Shipment from GS - hear my yawp! - The Saab Link Forums
Old 01-14-2008, 09:56 PM   #1
Route246's Avatar
Cool Shipment from GS - hear my yawp!
Received boxes 2 & 3 (out of 3) from GS today.
22mm ARB w/ Hardware
6pt. Subframe spider (no hardware yet)
Awaiting the last HEAVY box with the Koni bundle, Rack Brace, and the rest of the look-good bits.
Finally, time to tighten up the 'vert 235R.
It's going to be a Sweet month of installation & callibration, for sure.
Heh, heh, heh. Muwaaaaaahahahahaha!
Sparka Roven!
James - Mercer Island, WA
2001 B235R 'vert
Last edited by Route246; 01-14-2008 at 10:24 PM. Reason: Added evil snicker and yawp.
Route246 is offline
Old 01-14-2008, 10:00 PM   #2
drewz airflow se's Avatar
Congrats on the box of goodies
^CLICK ME^
drewz airflow se is offline
Old 01-15-2008, 03:26 AM   #3
mcrowley's Avatar
Excellent.
I need a set of Konis on my 900.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 01-15-2008, 07:34 AM   #4
Champ's Avatar
You only need the rivet for the passenger side!
Don't drill the hole out too big, 1/2" is TOO LARGE.
Champ is offline
Old 01-15-2008, 09:19 AM   #5
Route246's Avatar
Champ, you're speaking of the 6-pt harness; am I correct?
Thank you for the tip - I will make doubly sure NOT to drill too much (hide spinning drill...)
I was quite surprised at how SMALL and light the subframe harness was. From the pictures, it looks rather large. Partly because I don't have a lift, and I don't get to look at the underbelly of my car so often.
The ARB looks like it can be installed in a matter of minutes. The instructions were a bit of a puzzle, but GS has gracioulsy applied their logo decal on it to indicate the correct orientation. This install should be easy enough, even for me
I really need to get a good set of jacks stands, now.
I wonder how many Saabists, here, are blessed with ownership of a good hydraulic lift in thier garage? (the scissor or pentagraph type)
In the meanwhile, I'm doing curls with the ARB (it's heavy), as I watch the local weather news in the Seattle area. Ice + inexperienced drivers in their over-spec SUVs... It's better than "Disney on Ice", for sure.
Sparka Roven!
2001 B235R 'vert
Route246 is offline
Old 01-15-2008, 10:12 AM   #6
stromer's Avatar
A lot of people do comment on the lightness of the 6-pt, but Nick says that due to the angles it has very high rigidity specs.
The ARB is very easy. If you're at stock ride height, driving back onto 2x4's should give enough room to get under there.
Start putting lubricant on all of the hardware while you wait for the rest of the parts!
1999 9-3, 2002 9-5, 1979 900
stromer is offline
Old 01-15-2008, 10:21 AM   #7
Champ's Avatar
Yes.
I used a 1/2" bit which made the hole a bit too large so the rivet wouldn't hold which caused me to destroy it trying to tighten it. I had to get it cut out, then a nut welded in place ($$).
There should be 3 plate bars with nuts welded on, 2 bars with 2 nuts each for the front, and 1 bar with a single nut that goes in from the center of the car towards the driver side to get that back bolt. Rivet for the 6th bolt.
This should make sense once you start trying to install it.
The rear ARB I would spray down the old bolts (4 of them) with some PBBlaster or liquid wrench (penetrant) each night for several nights before you are going to try this.
Champ is offline
Old 01-15-2008, 03:06 PM   #8
Route246's Avatar
2x4s, Lube, Penetrant... Check!
Thank you for the hints - even Champ's explanation of the plate bars make great sense.I think I made the right choice to order from GS and to consult you fine blokes here, at Saablink.
Sparka Roven!
2001 B235R 'vert
Route246 is offline
Old 01-15-2008, 03:32 PM   #9
NahumCC's Avatar
Eh just go and snap the bolts of the RARB as you won't need to reuse them since there is hardware provided.
2013 FR-S
NahumCC is offline
Old 01-15-2008, 07:09 PM   #10
Route246's Avatar
Sure, with my pinky.
No problem
Sparka Roven!
2001 B235R 'vert
Route246 is offline
Old 01-15-2008, 08:02 PM   #11
Champ's Avatar
It's 100% easier if the bolts just come off.
Champ is offline
Old 01-15-2008, 08:07 PM   #12
NahumCC's Avatar
Lol. Nick seemed to make short work on mine after we snapped the bolt heads off.........Then again he did grab a mallet to break the bar free from the rust to the rear axle beam.
