Clutch Advise - The Saab Link Forums
Old 01-08-2008, 04:02 PM   #1
Passenger 57's Avatar
Question Clutch Advice
Its time for a new clutch, I'm getting the reverse "clunk", weird hums when driving, and had a few qusetions;
Here's what I got
1999 9-3 HOT
K&N cone filter
GS Sport Exhaust
22mm Rear Sway bar (not really relevant here)
1. Should I get the Viggen clutch kit or a spec clutch and a viggen PP?
(I would like to get a stage 3 ECU upgrade in the future)
2. Is there anything else I should replace while "I'm" in there???
Oh I was thinking of getting a GS fly wheel if funds permit.
Thanks for your input.
Damn I almost forgot, how manys hrs of labor am I looking at???
"A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.
Passenger 57 is offline
Old 01-08-2008, 04:17 PM   #2
NahumCC's Avatar
Well Viggen clutc, viggen p/p, and the flywheel are an awsome stage 3 combo as thats what I have.
I however can tell you that if you have the reverse "clunk" and humming when in reverese moving that you probably want to start setting aside for another trans. I had the same problem and I'm at the point that I have either a.) push my car back or roll back to get into reverese now or b.) Pulling the shifter into Reverse as I'm pulling to a stop until the gears line up. It's a major pain in the ass.
2013 FR-S
NahumCC is offline
Old 01-08-2008, 04:31 PM   #3
Azrael's Avatar
Get any clutch that's black.
Always bet on black.
Originally Posted by Hirsch
If you grab a tiger by its tail, you better be prepared to deal with the fucking fangs on the other end.
Azrael is offline
Old 01-08-2008, 04:37 PM   #4
mcrowley's Avatar
I agree with Nahum. Don't go for the spec unless you plan on going stage 4+.
I've got the viggen pp/spec stg 3 in my 900 and its quite grabby.
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 01-08-2008, 05:19 PM   #5
StX221's Avatar
Do a Rear main seal while you have the flywheel off. If you replace it, great. If you dont, make sure to get it turned at a machine shop so it is nice and smooth
Also make sure you replace the slave cylinder as well. If I can think of anything else you should also do while there, i will post again.
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 01-08-2008, 06:06 PM   #6
Thanks for all the advise, guys. I only get the "clunk" ocassionally when I put the car in reverse, I read somewhere that's a sign of a worn clutch, no strange noises when driving in reverse though. I sure hope I can get a viggen clutch in black, that would be great!! Rear main seal huh... I'll check into that.
Old 01-08-2008, 06:11 PM   #7
StX221's Avatar
Its like 15 bucks and the seal is right there with the flywheel off. Might help you to avoid having to drop the trans in the future if it decides to start leaking.
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 01-08-2008, 07:47 PM   #8
so...
I have just started getting a little "clunk" sometimes when putting in reverse, and I have just noticed that hum you may be refering too. Is it when you put the pedal down at 50mph and you here a new, semi-high pitched hum (not the turbo)
oh and 3rd gear syncros are, well, bad. Little bit oh clunk if i slam her.
New clutch and / or trans in my future?
99 3-door 9-3 - SOLD
2001 Audi a6 2.7 twin turbo
1986 Audi 5000 2.2 turbo
2012 VW Golf TDI
1982 Yamaha Seca xj650
PoisonBeef is offline
Old 01-08-2008, 07:50 PM   #9
NahumCC's Avatar
The hum is the syncrhos you hear normally as you put the car into the next gear while moving as they try and match the input and output shafts to each others. If your hearing a whine while moving its gear whine.
2013 FR-S
NahumCC is offline
Old 01-08-2008, 08:00 PM   #10
gear whine is bad? like nearing death bad?
2012 VW Golf TDI
Old 01-08-2008, 08:01 PM   #11
NahumCC's Avatar
Not neccesarily. Just a mechanical noise. May help if you do a fluid change.
2013 FR-S
NahumCC is offline
Old 01-09-2008, 01:28 PM   #12
ok, I was a little worried as I never had the sound before, it popped up about a month ago.
any how to's on a trany fluid change/flush? I did a quick search and came up empty.
2012 VW Golf TDI
Old 01-09-2008, 02:09 PM   #13
JZW
If you want to confirm how bad you're clutch is or if its bad at all, put the car in third gear while the car is stopped, put the E-brake on and give it a little gas and let the clutch out. If it kills the car immediately, the clutch is fine, if it slips a little and then kills the engine, the clutch is starting to go out and if it does not kill the car at all, the clutch is slipping pretty good...
John
JZW is offline
Old 01-17-2008, 01:26 PM   #14
Spec cluch's are junk... (well mayb just the stage 2 is, stage 3+ is holding out so far)
jonny72888 is offline
Old 01-17-2008, 01:42 PM   #15
JK
JK's Avatar
There are quite a few people out there who have had no troubles with spec clutches, so that might be a *bit* of an over-generalization.
Mine has been holding up to the abuse I dish at it just fine
That's like saying saab CV joints are junk just because I've had one fail in the past...
always a SAAB guy at heart
JK is offline
Old 01-17-2008, 01:47 PM   #16
this is my 2nd clutch and i know of another menber who did the same thing with a stage 3 tune.
ok, they may not be junk but after 5000 miles... you shouldnt spin the hub out of 3 of them, 2 in my car and another members car.
Old 01-17-2008, 01:48 PM   #17
laxian55's Avatar
Mine did the same thing as jonny's about 6 months before him. I would go viggen clutch unless you plan on going all out. Mike Saunders has the vig clutch and what 350ish HP.
laxian55 is offline
Old 01-17-2008, 01:53 PM   #18
JK
JK's Avatar
Hmmm. I hove I don't have the same results!
The VW/Audi community uses them pretty widely, and there are quite a few saab folks using Spec disks with viggen PPs, you two are the first I have heard of having this happen! Not to sound rude, but for my sake I would hope this is a fluke
Sorry to assume that it was an over-generalization. Did Spec stand by their product for you?
I don't do a lot of clutch dumps (read, I'm not a fan of burning up tires of blowing transmissions for the sake of a smoke show) so I would hope that I don't end up in the same boat.
JK is offline
Old 01-17-2008, 01:56 PM   #19
laxian55's Avatar
spec sent me another for 150 shipped same as jonny, not bad, but they claimed to both of us that they had never heard of it happening. That may be legit to one of us, but impossible for both.
I think that there was a bad batch and i wouldnt be the least bit surpised if a few more went out the same way. I may be wrong in associating the "spec hum" to the hub blowing out, but for about 5 miles before my hub blew out that hum got noticably louder. Then my car stopped moving. my .02
laxian55 is offline
Old 01-17-2008, 01:58 PM   #20
I have seen a member clutch where the springs popped out too.
