Viggen Brakes????? - The Saab Link Forums
Old 12-10-2007, 07:39 PM   #1
MONSTAMUNCH's Avatar
Viggen Brakes?????
The time has come to replace my discs and pads on my Viggen. Any suggestions as to what i should use? I dont want to go bigger, just better brakes like maybe EBC or something for road use.
MONSTAMUNCH is offline
Old 12-10-2007, 07:49 PM   #2
Champ's Avatar
I am using the stock rotors with Akebono Euro Ceramics and I like them a lot. No dust is icing on the proverbial cake.
Champ is offline
Old 12-10-2007, 09:44 PM   #3
Cool thanx. I will look around and see who has some in stock.
Old 12-10-2007, 10:35 PM   #4
I run stock Viggen discs with EBC Red Stuff on all corners.
Works very nicely
Pade is offline
Old 12-11-2007, 05:03 AM   #5
stevehayes01's Avatar
If you run the Viggen disc's you need to be running 17's right? I had always read that you would get severe rubbing on stock 16's.
stevehayes01 is offline
Old 12-11-2007, 05:14 AM   #6
No, 16's work( perhaps not ALL 16's though). Many run 16's for winter.
Again, stock slotted rotors are excellent. if you go aftermarket, I would go with Nick's plain rotors that he had slotted in house as they are of OEm quality and the slot vanes actually go in the right direction.
The cheap rotors at say R1 on ebay are not of the same quality.
I reccomend Hawk Pads, I have also had EBC's but on the car I had them on they did not last long. But others who have had EBC's on Viggens have been happy with them. EBC greens and Hawk HPS are pretty performance oriented to expect SOME noise and the fact that they work a bit better as some heat is built into them.
Jameson is offline
Old 12-11-2007, 05:17 AM   #7
Works very nicely
How do you get the front viggen brakes to work in the rear?
snow4_1man is offline
Old 12-11-2007, 07:44 AM   #8
KVR has some light weight and strong 2 piece front rotors. Ditto on the Hawk pads. In the rear, the 9-5 aero/300mm upgrade kit from GS is great.
oldzmann is offline
Old 12-11-2007, 07:55 AM   #9
LostAbbott's Avatar
I run EBC rotors and hps pads. I have noticed a huge difference between them and stock in terms of stopping power and distance. I have had them on for about 6monthc now and they are great, and there is no rust on the rotors and I am in the Northwest where it does not stop raining.
LostAbbott is offline
Old 12-11-2007, 08:15 AM   #10
I liked the Greenstuffs enough on my stock setup enough that I have them on my Viggen set up. Wont have impressions untill spring.
Stock sized 2 peice rotors oldzmann?
Old 12-11-2007, 09:44 AM   #11
Champ's Avatar
I got mine from tirerack.
Champ is offline
Old 12-11-2007, 09:46 AM   #12
I don't
Stock Viggen front brakes discs and stock Viggen rear brake discs
Pade is offline
Old 12-11-2007, 11:41 AM   #13
troll_speed's Avatar
Link
Chris
troll_speed is offline
Old 12-11-2007, 02:31 PM   #14
RBatsch's Avatar
KVRs are really nice but not cheap and front only. The company is here in Ottawa so I checked them out before I replaced my brakes but I decided to stick with OEM due to cost/performance.
RBatsch is offline
Old 12-11-2007, 03:29 PM   #15
LostAbbott's Avatar
Holy Crap those KVR's are expensive. i hope they have some magical properties...
Old 12-12-2007, 05:43 AM   #16
I hope the pattern where the hat mounts to the disc is common enough to be used for say a 322mm or larger rotor/caliper combo.
Old 12-12-2007, 04:10 PM   #17
RBatsch's Avatar
Well one reason I was considering the KVRs is that I thought you could replace the actual rotor seperately from the hub whenever the rotors wear out...nope! KVR will not sell them as they must be aligned and balanced. Guess that makes sense, but so much for saving some money. Cost is almost the same when just replacing the worn section.
Apparently KVR is working on all aluminum rotors....not sure how that works with respect to wear but the unsprung weight savings would be obvious.
RBatsch is offline
Old 12-12-2007, 05:40 PM   #18
Adrenaline406's Avatar
Check out amazon.com too, they're actually pretty well stocked and pretty cheap too.
Adrenaline406 is offline
Old 12-12-2007, 07:35 PM   #19
liketheword's Avatar
I also give a vote for stock Vig rotors and EBC Red's. I have the EBC Red's now and love them!
Vitamin SAAB
liketheword is offline
Old 12-12-2007, 08:48 PM   #20
slspf2's Avatar
What's the difference then between the green stuff and the red stuff?
slspf2 is offline
