Lowering a Viggen post your pics and set up. - The Saab Link Forums
Old 12-30-2007, 08:02 AM   #1
900AERO's Avatar
Well my 02 Viggen rides very comfortable, The suspension seems to be in great shape. But I am wondering if I can lower it a bit without changing the ride comfort. Does any one know which springs can pare with the stock shocks to just gain a drop without changing ride comfort? and if so how much drop should i expect. photos will help.
WHATEVER.....SAAB'S ARE FASTER THAN WHAT YOU THINK.
900AERO is offline
Old 12-30-2007, 08:19 AM   #2
Short answer = no. If you really like the way it rides, leave it as is. shorter springs = stiffer rate.
99SAAB9-3 is offline
Old 12-30-2007, 08:41 AM   #3
StX221's Avatar
I beg to differ. My 9-5 had a fair amount of body roll but I really liked the way it used to ride while cruising on the highway.
I love it so much more being lowered and on good struts and springs. It makes a world of difference. In fact, I prefer it more now than I used to, even though you feel more of every bump while cruising on the highway (though that could just be having the koni's on almost full firm )
Time for a comeback tour?
'02 9-5 Aero
'05 Yamaha R6
StX221 is offline
Old 12-30-2007, 10:57 AM   #4
DeLorean's Avatar
IMO, viggens are too low already... at least for their bumpers
DeLorean is offline
Old 12-30-2007, 11:05 AM   #5
900AERO's Avatar
The viggens are not as low as they should be to my taste. I agree with the bumper Issue, but a careful driver should be OK.I just feel that a car can use an inch drop all around. So is any one going to post pics of their cars lowered? Alos please make sure to your list suspension set up. that would realy help. Also feel free to address any spring height setlling issues, any ride issues, etc. Thanks
Thanks
900AERO is offline
Old 12-30-2007, 01:44 PM   #6
spgproject's Avatar
Originally Posted by DeLorean View Post
IMO, viggens are too low already... at least for offroading purposes.
fixed.
as far as lowering and mantaining ride comfort, i'd think you'll need the full koni setup.
-Sir William Lyons
spgproject is offline
Old 12-30-2007, 03:08 PM   #7
lms
I have a 2002 Viggen as well. Yes, most cars ride like hell when lowered, but in my case and many others eibach springs and koni adjustable shocks make the car (viggen) ride much better. You can dial the shocks in so the ride is actually softer then the stock viggen ride.
The full koni setup has vogtland springs and is lower then eibach. I can not comment on those springs. But I have heard that these springs are a tad lower in the rear???
lms is offline
Old 12-30-2007, 03:33 PM   #8
900AERO's Avatar
Thanks. Ohhh Vogtland are koni springs, is that right? Do you have photos of your ride with your set up?
900AERO is offline
Old 12-30-2007, 07:41 PM   #9
Champ's Avatar
I've scraped less post-koni than pre-koni. The bumper sits about the same if not a little higher - since the back of the car drops so much.
900Aero, the koni kit rides better than stock with less body roll so...
Sorry for the monster photos!
Champ is offline
Old 12-30-2007, 09:28 PM   #10
900AERO's Avatar
Thanks for the pics, and the words.
900AERO is offline
Old 12-31-2007, 05:11 AM   #11
gm
gm's Avatar
I also have the koni kit on my 2K viggen & it DOES ride better then stock! The car feels better balanced & can soak up bumps MUCH better then before.
Using OEM viggen shocks on aftermarket springs I would think would be a VERY bad decision. You would be better off using the viggen springs & koni shocks then keeping the viggen shocks & using aftermarket springs.
With the nose issues, I also seem to scrape less now then I did before the car was lowered. I have always been cautios & am use to breaking fog-lights on C900's But it does seem that the way the car sits now with the back end not being up so high the front doesn't scrape nearly as much.
2009 Buell 1125cr
2013 club miata
2016 JKU RHR
gm is offline
Old 12-31-2007, 06:26 AM   #12
900AERO's Avatar
so I guess it's Koni Koni Koni. I would love to see some more pics of cars with Koni Kit set up. I have seen a few and the height seems always different. Of course that maybe because some had the springs on for longer than others. But if anyone has final photos of their cars with Koni kit and everything is settled then please post pics.
Thanks
900AERO is offline
Old 12-31-2007, 11:43 AM   #13
WSUviggen's Avatar
On the girlfriends comp so I can't post the pictures, though if you search you can find them. I have the adjustable konis front and rear with the afore mentioned springs. Once you play with the adjustments the ride can be pretty smooth. Though remember smoothness of ride is going to also be dependent on tire size. I have 18 inch ronals with 45 series tires on them and even at the softest level with the suspension the ride can be pretty harsh. The body roll is much improved though. Also any kind of sway bar or subframe brace helps nicely to tighten things up.
Hope this helps
WSUviggen is offline
Old 12-31-2007, 11:56 AM   #14
900AERO's Avatar
Hope this helps
what is with the afore mentioned springs ? Koni or Vogtland??Or..?
Post pics when you can. Thanks
900AERO is offline
Old 12-31-2007, 01:40 PM   #15
900Aero, there is a show that will be coming up in May, Its called the Carlisle Import Nationals. You may be able to get a good idea there. Also, If you are any good at driving that viggen, Saabtoberfest is a good event too.
Old 12-31-2007, 02:24 PM   #16
900AERO's Avatar
Tweeks, Hello. ..... I mean Hello.. do you know who you are replying too. Think again... Yes... That's right.
900AERO is offline
Old 01-02-2008, 08:37 AM   #17
WSUviggen's Avatar
This with the Konis struts and springs, I was trying to find a picture with them settled a bit more but couldn't...hope this helps though.
Old 01-02-2008, 12:40 PM   #18
sab
sab's Avatar
Mine is not a Viggen, but a 2002 9-3 Aero (that came from the factory with the Viggen kit and 17" rims). It also has the full Viggen interior. You didn't get this model in the USA.
Suspension: Koni adjustables shockers and Koni Springs from GS. Poly control arm bushes.
sab is offline
Old 01-02-2008, 12:52 PM   #19
Trollerator
abdukted1456's Avatar
this is not a viggen, it's a 2002 SE... I had added a viggen kit and Koni Springs and shocks kit. it was plenty low for me, sometimes much too low. this angle makes it look like it's got more clearance than it really does. you could barely fit a jack under the front, and to get it on a lift, you had to jack up the front bumper first to be able to get the arms for the lift under the side skirts
now somebody else is driving around scraping up the front bumper. (and looking like a damn pimp too)
1990 900 turbo vert
2004 9-5 aero sedan
abdukted1456 is offline
