hp gains? - The Saab Link Forums
Old 11-24-2007, 06:23 PM   #1
gsaab's Avatar
hp gains?
any idea of the hp gains i would see going from having all the hardware for stage 3 with a mbc to the hard+soft stage 3?
96 SAAB 900 STAGE 3... Thanks Larry
gsaab is offline
Old 11-25-2007, 06:41 PM   #2
Send a message via AIM to aero93
im interested too with what power stg 3 makes i have stg 3 but never dynoed it, jsp type 2 3" dp , tdo4- 15hl, x flow ic , viggen cat back, jsp stage 3 ecu i would love to see anyone with similar set ups numbers t5 by the way
aero93 is offline
Old 11-25-2007, 06:43 PM   #3
Red DIC's Avatar
Why are you running an MBC on staged tuning?
Red DIC is offline
Old 11-25-2007, 07:33 PM   #4
Send a message via AIM to brewtide
Oh man, here it is again.
Because sometimes people prefer to do this? Because $250 for a BPC unit is insane? Various reasons...
-Bny
brewtide is offline
Old 11-25-2007, 10:08 PM   #5
gsaab's Avatar
i don't have the software yet im running the mbc with stock software. when i get the software i will be taking it off and going back to the solenoid
gsaab is offline
Old 11-26-2007, 06:01 AM   #6
amish_geek's Avatar
Stage 3 hardware + Stock Software + MBC = fast spool, max boost 15psi
Stage 3 hardware + Stage 3 Software = Fast spool, max boost ~20psi
With the stock software, you still have your 15psi fuel cut. You'll probably see ~20hp gains due to the stg3 hardware, but you'll only be boosting 2-3psi more than stock.
With Stg3 software, your fuel cut is raised, and you'll see gains of up to 40-50hp, since you'll be boosting that much more.
now if you were to run Stg3 hardware + Stg3 software + MBC, then you'll make the same power (the MBC doesn't add any more poser or boost), you'll just hold boost longer when the software would normally pull it back due to knock at high RPMs, and boosting with knock is bad.
amish_geek is offline
Old 11-26-2007, 06:35 AM   #7
You can make some good power without software, in fact once you do all your hardware, (minus certain parts) it then makes software selection easier.
