where did the boost go? - The Saab Link Forums
Old 12-22-2007, 06:08 AM   #1
hey guys, today when i got in my car i was going to the bank and on the way home i gave the car some gas, i spiked to 21psi and then fell to 17 and held there... that has never happen before i can hold 21psi in the summer so it should be even better now. so i did it again and this time it was fluttering from 17 to 20 and then held at 17.
i have a stage 4 tuned car with all the hardware to back it up. im thinking mayb my ebay bov kicked the bucket. all test were in 3ed gear.
jonny72888 is offline
Old 12-22-2007, 06:10 AM   #2
Red DIC's Avatar
t5/7? BOV tells me 5 but you know how that goes...
Red DIC is offline
Old 12-22-2007, 06:26 AM   #3
ya, sorry its a 1999 9-3 (t5)
TD04hl-15
20"x8"x3.5" FMIC w/ 2.5" hot side and 3" cold
Stage 4 23psi JSP
Stage 3+ SPEC clutch
Open Air Intake
Saab Sport Exhaust
Lightend flywheel
3in Down Pipe w/ race cat
22mm ARB
Greddy Type S BOV
Sport Brembo slotted rotors
Sport ceramic pads
6 point sub-frame brace
Stage 2 motor mount
Sport tranny mount V2
Steering rack brace
Full koni kit
oil catch can
New head gasket w/ high performance bolts
Old 12-22-2007, 06:38 AM   #4
mcrowley's Avatar
How old is your bpc?
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 12-22-2007, 07:00 AM   #5
a year mayb
Old 12-22-2007, 07:36 AM   #6
JA 37's Avatar
Hey Jonny, glad you made your way over here.
I was gonna say boost pressure control as well.
You can try cleaning it out with some WD-40 then compressed air.
If that doesn't work, Goldwing or if you're feeling spendy, eEuro...
2006 9-2X Aero
2001 9-3 Viggen
JA 37 is offline
Old 12-22-2007, 07:54 AM   #7
you guys think thats what it could be? if so i have a spare i could put in just to try. so you think i could rule out the cheapo bov?
Old 12-22-2007, 08:15 AM   #8
132417SAAB's Avatar
when atleast the stock bovs go they make a hell of alot of noise so I'd assume others would too
99 9-3 se
91 Plantana Grey Carlson 9k
132417saab™©
AKA "numbers"
132417SAAB is offline
Old 12-22-2007, 09:52 AM   #9
i thought when bov went they didnt hold as much boost.
Old 12-23-2007, 02:28 PM   #10
JZW
It can be a number of things, like boost leaks on one of the ic clamps or the bpc, or a vacuum/boost line to the tb and I have had bpc's stick on me many, many times and have fixed them many times by cleaning with wd40 and blowing it out with compressed air, like shop air!
Its best to check the easy stuff first, check the bpc first and if that is not it, start looking at each ic clamp and hose to make sure the clamps are tight and the hoses have no cracks. Then look at you're vacuum and boost lines and then check the tb and make sure its not leaking, any hoses pop off the tb or the back side to the egr valve. I had all this happen with high boost and you have to start with the simple stuff and then go to the harder stuff.
One time it took me two weeks to find the issue and it was the small rubber T that splits the bpv to tb line to the gage. It had a very small slit in the black rubber T to gage, just enough to lose about 6psi of boost!
Good Luck,
John
JZW is offline
Old 12-23-2007, 04:15 PM   #11
NahumCC's Avatar
I'm saving for a Goldwing BPC for both my cars right now as the one I nabbed from my 9000 to use on the 9-3 is doing the same thing again as yours.
99 9-3 JSP stage 3 BTW.
2013 FR-S
NahumCC is offline
Old 12-23-2007, 04:32 PM   #12
saab4life93t's Avatar
im willing to bet it might have something to do with ur greddy bov...
1999 9³ sold
1995 9k aero sold
1994 9k aero current
2002 viggen current
saab4life93t is offline
Old 12-23-2007, 06:03 PM   #13
well i got laid off for 2 weeks so im sure in that time ill find out what it is. it started right after i did the head gasket so i think it is a line to the TB. i think i replace all the vacc hose... should 12' be enough?
Old 12-24-2007, 01:55 PM   #14
ok, i cleanned out the bcv and nothing, im going to replace all the vacc. lines tomorrow and see where that gets me.
after taking a test drive today i might beable to explain it better, when the boost builds it goes to 21psi and then falls back to 17 and then will slowly buld to 19 (then i run out of room). im lost now.
Old 12-27-2007, 06:25 PM   #15
replaced all vacc lines and no change, im going to try and fiind a buddy with a bov and put iit on to see it that helps, if not i dont know.
Old 12-28-2007, 07:47 AM   #16
lms
How are your plugs. Have you pulled them to checked the gap and condition?
lms is offline
Old 12-28-2007, 08:23 AM   #17
JA 37's Avatar
If you don't find one by Tuesday, I might be able to swing by. I have a good Bosch BPV and a Forge dump valve. Let me know.
2006 9-2X Aero
2001 9-3 Viggen
JA 37 is offline
Old 12-28-2007, 12:46 PM   #18
i think i got it, im just not sure what it was lol.
i cleaned the bcv, replaced all the vacc lines and tightend the intercooler clamps up, and replaced the spark plugs ( which were way out of gap). i think i fixed it, i have to wait til later when i take it out. ill let you guys know how it goes.
Old 12-29-2007, 06:06 AM   #19
im not sure if this was what was leaking boost but it is fixed. it spikes to 22psi then drops back to 19 then goes to 22-23 and holds.
that is the little rubber adapter that came in my boost guage kit, im sorry for the bad picture but there is a split where the plastic line from the guage would be and the rest of it is cracked.