2013 FR-S
NahumCC is offline
Old 01-16-2008, 05:26 AM   #13
Nick Taliaferro
GenuineSaab's Avatar
You just don't have to be nice to it. Yours Nahum was one of the more difficult ones in a while.
Nicholas Taliaferro
GenuineSaab is offline
Old 01-16-2008, 05:33 AM   #14
NahumCC's Avatar
Hahaha. Yes we can thank the state of Minnesota and there road department for the salt they put down each winter. Carfax showed thats where my car started out at.
2013 FR-S
NahumCC is offline
Old 01-16-2008, 10:56 AM   #15
Route246's Avatar
Got the final box last night.
No instructions for the open-ain filter. Pretty straight forward install, I presume? There is this part on the shield that is like a "tab" that is laser cut, but not bent out/in. Would any of you guys know what it's for? ...sorry - don't have pics at the moment.
All of the parts were neatly bagged, save for a few filter-mount screws and washers rolling around at the bottom of the box. No damage, all of the larger parts packed securely in the box. Even the decals & emblem were saran-wrapped to a piece of cardboard!
As Champ noted, there were three slide-in plates (total of 5 holes covered) and two rivets. I assume the one rivet is extra...?
All but the front suspension should be pretty DIY-able with minimal down-time. I am debating if I should do the front struts myself, or have the local indy (Scanwest) do them for me.
Now, to find the time to install all of the items - what a pleasant delimma.
Sparka Roven!
2001 B235R 'vert
Route246 is offline
Old 01-16-2008, 11:03 AM   #16
SteveMcqueen's Avatar
There is a thread here with pictures of the GS intake install, my pictures show what mounts to it.
The Internet is SRS BSNS.
SteveMcqueen is offline
Old 01-16-2008, 11:28 AM   #17
Champ's Avatar
It's pretty easy once you get into it. Reuse the 3 or 4 mounting screws from the old air box. One of them is kinda tricky to get at though. The tab is for some little part that sits up there, you'll figure it out once you start.
If I remember right, the MAF goes in rotated 180 degrees from stock.
Yep in case you F up. I used both, the extra one ended up being welded in place instead of crushed. Try getting the rivet into the subframe without drilling out the (square) hole first. I wasn't able to on mine which is why I drilled it out.
I hear the rears are easy, but I just paid around $350 to have a mechanic do them for me. (he did the rear ARB at the same time)
He told me the fronts took him a long time to do since the old ones were a bitch to get out. I was happy to spend the money to save a headache.
Champ is offline
Old 01-16-2008, 12:17 PM   #18
Route246's Avatar
Steve,
I saw the pics - very clearly, too.
That's all I need. Thanks!!! Did you paint the shield? Looks pretty neat.
We need to meet up at the next SCS event. XXX next month?
Champ,
MAF rotated 180 - check.
I'll look into the front suspension - I just might try it to get to know my car a little better
Something tells me, though, that I will be calling the indy...
Sparka Roven!
2001 B235R 'vert
Route246 is offline
Old 01-16-2008, 12:36 PM   #19
IronJoe's Avatar
Pics James!
Steve - see ya next month. And nice sig... but I would recommend changing the license plate to "NO JOKE"
IronJoe is offline
Old 01-17-2008, 01:32 AM   #20
Route246's Avatar
Originally Posted by IronJoe View Post
Pics James!
Joe,
Here you go - have at it: http://picasaweb.google.com/route246...ey=cnBnu-KnrgE
I'm pleased to report that the Intake and the Rack brace installation was relatively straight forward, thanks to the guidance from you all. Both the intake and brace went in, in one sitting, in less than an hour.
Took her for a spin, and I now see why people say that this is the first and foremost modification that needs to be applied. Flogged the go-pedal on a hill, and the floppy vert just goes STRAIGHT. I can almost take my hand off of the steering wheel. Wow, what blast not not have to worry about wrestling with the car during take-off.
The intake is quite the heavy breather! I can even hear the recirc. valve. Sounds an awful lot like the atmospheric BOV that I had in my '93 c900t, but less deafning.
There is a very curious, faint, fast ticking sound that started up after the modifications. It goes away during accel. Need to figure out what it is, because I know it's going to drive me mad. Can't hear it with the bonnet open and the motor running - the sound is much more evident inside the car with the windows closed.
More pics to follow, as the installation fest continues.
Sparka Roven!
2001 B235R 'vert
Route246 is offline
