b234 ???'s - The Saab Link Forums
Old 01-10-2008, 11:54 AM   #1
saab4life93t's Avatar
b234 ???'s
if im going to do my b234 swap do i need to do the whole motor or can i swap the crank, rods, pistons, etc...??? im thinking its time to do the swap seeing how my motor is refusing to run correctly changed oil, plugs, fuel filter, and ran complete fuel system cleaner in it and it sputters and hessitates... any ideas??
1999 9 sold
1995 9k aero sold
1994 9k aero current
2002 viggen current
saab4life93t is offline
Old 01-10-2008, 11:56 AM   #2
drewz airflow se's Avatar
I am planning on the swap i think just cracked a piston in the ng.
^CLICK ME^
drewz airflow se is offline
Old 01-10-2008, 12:00 PM   #3
im thinking thats my problem too i might have a compression test ran on it some time this week to see for sure... i cant think of any other reasons for the poor idle and hesitaton...
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 01-10-2008, 12:03 PM   #4
I cracked the #4 piston and the leak down test was 50%
^CLICK ME^
Old 01-10-2008, 12:07 PM   #5
mcrowley's Avatar
I'd say it depends on the condition of the 2.0 block in the car and the 2.3 you want to swap in. If the 2.3 is low miles I'd just do a full refresh (hg, timing chain, main seals, etc) and toss it in.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 01-10-2008, 12:07 PM   #6
well now you know your problem...
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 01-10-2008, 12:09 PM   #7
JZW
All you need is the crank, rods and pistons from a 2.3 motor to make it work, the blocks are the same, you still need the timing cover and pulleys from you're ng900 set-up to make it work. The ng oil pan works a little better for the dp too.
I would do a compression test first before you condem the motor, a bad di can make it miss-fire, a leaking intake manifold gasket can cause an air leak, bad vacuum or boost lines can cause problems. Leaking tb o-ring can cause issues, bad coolant temp sensor can cause issues, bad bpv can cause issues. I would do a compression test first!
John
JZW is offline
Old 01-10-2008, 12:14 PM   #8
JZW
I lost the #4 piston on my set-up as well, read 0 psi on compression test
To me it looks like #1 gets the most fuel, it always reads the richest on the plugs, then #2 a little less and by #4, it always reads the leanest. I have my w/m on full blast to compensate for this and I set it up so #4 reads just about right and #1 reads a little rich.
I have heard this before and I think its the design of the intake manifold because there was a guy running nitrous that said you had to run direct injection on the runners because if you tried to put a single nozzle in the delivery pipe, the #1 cyliner would get most of the nitrous and cause that cylinder to run way too hot with way too much pressure and crack the piston or bend the rods, hey kind of what Nick had happen...
To me this seems to be correct as my #1 cylinder seems to get more w/m than the other 3 cylinders....
John
JZW is offline
Old 01-10-2008, 12:15 PM   #9
the 2.3 i have has about 171k and my 2.0 has about 120k... i do plan on doing a refresh either way...
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 01-10-2008, 06:04 PM   #10
JZW
Yea, be smart, have the block checked out and honed by a machine shop and then put new piston rings and bearings in the motor. That along with a new timing chain and guides and you basically have a new motor for cheap!
Seals would be included of course...
It will require the "normal" break in process of course, good luck,
John
JZW is offline
Old 01-10-2008, 06:56 PM   #11
thanks john...
im going to have daveship do my motor because i just dont have the time and he gave me a really good price
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 01-11-2008, 04:41 AM   #12
If you want, I have a set of b234r piston heads I don't need. Problem will be trying to get somebody to seperate the rods and crank. If you want the piston tops, lemme know, I don't need them.
If you do get con rods seperately and you know for sure they are 94+ b234 con rods, post up the casting and part numbers in my thread in general perf.
Old 01-12-2008, 11:36 AM   #13
are we talking after market rods here?? ive been looking for some for the b234 but they only list rods for the b235 on maptune's site... you know where i could find some??
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 01-12-2008, 01:01 PM   #14
saabkid37's Avatar
you don't need rods...and IMHO it is easier to do a full swap than try and change all the shit with the block in the car
saabkid37 is offline
Old 01-12-2008, 06:38 PM   #15
i dont plan doing it that way at all... and why wouldnt i need rods if im going to do the swap?? ive heard that the stock rods can only handle about 400 hp... i plan on more than that
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 01-12-2008, 11:07 PM   #16
mcrowley's Avatar
I think Terry is still on stock pistons/stock rods with his 9k and he drives that thing like he stole it.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 01-13-2008, 01:01 AM   #17
saabkid37's Avatar
stock pistons/stock rods 412 whp.
kaylans at what 476whp stock pistons stock rods?
get je's and call it a day.
Old 01-13-2008, 03:57 PM   #18
geeeze you both are up early... yeah im looking to get about what kaylans getting... didnt nicks nira car bend a rod?? whats the power in that thing???
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 01-13-2008, 04:00 PM   #19
ill think about it tweek how much $$$ we talking??
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 01-13-2008, 05:35 PM   #20
mcrowley's Avatar
Late night...I didn't go to bed till 4
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
