Walbro 255LPH fuel pump - The Saab Link Forums
Old 12-04-2007, 03:24 PM   #1
saab4life93t's Avatar
Where do i go to buy a high flow fuel pump. i hear people like to run these. any suggestions??
TIA
1999 9 sold
1995 9k aero sold
1994 9k aero current
2002 viggen current
saab4life93t is offline
Old 12-04-2007, 03:49 PM   #2
http://www.jdsperformance.com/ i got my spec stage 3 clutch from them call and ask for JD
myaero9000 is offline
Old 12-04-2007, 03:59 PM   #3
If you're going to put in a new pump, you might as well put in a Bosch Motorsports "044" pump. It has a higher flow rating at various demand pressures than the 255 (which is still a damn good pump...)
There's not much of a price difference and the 044 will handle almost every turbo you can throw on the car and still keep it a street car.
Old 12-04-2007, 04:04 PM   #4
is there a site that has them???
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 12-04-2007, 04:07 PM   #5
There are loads of sites.
Find one with the price you like and go for it.
Only hitch is that the inner pump carrier in the pump housing will need to be altered slightly to fit the larger pump...
Old 12-04-2007, 04:28 PM   #6
what has to be altered on the housing and how big of a project is this going to be??? time??
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 12-04-2007, 04:45 PM   #7
The pump is slightly longer than OEM, so you'll need to shave down the carrier part to enable the bigger pump to fit. Boe Kalinoski did mine....works "the balls" ....
Old 12-04-2007, 05:12 PM   #8
Castor Troy's Avatar
fuel cell + http://store.summitracing.com/partde...5&autoview=sku methinks
Castor Troy is offline
Old 12-04-2007, 05:14 PM   #9
haha should it be done by a real mech or...
you can get to it through the back seat right??
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 12-04-2007, 05:21 PM   #10
haha im not sure if i have the $$ for a fuel cell but ill keep it in mind...
im also having trouble with my gas gauge the needle is always pegged in empty if i fill it from empty it goes to half but when i shut the car off and turn it back on its pegged again. is there some kind of sending unit that needs replacing??
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 12-04-2007, 06:20 PM   #11
a12
a12's Avatar
It's DIY if you work on your car. it's a plastic basket that comes apart that the pump sits in.I fitted a Bosch 044 which has a large body in there.i had to kinda router it out with various grinding tools like files,sandpaper and Dremel tool. It's pretty simple once you get it apart,just a few things to remember:
1.Go slow and test fit a bunch of times-can't replace mat'l that's gone.
2.When done and happy with the fit,make sure to clean out all plastic shavings thoroughly.
3.Reassemble-make sure wires and hoses not chafing and are connected securely.You may need some special fittings to make the hoses work.Try to only cut the hose that goes form the plastic Tee to the pump-leave all others.
a12 is offline
Old 12-04-2007, 06:43 PM   #12
yeah i do all the work on my car... can i get to the fuel pump from the back seat?? i thought i saw a place under the carpet but i wasnt sure... when you say fittings like what kind home depot brass or??
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 12-05-2007, 03:51 AM   #13
The little round hatch only allows access to the electrical connections to the pump, not the pump itself.
You'll need to either:
-- cut an access panel going from that round hatch toward the center of the car for about 12-16 inches
-- or drop the tank and remove it to gain access to the pump.
I've done both on two different cars and the access panel route is easier by far. If your car has been winter driven, then the straps and bolts that secure them are probably rusted tight. No amount of PB Blaster will get them loose. (I went through almost a full can over the course of several days trying to work them free.)
If you go the DIY route, memorize A12's advice, especially:
If you screw it up, it's on your head alone so go slowly and mark locations and measure clearances....
And be prepared to replace your fuel filter at the same time. It's a good practice whenever you do any major fuel system work because you usually dislodge sediment and other crap....
Old 12-05-2007, 10:19 AM   #14
i might end up cutting the 12-16 hole...
other than a new fuel filter are there any other things i should get?
1999 9 sold
1995 9k aero sold
2002 viggen current
Old 12-05-2007, 03:24 PM   #15
a12
a12's Avatar
On my Bosch pump,I used some eyelets crimped to the wires to get them on the new pump,you may need those.Also,The Bosch pump connects with a m12 x 1.5 banjo style connector I think.I got a m12x1.5 female banjo to barbed connector fitting (it's the same one as used on 9000's to connect to the fuel rail),banjo bolt,2 copper washers,and some in tank submersible rubber line to connect up to the Tee joint,along with some good fuel injection hose clamps.Worked great. I think you may have a barbed fitting right off of the pump so that should make it even easier.You will either need some of the stock plastic fuel line (which is a real bitch to work with) or some in tank submersible fuel line with clamps-i got mine from NAPA-yes they actually had it!
I have to stress though if you use flexible fuel injection hose make sure it is the in tank submersible stuff or it will fall apart over a few years time.
a12 is offline
Old 12-05-2007, 03:32 PM   #16
Nick Taliaferro
GenuineSaab's Avatar
It is not that much harder to drop the tank and that big hole always worried me about exh fumes and crash-worthiness.
Make sure the walbro you get is not a china copy..
This one looks way different than the five0 one in the Nira car Performs much better.
http://shopping.lightningmotorsports...40-p-2031.html
Nicholas Taliaferro
GenuineSaab is offline
Old 12-05-2007, 03:36 PM   #17
mcrowley's Avatar
So is that the real deal or a copy?
95 9000 Aero
96 900 SE
06 9-5
mcrowley is offline
Old 12-05-2007, 03:40 PM   #18
saabkid37's Avatar
lightning is legit and good shit! i use them all the time for honda shit, good deals too...might be able to dig up a free shipping or 5 off coupon for you too...
EDIT: heres free shipping....enter it at checkout - HTPUMPFS
saabkid37 is offline
Old 12-05-2007, 05:39 PM   #19
JZW
Great, are you saying the five-0 stuff is garbage? I got mine there and it says made in the USA, but I guess it still could be a copy...
That sux! I have one for me ng900 I am waiting to install and already put another in my 9k aero...
John
JZW is offline
Old 12-05-2007, 06:46 PM   #20
how much are new gas tank straps?? i cant find them on eeuro..
1999 9 sold
1995 9k aero sold
2002 viggen current
