #6
moose's Avatar
it is used in racing alot, go to the drag and you'll find it.
undercover Moderator
Stg. no go
moose is offline
Old 01-30-2008, 02:48 PM   #7
Legit's Avatar
I thought leaded gas was discontinued for pollution control?
2002 Viggen Convertible
Legit is offline
Old 01-30-2008, 03:19 PM   #8
http://www.goestores.com/catalog.asp...&DeptID=169321
Its for "track use" Its absolutely terrible for humans when it gets into the water supply and in the environment. We got rid of it because catalytic converters get destroyed when running leaded fuel. The environment won that battle fortunately.
~Dave
Old 01-30-2008, 03:43 PM   #9
I get 110 octane fuel all the time. Its like 5.00 a gallon right down the street in N.H. The led is good for the motor but bad for the cat and O2 sensors. I run the 110 im my car only when im doing steet racing or going to the track and yes it does make a big difference in hp. It would be ok to run leaded fuel in ur car about every ten tank fulls of regular gas but i wouldn't fill up on it
myaero9000 is offline
Old 01-31-2008, 04:51 AM   #10
Nick Taliaferro
GenuineSaab's Avatar
Leaded race fuel kills the o2 sensors. It is especially not nice to the wideband o2 sensors. It will start affecting the dyno sensors after 10h or so. I keep 2 sets of sensors so they don't influence the normal gas / ethanol cars.
Nicholas Taliaferro
GenuineSaab is offline
Old 02-02-2008, 10:15 AM   #11
so whats everyones thoughts on water/meth and 110 race gas.
jonny72888 is offline
Old 02-02-2008, 11:14 AM   #12
mr_saab79's Avatar
If I am not mistaking the water/meth is for cooling!
79' 900T
96' 9k CSE
95' 9k CSE
3 99s RIP
11 900s RIP
5 9000 RIP
Old 02-02-2008, 02:55 PM   #13
lms
Why? What is it you are planning on doing?
lms is offline
Old 02-03-2008, 08:15 AM   #14
i have a snow performance kit im waiting to put in and it says its like running 120 octane gas (if you start off wiht 92) so what if i used race gas and the meth, would that still be safe? im guessing it would be but i just thought i would ask.
Old 02-03-2008, 09:55 AM   #15
technically methanol is race gas, if i remember correctly the use it in f1. the main reason for methanol injection is to dramatically cool the intake/exhaust temp since it burns so cool. If you strictly ran on methanol you wouldn't even need an intercooler. due to this methanol also allows you to run more boost safely because it stabilizes pump gas so it takes more pressure/temp to ignite. but even if your not running more boost, you will get a noticable performance/response increase because of the density of the charged air. with a good injection system you should be able to get an almost 15% gain, in some cases more.
However, you must be careful when using methanol especially if this is your primary fuel. due to its extremely low specific gravity, it requires almost twice the fuel by volume than gasoline and then you will need ridiculously large injectors. So injection is perfectly safe as long as it directly injected into each cyl, but if its one of those crappy single injector into the intake charge pipe systems,you'll be safe with stock boost, but i'd make sure you do not try to turn up the boost too much since you have no way of telling how much methanol each cyl is getting.
AutoXer01 is offline
Old 02-03-2008, 01:11 PM   #16
mr_saab79's Avatar
Where does the water come into play? I am correct about water and methanol mixed together as a coolent. You are correct about it as a fuel.
79' 900T
96' 9k CSE
95' 9k CSE
3 99s RIP
11 900s RIP
5 9000 RIP
Old 02-03-2008, 04:16 PM   #17
water simply acts as a detonation supressor, it makes sure the charge does not self destruct before the plugs let loose.
i believe straight methanol is better overall for your engine, but it requires additional tuning.
Old 02-03-2008, 05:03 PM   #18
mr_saab79's Avatar
interesting!
79' 900T
96' 9k CSE
95' 9k CSE
3 99s RIP
11 900s RIP
5 9000 RIP
Old 02-04-2008, 06:34 PM   #19
The evaporation of the water cools the intake charge, wile the methanol raises your octane rating. Both = knock supression which = you can run more boost, and advanced timing which = yee fuckin' haw!
Corn Cob is offline
