Clearing the glass lens - The Saab Link Forums
Old 10-29-2007, 08:07 PM   #1
I did this a while ago but never got around to posting it. I've been wanting to do HID lights in the 900 for some time. My holdback is the fluted glass lens. I'm not interested in going trough the trouble if the flutes are going to screw it up.
Some people have suggested faricating new lenses, other clearing the flutes. I have part of a smashed 9-5 headlight here (from 1999) and I thought I'd give it a try:
I did that with a die grinder and some sort of polishing wheel form harbor freight. I think that was the medium of the three. I used a cutoff wheel at first on its side to quickly remove the flutes, then the polisher wheel to start to clean it up.
I'd say it was a sucessfull try! I think I got it too hot (cracked). The crack I think was a combination of the heat, and the fact that the lense was a piece already (stress points). I used some water, and found the best was to do this partially submerged.
So as soon as I get a set or one more lens, I will try this out for real. I've found some good grinding stones that I would like to buy and give this a go.
If anyone knows of a cheap place to get some decent lenses let me know.
Tboy
Tboy is offline
Old 10-29-2007, 08:24 PM   #2
Send a message via AIM to mlemorie Send a message via MSN to mlemorie
Keep me updated on this please. I want to do the exact same thing to my 900. What projectors are you planning on retrofitting? Also, have you checked out HIDplanet.com? Thats where I go for learning on all that stuff.
mlemorie is offline
Old 10-30-2007, 06:22 AM   #3
Yea I'm looking at this with interest as I want to do the exact same thing! I was thinking of taking it to a glass shop but if it can be DIYed then I'm for that
hkayssi is offline
Old 10-30-2007, 06:25 AM   #4
IM planning on some E90 projectors that are bixenon. I bought them here from a memebr for not too much money. I figured they would be a good starting place at least.
I've been to HIDPlanet a lot. I haven't found too many posts on the lense clearing (at least glass lenses).
Has anybody ever tried a glass shop? My guess is this will be really expensive, but I am totally sure its possible.
I am looking at grinding stuff that does granite as well, they are both hard! Im looking at diamond grinding wheels (not real diamond).
Tboy
Tboy is offline
Old 10-30-2007, 06:39 AM   #5
Red DIC's Avatar
Ah Tboy! that was my suggestion based on the smoothing of the brake lights that you did a while ago. I hope this works out for you, i imagine it'll work out well as long as you can maneuver the grinder/dremel around the curves of the lens.
Good luck, keep us updated.
Red DIC is offline
Old 10-30-2007, 07:50 AM   #6
Yeah I remember that, just didn't chime in again!
What I had thought was to not clear the whole thing, but just enough for the light to shine through. I would like to order a cup cheel grinder, and then set up some kind of oscillating rig that would pass it back and forth and grind out an oval. Perhaps then I could do a bunch if others wanted it done as well.
I'm using the air grinder since this is mostly done under the water and water+electricity is more excitement than I am interested in.
Tboy
Tboy is offline
Old 10-30-2007, 07:57 AM   #7
drewz airflow se's Avatar
I am really interested in this. I want to do this to my c900. Keep us posted!
^CLICK ME^
drewz airflow se is offline
Old 10-30-2007, 08:40 AM   #8
Red DIC's Avatar
Tboy
Are you doing the grinding under water and the polishing above? I imagine that it'd be difficult to do the polishing under water due to the difficulty in viewing your artwork.
Red DIC is offline
Old 10-30-2007, 11:45 AM   #9
So far, that is no polishing. I bought this three stage grinding kit from harbor freight. There is rough medium and fine. That was done with medium.
The wheel is not a stone, but some sort of hard hard foam. I almost want to say ceramic but Im pretty sure its not. It does work really well on aluminum though and I was easily polishing up my valve cover.
I JUST bought some little sanding discs to try this again. I bought 100 grit silicon carbide that are 2" round. They also have .75" round, and the grit goes down to 36 grit. I also bought in 1" size 320 grit (same silicon carbide).
We shall see how this works out. I am hoping the 320 will get it darn close to done. The place I bought from also has lapping compound that I might try out later.
Tboy
Tboy is offline
Old 10-30-2007, 08:14 PM   #10
Yeah, I am currently looking at a set of RS6 bixenons. The problem that I am running into though is that these headlights are HUGE. In my opinion, one projector would look kind of strange, but thats just me lol.
mlemorie is offline
Old 10-30-2007, 08:22 PM   #11
Red DIC's Avatar
i don't believe they changed the lights from the a6 to the rs6
Red DIC is offline
Old 10-30-2007, 11:02 PM   #12
sethrman's Avatar
Send a message via AIM to sethrman
Very interested as well.
sethrman is offline
Old 11-04-2007, 12:08 PM   #13
NickTurbo900's Avatar
On the way!
NickTurbo900 is offline
Old 06-22-2013, 07:04 PM   #14
what happened to this?
felchi80 is offline
