Turboxs RFL Audi Adapter ?? - The Saab Link Forums
Old 11-17-2004, 09:50 AM   #1
dasaabguy's Avatar
Just picked up a Turboxs BOV but cannot install it without the Audi adapter.
Does anyone know where i can get the 1.8T Audi adapter by itself?
They do have kits for like $40 bucks but i dont need all the extra vacum line, hose clamps, ties etc!!
Does someone have one laying around in their garage???
dasaabguy is offline
Old 11-17-2004, 09:53 AM   #2
saabkid37's Avatar
ebay is your friend
saabkid37 is offline
Old 11-17-2004, 11:25 AM   #3
HNNLIC
Blaque's Avatar
Check TurboXs's website.
Blaque is offline
Old 11-18-2004, 02:23 PM   #4
dasaabguy do you have a t7 or t5?
saab4life is offline
Old 11-22-2004, 07:18 AM   #5
dasaabguy's Avatar
I have the T5!
Old 11-29-2004, 07:05 AM   #6
dasaabguy's Avatar
I got my adapter from Boostparts last week and installed the valve. It does blow off pretty darn loud! However it has somewhat of a mumbled cough before it blows off! Im guessing it has something to do with spring tension in the valve? Does anyone know how many spacers to run on this valve? The guy sent me about 5 spacers with the valve.
The mumbled cough sound is hard to explain but its almost sounds as if the the air is struggling to get out of the valve....almost as if the hose/intake piping is shaking violently as it blows off!
Any ideas for a fix or does anyone know how many washers to install?
Old 11-29-2004, 08:58 AM   #7
i am also running an rfl
by cough sound do you mean like a squeaking noise when it first blows?
it does not matter how many washers you install, the fewer washers the louder it'll be however, the sound won't be as crisp...the more washers you have it won't be quite as loud but the sound from the valve will be quite crisp
saabvos is offline
Old 11-29-2004, 09:34 AM   #8
stevehayes01's Avatar
I use the valve on my C900 T16 and I can only use 3 washers max on it or I get driveability issues with it. I get a little extra cough noise on mine as well but I believe it is just a little boost bleed from the valve when it is reaching critical mass pressure before blowing. And as for the rest of the noise I feel like I am driving a Skyline or something like that at times when I am driving my car since it is so loud (much like on Gran Turismo 3). Just remember that the less washers you install the less pressure it will hold thus blowing off sooner. Inset more washers and the car must build more pressure and depending on your setup this may cause some undesired results in your motor performance and longevity. I have a friend that blew a head gasket on his WRX using the RFL with 5 washers in it when it wouldnt open up at max boost (side note--- that how I got my valve for $40 bucks!!!!!!). So I would start with a 2 or 3 washer setup and play around with it from there.
stevehayes01 is offline
Old 11-30-2004, 01:35 PM   #9
dasaabguy's Avatar
hmmmmm
reinstalled my turboxs valve and still get the mumbled cough sound!
I put 1 washer in it to see if it would go away......nope!
The sound resembles that of air coming out of a tube while somebody is shaking the tube really fast!!
Is this valve adjustable, i notice it has quite a few turns when opening it to add the washers. Is this a means of tuning the valve?
How are u guys doing with spacing, my BOV vacum barb comes right up to the front radiator support! As a matter of fact i have to tuck it under the radiator support to fit it!
Why dont they make things that work when u put them on!!! ha
Old 11-30-2004, 02:02 PM   #10
It is not really a means of tuning it but yes it will cause more and less resistance to it. As of today my C900 is in pieces again so once she is back together I will get you some pics of my instsall on my C900. It is not really too tight of a fit for mine. Have you checked all of your vacuum connections to the valve and around it???
Old 12-01-2004, 05:11 AM   #11
i have a 9-3, my fitting is exactly like yours...TIGHT!....there's not much you can do about it, just try and tuck that valve under as best as possible
saabvos is offline
Old 12-01-2004, 07:12 AM   #12
dasaabguy's Avatar
Thats it! Im taking everything out of my car this weekend and dumping it
ok i wont be doing that but im going to take the BOV off along with all the hoses and the mbc+a !
I havent been able to hit fuel cutoff ever since i installed these things therefore this leads me to believe im not getting the full potential power from my engine or i have a faulty part somewhere.
This BOV is weird yesterday driving home from work it was blowing off nice .....pssssht! Today its back to its ol cough!
I will keep u guys updated on my findings!
