Anti-Boost: Keeping others under control
2.5K views 34 replies 10 participants last post by  Adrenaline406
Im looking to be stage 4 by summer. Whats left on the list: DP, Turbo (15t), and the chip itself. The thing is, i would like to be able to let other people drive my car without them finding out what 300 fwhp feels like (mainly dont trust my dad haha). I've heard you can do this with a MBC, but as I sit here thinking about it, im not sure thats the case.
Any ideas short of making a turbo bypass?
first off, stage 4 isn't going to be 300whp, it will be around 255-270 whp.
To limit boost you could just unplug the BPC and run base boost, or if your car is Trionic 5 you can stick a manual boost controller in there and turn the boost down (just be sure to also unplug the BPC or you can fry it - I've done this twice now :oops: )
So okay, i have a dual stage/switched mbc right now, are we talking about just opening that thing up all the way, that shouldn't work, as then it would be just turning it back into an open pipe, therefore running off of the ecu again. Might as well have no mbc at all.
And unplug the BPC? how so? do you mean one/several tubes or the electrical connector? JK, what were you doing that killed a couple of these things?
So there are three tubes, one to the wastgate, one to the turbo housing and... im not sure. But it seems like in all of these cases using an mbc will cause the bpc to think boost is lower than it really is. Not higher.
Thanks
What eric did (from what I remember) is use the valve to switch between manual boost control and BPC boost control without having to physically remove the MBC.
The way I fried my BPCs was by plugging in a MBC without unplugging the electrical connection to my BPC.
I had a working BPC, installed my MBC. I drove it for about 20 miles before I remembered that I had not unplugged the BPC. I took the MBC out and hooked the vac tubes up to the BPC and it was already too late, it was stuck wide open. For some people this does not seem to happen, but it happened twice for me.
A person with a tune or custom go-fasties should be checking fluids and the general state of things under the hood once a week anyway. I don't think wear will be a factor on the connector. Keep a bit of dielectric grease on it and I bet it wouldn't wear at all.
#27 ·
I don't know as much as many people on here, but I know what I have seen on quite a few dynos done on stock cars, and cars that were "done wrong" like mine.
I found it a bit interesting that with my tune my A/F is actually a 12.0:1 to 12.5:1 right now, whereas when I was using a stock tune for a smaller turbo I was running pretty rich.
Ether way, after seeing slspf2's dyno I would definatly look into some sensor issues. There is no reason that a larger exhaust and a turbo that flows 8% more would cause a car to run that lean as long as the sensors are reading correctly. It just should not run that lean as long as the car is knows how much air and how much fuel is flowing through...at least that is my understanding.
What I know is that I have seen dyno slips from cars with stock software that obviously does not match the hardware, but T7 and T5. I doubt that those instances are flukes, but as always, its a risk you have to take when dealing with aftermarket parts and/or a situation where you bump the power output over the stock level. That's all I can say about this for sure.
So youre saying unplugging the bpc will lower the car's boost. Seems weird, but then again, i really dont know the internals of these things.
And JK, Ive been running a dual stage/switchable mbc set up for a month or so now... nothing bad so far, but thanks, i will keep an eye out!
#33 ·
Technically, yes you are lowering max boost. No bpc means the only thing controlling boost will be the spring in the wastegate actuator. So depending on what your base boost is set at that could be anywhere from 6-8psi.
#31 ·
On my T7 9-5, I have a 5cm td-04, 3" downpipe, FMIC, saabsport catback and intake.
Its been run on the stock LPT ecu and shown to be slightly rich on the dyno.
I have it now on a 2000 saab sport ecu, and i have not dyno'd it yet, but i would garuntee that it also runs rich.
With an SQR Stage 4 Ecu, it definitely dumps fuel on the top end like nobody's business, really rich ;)
So, I will say with complete confidence that t7 can correct and adapt for hardware changes without running lean, as I have run my same hardware setup on all the different software, and 2/3 are dyno proven. And I would be very sure that this setup is as well.
#32 ·
I believe it. I only commented that he might run lean originally due to the fact that I am currently experiencing that problem, though wrongly diagnosed.;)
Unfortunately it is apparent that the Saab mechanics in StL don't know what to look for in a check engine light... they didn't even see a bad MAF as a remote possibility.
#35 ·
Hahaha, exactly what im looking for! thanks guys, im gonna just hook up a switch to my change switch (i pulled apart the change holders in the cup holder and installed a push switch at the bottom of the quarter slot, completely hidden)
Featured vehicles
Explore custom vehicles by our forum members. Click a card for details or add your own!
Loading…
