How to cam install? - The Saab Link Forums
Old 01-17-2008, 10:02 AM   #1
liketheword's Avatar
How to cam install?
So I am thinking T5 cams down the road. Anyone have a good write-up on how to go about this? Is this worth it for running on the stock TD04? Inquiring minds want to know.
Vitamin SAAB
liketheword is offline
Old 01-17-2008, 10:38 AM   #2
JK
JK's Avatar
Its easy cheesy. Pull the valve cover, zip tie the cam wheels securly to the timing chain to retain the correct orientation on the chain, remove the cam wheels from the cam, remove the cam keepers, pull the cam out, put new cam in, put the cam keepers back on (being sure that you have the same keepers in the same places and being sure to put the correct bolts back in the same hole they came out of. Put it back together in the order you removed it...
There are torque settings too, but I don't know them off the top of my head.
Its also a good idea to throw a new valve cover gasket in there while you're at it.
always a SAAB guy at heart
JK is offline
Old 01-17-2008, 10:44 AM   #3
Yeah, certain bolts are channeld out for oiling.
Old 01-17-2008, 12:59 PM   #4
SAAB9-3USA's Avatar
if you want a set of t5 cams i may have some after i get my taxes back. want some t5 pistons to?
i give you a deal on them to
SAAB9-3USA is offline
Old 01-17-2008, 01:06 PM   #5
I figured since I need to do the valve cover gasket it's a might as well sort of scenario regarding the cams. Provided it is a fairly easy procedure. As it seems to be. (I have the classic front driver side slow oil leek from the valve cover.)
T5 cams eh? T5 pistons eh? Will the pistons swap into my b205r block? I have asked this question before w/o a reply. It makes sense that they would, but then again maybe someone knows something I don't...
Vitamin SAAB
Old 01-17-2008, 01:09 PM   #6
JK
JK's Avatar
No clue if they fit or not (they will "fit" for sure, but I don't know about valve interference with the differences in the T5 and T7 heads...)
Either way you'll have to take the engine all the way apart if you want to attempt that sort of thing.
JK is offline
Old 01-17-2008, 01:15 PM   #7
I figured that there might be the case of interference. Due to altered deck height and valve operation differences between the two.
Sounds like only the cams would be really worth the trouble. The question is how much of a difference do they actually make? I realize it opens-up the top-end where my current ones run out of steam rather quickly. What sort of RPM differences are we talking here?
Vitamin SAAB
Old 01-17-2008, 01:17 PM   #8
SAAB9-3USA's Avatar
Do a full refresh, add a 18t turbo. Get about 285-290 whp sounds good to me
and plus tearing apart engines is fun
Old 01-17-2008, 01:18 PM   #9
JK
JK's Avatar
talk is cheap and easy.
JK is offline
Old 01-17-2008, 01:18 PM   #10
Bah!
Agreed!
A extra T5 block on hand to do these sorts of things to would be better if you go that far. Call it "old man" logic/wisdom.
Vitamin SAAB
Last edited by liketheword; 01-17-2008 at 01:19 PM. Reason: To include JK's post as a qoute :D
Old 01-17-2008, 01:20 PM   #11
theres a dyno sheet somewhere on the site and it was like 35 more whp
jonny72888 is offline
Old 01-17-2008, 01:20 PM   #12
SAAB9-3USA's Avatar
very cheap.
Old 01-17-2008, 01:21 PM   #13
Wha?
Pictures or it didn't happen!
Vitamin SAAB
Old 01-17-2008, 01:23 PM   #14
JK
JK's Avatar
Originally Posted by liketheword View Post
Wha?
No shit! I don't believe for a second that T5 cams in a T7 will lead to even a 15hp increase.
Maybe jonny is confusing the T5 cams with the Enem cams - very big difference!
JK is offline
Old 01-17-2008, 01:25 PM   #15
They better offer a sizable gain for the amount of *ching* they cost!
Again pics for prof.
I am expecting like 5hp gain.
Vitamin SAAB
Old 01-17-2008, 01:46 PM   #16
oh... sorry i thought we were talking about some 268 cams
https://saablink.net/forum/showthread...409#post365409
Old 01-17-2008, 02:17 PM   #17
Dunno how you thought that with T5 being all over the place.
It's Ok to make a mistake.
Just own-up to it man style.
Vitamin SAAB
Old 01-17-2008, 03:25 PM   #18
i saw t5 but i thought he was talking about the car, i didnt see that he had a t7 so i just thought everyone was talking about aftermarket cams and not swaping t5 and t7.
my mistake
Old 01-17-2008, 03:57 PM   #19
132417SAAB's Avatar
so generaly you dont need to worry about a tune if the t7 motor is stock? (in my case for example it would be a 99 vig fyi) why would you want swap in t5 cams in the first place?
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
