SAS rear sway bar - bolts let go! - The Saab Link Forums
Old 12-26-2007, 10:04 PM   #1
I was driving the car tonight, and heard a loud clang. Thought I ran over something. Didn't hear it again, so I went on my way. Arrived home and inspected around the suspension pieces in the rear and found the left rear sway bar bolts to be completely gone. Inspected the right side and found them to still be tight, and not corroded, as best I could tell.
So I reattached the bar on the left side with the original hardware pieces that came with the stock bar. Is there any reason to go out and get heavier hardware, or is the stock enough?
I suppose the hardware from Genuine Saab would work too.
This bar has been on without incident since, oh, probably 2003 and 75,000 miles ago. Lesson learned is to re-check the bolt torque periodically!
<Signature Goes Here>
Tito is offline
Old 12-26-2007, 10:14 PM   #2
jk88's Avatar
haha, the left side bolts on my GS 22 arb came loose last friday even WITH loctite after only 5mo/6000mi on the car!
i hand-tightened but they still came off in the last 3 miles before home. luckily the right side was tight, so when i got home i moved a bolt to the left side and went to the parts store...
jk88 is offline
Old 12-26-2007, 10:22 PM   #3
amish_geek's Avatar
I'll have to check my GS rear sway.
When I installed it, I got tired of holding it up with one arm, while tightening the nuts with my other. My arm got tired holding it at that weird angle (and it is a heavy gauge bar). So I used Zip ties to loosely hold it in place so I just had to rotate it and tighten the nuts.
I never removed the zip ties, so if the nuts/bolts work their way loose, the zip ties will prevent the bar from falling off, and it will just swing off the axel.
You can see the zip ties here:
amish_geek is offline
Old 12-26-2007, 11:00 PM   #4
Adrenaline406's Avatar
Haha thats a great point. I gotta do that when mine goes on...
Adrenaline406 is offline
Old 12-27-2007, 05:46 AM   #5
Nick Taliaferro
GenuineSaab's Avatar
Should not be a problem if you use good grade-8 bolts 3/8" UNC x 1.5" long with a nylock nut and hardened washers.
You need to re-torque it after it beds in. This happens because the mounting tabs on the frame are almost always rusty and the washers bed into the powdercoat just a little.
JK I don't understand how the bolts could come loose. Those nylock nuts wont loosen.
Also tighter is not always better.. You want just enough preload to hold the part nicely while leaving enough of the bolts strength to handle the working loads.
Amish - cable ties are still second to the pile of toilet paper.. I forget who that was.
Nicholas Taliaferro
GenuineSaab is offline
Old 12-27-2007, 05:53 AM   #6
JK
JK's Avatar
My GS bar is still as snug as the day I put it on there. I second what Nick says about the nylock nuts, those should not come loose at all.
always a SAAB guy at heart
JK is offline
Old 12-27-2007, 06:09 AM   #7
JA 37's Avatar
Hah! I think it was Jameson?
2006 9-2X Aero
2001 9-3 Viggen
JA 37 is offline
Old 12-27-2007, 08:07 AM   #8
jk88's Avatar
yeah i don't either. i'll just keep a close eye on it from now on. great product!
jk88 is offline
Old 12-27-2007, 10:07 PM   #9
NahumCC's Avatar
Tito were you out on 146th street by the clay terrace mall in carmel around 8:30 tonight. I thought I saw your white 9-3.
2013 FR-S
NahumCC is offline
Old 12-28-2007, 02:16 AM   #10
It's allways good measure to check these things at every oil change or at least evey 15k miles, or Maybe I'm just paranoid
99SAAB9-3 is offline
Old 12-28-2007, 09:52 AM   #11
No but I've been in and out of there a lot this holiday season!
Tito is offline
Old 12-28-2007, 06:31 PM   #12
NahumCC's Avatar
Wow glad I didn't pull a u-turn then lol.
2013 FR-S
NahumCC is offline
