Front ARB Theory Needed. - The Saab Link Forums
Old 10-30-2007, 08:59 AM   #1
liketheword's Avatar
I have the stock 2K2 SE FARB 24mm...IIRC? As well as a an GS 22mm RARB. Also if IIRC for the Viggen they stepped the stock FARB down to 17mm...? I have arguments for and against this setup. However, I am not liking the current handling setup I have with regard to the front end feel in a turn. It just doesn't seem to transfer enough weight to maximize the contact patch. So please chime in with your opinions on this. I would apprecaite the incite for those who have been though this or have similar setups.
Current Suppension:
Stock Springs and Dampers (Lost the tip of the spring on the driver side. A 3in section in the lower perch.)
Stock FARB
GS 22mm RARB
GS 6-point subframe brace
GS SRB&C Kit
Vitamin SAAB
liketheword is offline
Old 10-30-2007, 09:07 AM   #2
Champ's Avatar
Koni Kit.
Champ is offline
Old 10-30-2007, 09:10 AM   #3
NahumCC's Avatar
Nicks site has explained this in detail. The size of the ARB needs to be considered against the dampener itself. If you have stiff dampener's then you don't need a very thick anti roll bar and this will allow the weight transfer to improve the contact patch. However if you have stiff dampener's and a sway bar that is too thick then your car won't roll at all and aid in providing a better contact patch.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 09:10 AM   #4
Sounds like there are 2 ways to solve this issue. One cheap and one expensive. 1. Pop-in a stock Viggen FARB. 2. Do the Koni kit.
Anyone else have a take on this?
Vitamin SAAB
Old 10-30-2007, 09:11 AM   #5
codesplice's Avatar
No, that's just the typical party line whenever anyone has a suspension question.
2001 9-3 - Nordic Stage 3
2007 9-5 2.3T Wagon
codesplice is offline
Old 10-30-2007, 09:15 AM   #6
What is? The Koni kit? See to me this car is a daily driver that I like to have a little fun with. It gets driven in the winter here in MN as well. I do have concerns about ground clearance... I know I am not the only one JK has just the Koni dampers on his car.
Vitamin SAAB
Old 10-30-2007, 09:19 AM   #7
codesplice's Avatar
Yeah, sorry, I swear the posts said something else initially
The Koni kit will definitely help your car handle better, but it will also drop you ~35mm ( I think). Maybe look into slightly shorter, stiffer springs (like the Viggen springs) to pair with stiffer, adjustable dampers (like the Konis).
2007 9-5 2.3T Wagon
Old 10-30-2007, 09:42 AM   #8
Champ's Avatar
Koni dampers and Viggen springs sound like a pretty good pair for performance while retaining winter time in MN.
I was planning on driving the Viggen lowered through winter, but got that classic instead.
It had no problems being as low as it was originally with the 2 winters I did put it through. (I drove in every major snow storm last year, no issues).
Champ is offline
Old 10-30-2007, 10:08 AM   #9
I thought the 2002SE had the same suspension as the Viggen..? Maybe I am wrong...? Anyone know for sure? And if they are different whats the drop from my current suspension w/ Viggen springs? Anyone have a good source for Viggen springs? So the issue is truly a spring and damper related? Wouldn't just a Viggen FARB resolve the issue for much cheaper and less hassle? Thanks in advance guys.
Vitamin SAAB
Old 10-30-2007, 10:15 AM   #10
Champ's Avatar
I believe the Viggen was 10mm lower (and a little stiffer) than the regular 9-3, not sure if the 2002's were different.
How easy is the FARB to swap?
Champ is offline
Old 10-30-2007, 10:44 AM   #11
Front and rear ARBs are the same for the 02 se as the viggen. The springs are slightly different. The viggen has lower springs, thats why it's not recomended to put a trailer hitch on them.
93nut is offline
Old 10-30-2007, 10:46 AM   #12
NahumCC's Avatar
FARB procedure is coming right up hold on.
2013 FR-S
NahumCC is offline
Old 10-30-2007, 10:48 AM   #13
The viggen has the 22m front bar, "to help with corner exiting traction".
I would suggest popping on the 25.5 rear bar. And not changing anything else untill you fully test the set up. It is trully the least expensive.
Old 10-30-2007, 10:51 AM   #14
8valvegrowl's Avatar
It's not real easy....you have to remove/slacken the subframe to get to the bushings.
If you increase the spring rate and damper rate, decrease your roll bar size.
If you have a Koni Kit, using a Viggen FARB with a 22mm RARB should give a good contact patch at the front and decrease understeer.
I have a 22mm bar up front with a 25mm bar in the rear with Koni springs/dampers...I plan on dropping the FARB to a 19 sometime to see how that affects change....
What size and A/R tire are you running?
8valvegrowl is offline
Old 10-30-2007, 11:22 AM   #15
Champ's Avatar
What's the bar on the top of the engine?
Champ is offline
Old 10-30-2007, 11:24 AM   #16
codesplice's Avatar
Strut brace?
2007 9-5 2.3T Wagon
Old 10-30-2007, 11:37 AM   #17
Champ's Avatar
Strut brace?
Must be, I was thinking that was the roll bar for some reason.
Champ is offline
Old 10-30-2007, 11:37 AM   #18
codesplice's Avatar
Roll bar is UNDER the engine.
2007 9-5 2.3T Wagon
Old 10-30-2007, 11:51 AM   #19
I thought the Viggen had a smaller FARB than that...
19mm sounds about right for the Viggen FARB. Am I missing something here?
Vitamin SAAB