Old 12-03-2004, 06:39 AM   #13
dasaabguy's Avatar
ok guys, i have used this BOV in many different variations such as with 2 washers, 1 washer, 1 washer with the valve halfway tightened.....etc....
I've notice a pattern, when the car is cold it gives me the mumbled air cough and after about 20 minutes of driving it blows off! Sometimes shifting from first to second it reverts back to the mumbled air cough.
Im starting to think something is up with one of my vacum lines or a faulty Dawes Device etc.....
Maybe not enough pressure is building up for blow off??
Old 12-03-2004, 07:40 AM   #14
Ok 1 washer should be blowing off with about 6 to 8psi of pressure or so at the most from what I have read on a other forums. 2 washers will be in the same range but with a crisper sharper snap to the noise. 3 washers is supposedly rated to around 10PSi or so and 4 and 5 are set to blow at 13.5+ psi. It sounds to me like you may have a small vacuum leak somewhere in your system. Do you have a boost gauge installed on your car yet? IF not now would be a great time to throw one on so you can see if you get boost flutter or low boost numbers in addition to seeing at what PSI the valve is blowing off.
http://www.hosetechniques.com --- Great place to get Silicone hose in any color!!
Old 12-03-2004, 02:23 PM   #15
dasaabguy's Avatar
ive been searching the net regarding BOV's and how they work!
I found a post on the TSN site stating 4 washers should withstand about 11psi boost?
Chad and Nick make very valid points RE the use of these atmos. valves on LH equipped vehicles and we generally recommend employment of a high rate bypass valve.
We are a dealer for Turbo XS and have installed the atmos. valves onto early 900/9000 when the customer prefers this but we will always make them aware of the potential problems encountered.
You can greatly reduce the engine stalling symptoms by increasing the opening spring preload on the valve. With the XS valves, 4 shims will generally bring this preload to 11 psi (it will take 11 hg to open this valve) and this will allow for the valve to stay closed longer during throttle closure (manifold vac) and it will also provide a quicker return of the valve piston. Check your manifold vac. at idle and set the preload of the XS valve to about 3 psi under this #. Your engine should not stall but you may still see rich mixture symptoms (black smoke from exhaust) between shifts...this is the byproduct of the air venting to atmos. after your engine management is already delivering fuel for the air measured through the AMM.
Good Luck and best regards!,
GSK @ SWEDISH DYNAMICS, INC
Also been reading about spraying some sort of teflon spray into the BOV??
Old 12-03-2004, 04:23 PM   #16
That sounds about right on. The guys I have been talking to are all Subaru guys and they are seeing 13.5 with 4+ shims.
Old 12-08-2004, 01:55 PM   #17
dasaabguy's Avatar
problem solved !
Yesterday i took off all the hosing and thoroughly inspected it!
I dont know which of the following fixed it but heres what i did!
- lubricated the valve really good with white lithium grease spray
- stretched both the MBC and BOV spring about .25!
- opened the actuator 1/4 turn
I occasionally get a cough coming from my cone air filter but the BOV blows off every time now is this normal?
Of course everytime you fix your problem you find something else that needs fixing! Just found out that my 2 front tires are worn in the insides tread! Great thats another couple hundred!
Old 12-08-2004, 02:06 PM   #18
It sounds likeyou are in the land of normal now. The slight cough is not something I would worry about too much. It seems that some SAAB's (My c900) seem to choke a little every now and then but it is nothing to worry about. Glad to hear that it is working like it should now!!
Old 12-08-2004, 07:23 PM   #19
HNNLIC
Blaque's Avatar
I want to apologize for not seeing this thread earlier... as I had the same problem with mine.
I didn't realize what noise you were referring to originally, but after thinking about it, you had the same problem that most of us had with the RFL... IT GETS STUCK!! When this happens, it makes the odd noise your referring to and you may get a whistle under boost(due to the air escaping)
You solve the problem correctly by adding lubrication to the piston. I used a copper based Anti-Seize and it never got stuck again.
Once again I hope everything worked out for ya, and sorry for not seeing this sooner.
Blaque is offline
Old 12-09-2004, 07:12 AM   #20
dasaabguy's Avatar
Blaque you could of saved me many headaches and hours of laboring in the late hours of the day!
You know whats weird is that lots of people on this forum seem to be running this RFL bov but if you do searches on the net regarding this valve theres alot of negative feedback on the valve especially with it getting stuck!
Thanks for the feedback everyone this case is officially closed!
