Ignition Alternatives - The Saab Link Forums
Old 01-06-2008, 08:40 AM   #1
beardedmayhem's Avatar
Does anyone know of feasible alternatives to the Saab Trionic 5 Ignition Control System and DI cassette setup?....perhaps something to replace the use of the DI cassette altogether? I'm getting ready to replace a bad DI, and was just wondering if there is an affordable aftermarket alternative that might offer better performance, as opposed to just replacing the cassette as normal maintenance.
beardedmayhem is offline
Old 01-06-2008, 10:17 AM   #2
NahumCC's Avatar
Nope. The DI is a very well engineered system that handles knock monitoring along with the ignition.
I can't say this for certainty but since GM bought into saab back when DI first came out I'm willing to bet that GM's coil on plug was a simplified version. However you can't use it in place of the DI.
Yet in the fashion of Paul and Jeff..........if you were really into this type of project you could run megasquirt and go back to a distributor system if you wanted. Would require much more work but you could do it.
2013 FR-S
NahumCC is offline
Old 01-06-2008, 10:21 AM   #3
Castor Troy's Avatar
nira + t7 di (hardly cost efficient though)
Castor Troy is offline
Old 01-06-2008, 10:31 AM   #4
The DI has ALOT of spark power, in fact more the quit many of the after market systems, so you wont find any gains with that... The DI is also used to sync the engine since it does not have a cam pos sensor and therefore it cannot be replaced if you keep the Trionic intact, but if you dont there are plenty of options but with a price bit more than a replacement DI runs for.
Vigge is offline
Old 01-06-2008, 10:57 AM   #5
Ok. Good to know. I have heard the ionization method is used to measure spark rate and timing across each plug. I imagine it is more accurate than a cam position sensor. Thanks much for the information!
Old 01-06-2008, 11:19 AM   #6
NahumCC's Avatar
Yup but more involved than that. Basically the DI uses ionnization readings post ignition to determine if knock has occured. Then based off the readings it will adjust each cylinder individually for timing and spark. It will also tell the ECU to pull back boost if needed after it pulls out all the timing.
2013 FR-S
NahumCC is offline
Old 01-06-2008, 11:23 AM   #7
Very cool. Are there any methods of interfacing with the ECU for re-programming aside from buying chip upgrades?
Old 01-06-2008, 11:28 AM   #8
I imagine it is more accurate than a cam position sensor!
The cam pos signal is just a reference and very little to do with accuracy, then main angle signal comes from crank shaft pos sensor, which later is used for ignition timing.
The reference is needed because from crank signal only you cannot determine phase diffrence between 1st and 4th cylider or 2 and 3. From DI's combustion signals the ECU gets the needed info via a start up sequence (both cyliders fired at same time) and therefore a traditional cam pos sensor is not needed.
Vigge is offline
Old 01-06-2008, 11:36 AM   #9
www.ecuproject.com
Aero02 is offline
Old 01-06-2008, 11:41 AM   #10
Cool. I haven't signed up for it, but can you mod the ECU via the OBD port or is there a specific interface for reprogramming?
Old 01-06-2008, 01:55 PM   #11
i wanted to know that to, how do you get the data from the ecu to the site?
jonny72888 is offline
Old 01-07-2008, 08:28 AM   #12
codesplice's Avatar
I haven't followed that project in a while, but I seem to recall that you have to build an interface adapter to plug in to the ECU itself.
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 01-07-2008, 11:18 AM   #13
Very cool. I'd be interested in trying the interface just for the sake of a learning project. It's probably not all that difficult. Does anyone have any additional information on this?
Old 01-07-2008, 06:05 PM   #14
so you would have to make something that would go from the ecu to obd2 to usb?
Old 01-07-2008, 06:38 PM   #15
a12
a12's Avatar
I believe there are a few individuals working on using the OBD port for tuning but nothing as of yet.
You have to take your computer out of it's casing, solder a connector to the board and use an interface unit with applicable software to get the info out of the ecu.
More info can be found as previously stated:
www.ecuproject.com
a12 is offline
Old 01-08-2008, 12:28 PM   #16
That's a pretty nice ride you have. I wish my 9 was up to par with that. I'm going to dive into the ECU tuning information, and will post as I make progress. Thanks again for the link.
C
